Question about Dryers
Not gas passing spark not burning
Not passing gas
  • yadayada
    yadayada May 11, 2010
    not passing gas, my wife would like that from me.
Dryer runs glow plug comes on no gas ingnighting glow plug goes off
Posted on Sep 12, 2009
94 Buick LeSabre is not passing emissions it has to much air in the air fuel mixture and gas is going into the catalytic converter I think its the erg valve but not sure I need it to pass emissions next...
try this trick first..pull the plugs out and make the center gap a bit wider than it calls for..this will give a hotter spark and the gas will burn more..its hard to get thru emissions in cold weather because the engine may not be warmed up enough yet..you need it to havve been running at least 30 minutes so it will be good and warm..take the car out on the hiway for about 20 minutes and go do the test after you stop in at a parts store and get any codes erased..
Dec 24, 2013 | Cars & Trucks
Does bad spark plugs burn gas faster
Worn spark plugs burn less fuel & yes,
waste gas & polute the air
Spark plugs get changed every 3 years,
before they wear to the point they stress
the ignition system
Mar 02, 2013 | 2003 GMC Sonoma Extended Cab
Running rough and white thick smoke from exhaust
sounds like you are burning coolant. sounds like you have a headgasket issue or cracked block. is your coolant level low?? in the overflow bottle and in the raadiator? something tells me that you will find that coolant is low. you are pulling coolant into the engine and it goes into the cylinder and pass the exhaust to the back of the car. the white smoke is the coolant burning off and thats why the car runs rough, because coolant is not flamable so it doesnt burn. this results in the spark plug not firing right and having rough running condition.
Nov 23, 2011 | Nissan Pathfinder Cars & Trucks
I have a montero sport 1998 v6 is giving me hard time pass 1 month now i have misfire problem and i do change the sensor and tune up and the engine is burning oil and gas too much
sounds like u have worn rings or valve guides or both could be fouling up spark plugs or could be low compression u could try a hotter setting spark plugs
Sep 08, 2011 | Mitsubishi Montero Cars & Trucks
Will not pass smog. what could be the problem
It is burning to much gas, could be that it needs a tune up.
Mar 13, 2011 | 1988 Chevrolet Nova
My car won't pass smog . (ca.) the no (ppo) measurement is 739 max allowed is 704 . what could be the problem i'd need to fix inorder to pass?
i would buy a really good set of spark plugs and replace the wires and distributar cap this will burn more of the smog off and get the plugs with 4 prongs they fire much better and improve your gas mileage and make it run smoother hope this helps
Sep 25, 2010 | 1994 Pontiac Grand Am
Im having issues passing inspection in TN
mcdevito75 here One way that will definetly heip is to cahnge the spark plugs, they burn the air &gas mixture in your enagine that make the emissions. It"ll be a good investment and you should pass inspection with no problems.
Jun 02, 2010 | 1992 Lexus Es 300
Cranks for about 10 seconds then starts, then runs good but you can smell fuel?
Your fuelinjectors are allowing to much gas 2 pass through at one time allowing ur vehicle to flood temperaly, please check your fuelinjectors and ur spark plugs for further problems, you can also get my help for free by texting 4195458235 and ask me any question day or night 24 hours a day 7 days a week, I hope I have helped you today.
Jan 20, 2010 | 1997 Pontiac Grand Prix
My shadow89 is consuming a lot gasoline
Your car is running too rich, you need to lean it out so there is not so much fuel being burnt. You will also notice an acceleration increase also once you do that..
Also it may need a tune-up, you may not be burning all the gas that passes past the spark plugs causing it to compensate for what the motor needs to run.
Hope this helps! -Steve
Dec 05, 2009 | 1989 Dodge Shadow
Dryers Logo
Top Dryers Experts
