Washing machine turns on but will not fill with water and start washing, kennore he 4
    President:
  • 1,776 Answers
It's most likely the water inlet valve solenoids. Be sure to unplug the machine. They can be tested using a multimeter or ohmmeter. Check for continuity. A lack of continuity indicates a bad solenoid. Also check the small metal screens inside the openings on the water inlet valve. Make sure they are clear of rust or debris. I will attach a photo for reference. Hope this helped and best wishes.
Posted on Sep 12, 2009
LG Turbodrum DD 8.5kg WT-R852 washing machine, will not completely fill with water to water, to initiate the wash cycle, wash process stops there.
THE WASHER IS OBVIOUSLY HAVING A PROBLEM DETECTING THE WATER LEVEL? IT DETECTS AS FULL WHEN ITS NOT AND THEN GOES INTO DRAIN CYCLE? THE FILLS AGAIN? I would suspect the water pressure switch but if it was detecting a full cycle it would sent it into wash cycle? the water inlet valve only allows the amount of water it is told to send in and does not control the amount or drain cycle. Im not sure here but Im thinking maybe the water level switch may be flawed, the one that has low-medium and high? all these can be checked with a multimeter
Mar 01, 2015 | LG Washing Machines
Fisher and Paykel Washing Machine model mw512
this sounds like the motor controller cant start the motor. I would be looking at the motor controller itself.
when it's filling with water, does the bowl go around slowly?
Sep 11, 2013 | Fisher and Paykel Washing Machines
Turned on whirlpool duet washer, came back to FH as realized forgot to turn water on. Have tried all the suggestions, but each time I plug the machine it tries to drain water and the motor hums. I cannot...
Make sure both hot and cold water supplies are turned on. Select a cold wash cycle and start the wash cycle, do you get cold water? Now select a hot wash cycle and start the wash cycle, do you get hot water? If you only get cold water replace the hot water fill valve. If you only get hot water replace the cold water fill valve. If you get neither replace both fill valves.
Jun 01, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My lg Washing Machine WF-T853A is putting black rubbery chunks and flakes through every wash.. This has been happening for about 12 mths and is getting worse to the point where half the lint bags are full...
sorry to ask you this but are you sure the flakes are rubber? usually the black flakes are lint from the clothes. to help combat this problem try this.1- buy 2 pkts of bicarb of soda or baking soda, 2- select high water fill. 3- select hot water fill.4- pour soda into an empty machine. 5- shut the lid and push the start button. 6- let it fill and wash, let it wash for about 5 to 10 min"s , do not let the water drain.7- turn machine off after letting it wash for 5 to 10 min"s , and leave the water sit in the bowl overnight . 8- in the morning start cycle again and let it go thru complete cycle. this should get rid of most of the lint. you might have to do this twice depending on how dirty the plastic tank is. please reply 4 more help and good luck.
May 12, 2010 | Washing Machines
F&P washing machine:GW709 doesn't cut out when filling
could b pressure switch tube is blocked or your control board with the pressure switch attached is faulty. empty water from machine, remove pressure switch hose from control board, blow thru tube to remove any blockages, refit tube. turn on cycle, select low water level, push start, after about 30sec"s push start again, that should stop it filling straight away. if the water stops push start again to continue filling. if it doesnt stop filling after restarting the cycle then it is your control module.if the water doesnt stop filling after the 30 sec stop it is the water valves. by the way what country do u live in because $120 seems to b alittle too expensive. please reply 4 more help.
Apr 29, 2010 | Fisher and Paykel Fisher & Paykel Washer
Dismantle washing machine fisher and paykel - unit smells -need to remove bowl to clean out
b4 u remove bowl try this 1/ buy 2 pkts bicarb of soda. 2/pour into empty bowl of unit. 3/select high water level 4/ select hot fill. 5/ start cycle 6/ let it wash for 5 to 10 mins then turn it off, do not let it get to rinse and drain the water away. leave it over nite with water still in it, in the morning restart program and let it do a normal cycle with no clothes in it. it will not refill as it already fill of water.please reply to see how u went or 4 more help
Mar 16, 2010 | Fisher and Paykel Washing Machines
Water over fills and machine does not start washing
put the washer on warn and start to fill,turn washer off,if it keeps filling then you need a new water valve,if it does not stop filling your water level,hose has come loose or the water level switch is bad-mike
Feb 09, 2010 | Kenmore 3.2 cu. ft. Plus Top Load Washer
My top-loading Maytag starts to fill with water when I turn it on and then completely stops and doesn't do anything more.
it could have a problem with the pressure switch.
the water supposed to trigger the start of the wash cycle and turns off the filling cycle.
it is a single trow switch that disconnect the connection of water filling and connect the wash cycle on.
maybe it is disconnecting the filling cycle but would not connect the wash cycle.
tnx 4 using fixya,
drcool
Sep 07, 2008 | Maytag Washing Machines
Keeps filling up even when full for over 4 hours (never changed cycles)
The timer sends a signal to the water level control valve. This valve serves two primary purposes. 1. Activate the water valve to fill the machine. 2. Shut the water flow down and allow the machine to operate. Try running the machine again. If the water continues to enter the machine after it begins aggitating then shut the water off at the spigot. Now watch and see if the timer moves or not.
If the timer does not move at all then I would replace the timer. If it DOES move then another problem exists and will need to be addressed.
Jan 13, 2008 | Maytag Performa PAV2200
Washing Machines Logo
20 people viewed this question
Top Washing Machines Experts
