Question about GE WBSR3140DW Top Load Washer
Washer will wash but wont change to next cycle it turns off
    Sergeant:
  • 222 Answers
Most likely a bad timer. Not to difficult for homeowner to replace... Be sure to replace wires on new timer EXACTLY as they came off of old timer. Best to leave wires connected to old timer and move one at a time.
Hope this helps. Good luck.
Posted on Sep 12, 2009
Timer wont turn to next cycle
That works unless you want to buy a new one.
Apr 24, 2014 | Hoover HTC243 Top Load Washer
It wont spin
Your washer has a lid switch.97a908d.jpg If the switch is broken the washer will not spin. The pump is mounted on the motor.c5ccc2f.jpg
In the wash cycle the pumps turns counterclockwise. In the spin cycle the pump turns clockwise, forcing the water out of the machine. So if that lidswitch is dead then she won't pump OR spin. This video shows how to get into your machine and the next one shows how to replace the lid switch
Use this GUIDE to help you
Did I help?
May 28, 2010 | Roper RAS8445KQ Top Load Washer
Washer filles with water but wont change cycles
start filling the washer on the warm cycle,turn washer off,if the water keeps filling then you have a bad water inlet valve,if it turns off then you have a loose water level hose or the water level switch is bad-mike
Jul 21, 2009 | Kenmore 22422 Top Load Washer
Washer stops after aggatating and wont drain
My Kenmore 70Series washer goes through the wash cycle then just stops when it is to drain and then spin.
Jun 10, 2009 | Whirlpool Washing Machines
Washer will not start/continue with cycle
check if the water pump is not blocked in any way preventing the water from emptying properly as the machine wont continue until the water sensor tell the machine that its ready for the next cycle the pump may not be doing its job preventing the next cycle to take place eric
Jan 15, 2018 | Kenmore 24872 Top Load Washer
Wont continue to the next cycle
Hi. this washer has a Machine Control Board that is responsible for the initiation of the wash cycles. if this board is damaged in any way, it will produce these symptoms you are experiencing at this time.
I recommend Replacing this Damaged Machine Control asap. if has failed(damaged chip set).
Jun 02, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Washing machine wont go out of first cycle
Hi, you will need to replace the control unit in this washer asap. it has failed due to circuit damage locate din the logic sector.
May 30, 2009 | Bosch Nexxt 100 Series WFMC1001UC Front...
Wont pump water
If it did not pump at all I would say you had a bad pump. Try removing hoses and check for plug up. If there is no plug up, I would manually try to adjust the timer to see where in the cycle it does not pump. It could be a bad cycle timer.
Feb 04, 2008 | Hotpoint WMA30 Front Load Washer
Won,t drain on rinse cycle
There could be several causes for this, but probably a bad timer. One test for this...when it stops...is to turn it off...and turn the timer slightly clockwise...to the middle of the rinse cycle...and turn it back on. Does it run then?? Try advancing it to the spin cycle after the rinse. If it runs okay after you manually advance the knob...the timer is probably defective.
Jan 13, 2008 | GE WNCD2050AWC Top Load Washer
GE WBSR3140DW Top Load Washer Logo
75 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
