Question about Kodak EasyShare C875 Digital Camera
The shutter won't close and I have had nothing but major problems with this & the company I bought it from is worthless and so is Kodak Co. It has been repaired & returned 3 times & still doesn't work properly. It shuts on and off at random times...frustrating!@!!
    President:
  • 2,976 Answers
Have you returned it to Kodak, or the place you bought it? Kodak can repair their own products a lot easier than jobbers can.
Posted on Sep 11, 2009
Kodak 650H projector - will cycle when the button is pushed to advance, but doesn't stop when the shutter is open. Rather it seems to keep moving until the shutter is in the closed position. The slides...
Sounds like a timing problem to me.... There is an adjustment you can make, but it's a "trial & error" fix: you have to make an adjustment one way or the other in the camstack, and then see if it's worse or better (relative to a correct slide cycle). This adjustment is made with the projector upside-down with the bottom cover removed. Check out the attached picture for more detail on where & how to make the adjustment.
Feb 09, 2014 | Kodak Office Equipment & Supplies
Shutter won't reset after battery replacement
it can fixed only camera fixera company,better if you fix it according to camera company because your problem also be facced to me,i take it to a ordinary camera fixer and then my camera fully get damaged because who fixed my camera they fall acid in battery placce.
Mar 26, 2013 | Vivitar V3800N Zoom 35mm SLR Camera
Shutters on the lens won't fully open
Stuck automatic lens covers are fairly. But usually it's very easy to fix, without even opening the camera. See this link for troubleshooting steps for this problem.
Dec 14, 2012 | Kodak EasyShare C633 Digital Camera
Won't charge
You have a Dead Kodak !!! needs to go to shop.
Sep 24, 2012 | Kodak EasyShare M532 Digital Camera
My father dropped my Kodak camera into the sand and it won't work now
If there's sand in the mechanics of the shutter flap and you can hear more that's stuck inside, there's nothing you can do except take it to a camera technician. It'll need to be disassembled, thoroughly cleaned and reassembled.
You will more than likely do more damage if you try turning it on or shaking it to get the sand out.
Sorry to hear about it!
Aug 02, 2012 | Kodak Md863 Easyshare Digital Camera...
Kodak C743 shutter
Had same problem. If the batteries are good, simply take them out and reinstall them. Worked for me.
Dec 07, 2011 | Kodak EasyShare C743 Digital Camera
When turning on, shutter opens then closes.
Most possible that the control board inthe camera is faulty and the shutter closing off after opening is the errors in the servo of the camera.
It will be necessary to obtain the control board from Kodak and should be estimated.
Sep 24, 2010 | Kodak EASYSHARE M1063 Digital Camera
It appears that pictures are being taken with the lens cap on - when that's not the case. In other words all camera indications are that the picture is "taken", but it is a black square. I'm thinking a...
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help:
Jan 12, 2010 | Kodak EasyShare DX4530 Digital Camera
How to replace battery cover for Kodak Dx6440
We had the same problem dropping the camera, and ordered a pair of new battery covers. I was able to install this by carefully removing the cover screws and slipping the pins into their slots. I am sure you probably got it by now.
This problem was before the one posted about start and then die. The "expert" response posted was worthless. This whole website seems to be a collection of anecdotal semi-worthless stuff.
Perhaps other topics may contain more relevant valuable commentary.
Sep 16, 2007 | Kodak EasyShare DX6440 Digital Camera
Polaroid FLM1511 LCD TV
I have the same problem, but I have a remote. I have tried everything and nothing works. When I try to type in the factory set password under parent lock, which is all zeros, it immediately turns the television to channel zero! We didn't set this, it just started happening. The manual for this model LCD 2000, is worthless! I called the company and they too were worthless! The call goes to another company for some reason and they have the same manual that I do. Any help would be appreciated!
May 18, 2007 | Polaroid LCD-1750 17 in. HD-Ready...
Kodak EasyShare C875 Digital Camera Logo
46 people viewed this question
Top Kodak Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Kodak Camera Expert? Answer questions, earn points and help others
