Question about Singer 2638 Mechanical Sewing Machine
I was sewing some thick material and now I get 3 sets of 3 beeps, now when you press the foot pedal nothing happens
    Problem Solver:
  • 8 Answers
You probably need to clean out the bobbin case area and then check your needle to see if it's bent. I know when I sew very thick fabric or many layers... it sometimes bends the needle. Also make sure you're putting the presser foot down when you sew. Then see what happens. Let me know if any of this works or if you've already resolved your problem.
Posted on Oct 09, 2010
Janome dks 100 se - it keeps beeping when I press the foot pedal and I have to do this several times before it starts sewing. It doesn't beep when using the stop/start button and is sewing fine
Same machine and model and same problem. It’s really irritating. It’s not the bobbin as the screen flashes worth the foot pedal. I’ll look at the tension but given how often it beeps and on so many different projects with different thread and tension it seems to be a fault of some kind... searching for a fix...
Sep 13, 2017 | Janome Sewing Machines
Feet won't feed the material.
Are you using a sewing machine? First have a look at the type of material you are using then see if you have an adjuster on the foot dog. My machine has 3 settings for thick, medium and slippery material. Sorry don't know all the terms as I have just started sewing. If that doesn't work it might be a good idea to take it in for a service.
Feb 25, 2016 | Sewing Machines
Why do stitches bunch when using walking foot on 3 layers of quilting fabric?
make sure that the thread tensions are correct for the thickness of material
remember that only the bottom foot walks and draws the material through so it may need a help and be pulled as it sews.
I find that women in sewing shops just love to talk about problems and how they can help so find a shop and discuss any problems with them
May 08, 2015 | Brother PC420-PRW Project Runway...
Machine is behaving as if not getting any power, but light is on. Press foot pedal and absolutely nothing happens
There is probably a bad connection in your foot pedal. Try moving it around with your hands at the contact points while pressing to activate. If it goes when you are shifting its position then it needs to be fixed or replaced.
May 20, 2014 | Janome Sewing Machines
430 aurora
Probably too thick to feed without dislodging the bobbin case, causing the error message.
May 07, 2013 | Bernina Activa 140
Foot pedal not working
Well, you are definitely getting power from the electric plug in.
Let's do some diagnostic work. Do you hear anything when you press the foot pedal? Any hum? Did you happen to leave it in bobbin winding mode?
your machine doesn't have a "sew" button for use without the pedal. So please rotate the hand wheel toward you as you press the pedal. Did the motor take over and sew?
If you know someone with a meter... have them test the pedal. (they will place probes on/in the part that plugs in which tests for shorts, etc.) If that tests ok... then we know it's something more than the pedal and it will need servicing by a Singer Tech.
Aug 27, 2012 | SINGER 7470 Sewing Machine
Jones Sewing Machine - When I press the foot pedal nothing happens? The light is on so there must be power.
is the foot pedal plugged into the machine correctly?
if it is then the foot pedal needs to be checked.
May 19, 2012 | Sewing Machines
White w2500 serger - nothing happens when foot pedal pressed
Sounds like it could be wiring - probably a job for a mechanic
Aug 26, 2009 | Sewing Machines
7436 beeps problem
Raise your button hole lever which is near the presser foot.
sewman7
Jun 11, 2008 | Singer 7436 - INGENUITY
Singer 7436 beeps - not working
Check to be sure the buttonhole lever is in the up position and the presser foot is down. Check feed dogs to be sure they are in the up position.
sewman7
May 26, 2008 | Singer 7436 - INGENUITY
Singer 2638 Mechanical Sewing Machine Logo
126 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
