Question about Sub-Zero 650 / O Bottom Freezer Refrigerator
SubZero 550 Water keeps collecting at the bottom of the refrigerator, behind the vegetable bins. I see it leaking from the drain pipe and the handyman has tried to clamp the pipe, but not sure why so much moisture and water are coming. Am wondering if the fan which is actually in the freezer, is supposed to be drying out the refrigerator? The water frequently turns to ice, and the refrigerator is only set at 4.
  • 28 Answers
On some models a drain heater or floor heater package is needed to stop the ice and water from forming. The freezer fan has nothing to do with the refrigerator. This is a repairable problem but you need an authorized Subzero repairman. They should know what a floor heater package is.
Posted on Sep 27, 2009
  • 725 Answers
Your drain may be plugged... it will need to be clean and clear... it may freeze too it you have ice in it you will need to add a drain heater to keep it clear
Posted on Sep 19, 2009
Sears Kenmore refrigerator 18cu frost free. Water constantly flows down the back of the fridge and collects under the vegetable bins. How do I fix it?
sounds like the drain pipe is blocked. turn it round and at the bottom there is a pipe check its not blocked. to clean out use an old curtain wire or something that can get up the pipe and flex.
Nov 03, 2013 | Kenmore Refrigerators
My whirlpool refrigerator Model ET18PKX6W00 leaks water under vegetable bins
Check behind the bins for a condensation tray/hose. Most refrigerators have these as they develop condensation due to the temperature differences when opening and closing the door. The tray catches the condensation, and drains it to a tray under the fridge. Here it evaporates when the compressor runs. Sometimes things block the tray or the hose gets clogged with gunk. clean out the tray/hose and hopefully your problem will end.
Dec 30, 2011 | Whirlpool Refrigerators
Water accumulation underneath the bottom vetable
Two solutions
1 If a frost free fridge/freezer - ice build up in internal cooler - defrost totally until no more water
2 if ordinary fridge/freezer look inside at the back, you should see a very shallow 'V' shaped plastic channel running to a small drain hole which leads to the rear outside of the unit. This channel collects the water drips from the cooler
Clear this hole with a pipe cleaner or cocktail stick or similar
Sep 27, 2009 | Samsung Refrigerators
Water is leaking in the freezer underneath the vegetable bin. Anybody knows what the problem maybe and how to fix it?- GE MAKE 685 ENERGYSTAR
I believe your defrost condensate drain has a blockage of ice and will need to be defrosted and clean the condensate line from the freezer to the condensate collection plate below your refrigerator. Most times the blockage begins slowly until the opening of the drain hole under the evaporator freezes itself shut. Below is a link to some solutions I have collected over a period of time. Also has a short movie that makes the repair look simpler. There are many reasons for this happening for example water leaking from a water supply line for the dispenser or ice maker, a crack in the defrost pan, water leaking inside and draining through the refrigerator cabinet, but most are caused by a defrost drain line blockage. Below is a link that may be helpful so try to take it all in and use the parts that most refer to your specific problem, Thanks Sea Breeze
click on link below
Sep 22, 2009 | GE Profile¿ Energy Star® 25.5...
There is water collecting inside my refrigerator.
The drain for the water to get away when defrosting is frozen shut...
Checkout this tip to help you..
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Aug 11, 2009 | Maytag MSD2756G Side by Side Refrigerator
Water drips from freezer into refrigerator
The drain is clogged..you need to see if it has a rubber drain trap going into the back side of refrigerator. if so, twist and turn as you pull it out and clean it..replace and then check that drain is open..if no drain trap on back side of refrig..remove freezer wall and open drain from inside freezer..you need to clean out drain trough using hot water..a little messy,but effective
Jul 12, 2009 | Refrigerators
Water in bottom of "fridge" and in vegetable bins
Hi: I'll assume this is should be a frost free freezer. If so the defrost drain is clogged and the water isn't getting to the evaporator pan. Without knowing the specifics although it sounds like a top freezer. Look for a drain below the evaporator coils. The will be in the back of the freezer behind a panel. Some models have a drain hose behind the ref. Use a strong solution of clorox and water to clean it out. The parts list or diagram of the fridge will help you find the drain. If you don't have it enter your model no. at sears.com parts direct. I hope this helps, Jeff
Jun 02, 2009 | Refrigerators
SubZero 550 not cooling, ice film
1. check the comp. working touch the top of the comp. 2.if the motor comp. working touch the high side tube of the motor comp. if to hot the freon is ok. 3. check the cooling fan inside.
Sep 23, 2007 | Sub-Zero 650 / O Bottom Freezer...
Water in the bottom of the refrig
HI thanks for your question. the drain tube is clogged. to repair turn fridge off, for at least 24 hrs. as the frain tube is between the inside and outside wall. so its just not dirt in the drain tube, its frozen . to clear after 24 hrs . purchase a small plastic tube , go to the drain tray at the back shove the small hose up the drain hose and blow air up the tube . it will unclog. thanks the appliance doc. please rate my answer. thanks.
Sep 22, 2007 | Amana ATB2135HR Top Freezer Refrigerator
Sub-Zero 650 / O Bottom Freezer Refrigerator Logo
470 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
ACME Sub Zero...
ACME Sub Zero...
Sal DeAngelo
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
