Question about Palm Treo 700wx Smartphone
The "Treo" screen comes up and the phone wont boot up. this happens once a week but after 25 minutes the phone boots. NOW it's been almost 9 hours and it's not booting
Treo 650 suddenly went to a palmone boot up screen then to a palmone powered screen and just keeps repeating without fully going to the normal screen mode for the phone.
When the first screen flashes, as the bar is loading, hold up. Let go once the bar finishes. If that doesn't work you may need to hard reset. Just google how to give it a hard reset and remember that you will lose everything that isn't backed up if you do.
Feb 12, 2010 | Palm Treo 650 Smartphone
My palm treo 755p power cycles to the access powered screen
There are different types of resets that may cure this issue. Try them, starting from a soft reset.
http://forum.brighthand.com/showthread.php?t=13189
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 26, 2009 | Palm Treo 755p Smartphone
My treo 755P (Sprint) screen shows 6 RGB squares only!
Try to at least get the PDA to boot up. Once it's fully loaded, back up all your data. Check Palm.com for any additional software update which should be the cause of your problem. Download this update and re-sync all your data. If you don't want to mess with backing up your data, then here is the manual way to reset your device: take out battery, wait 30 seconds and replace battery while holding up navigation key until palm logo appears. Let go and the PDA will prompt you to erase all data ( To accept is up, to decline is down"). Hope I can be of an assistance. Thanks.
Mar 13, 2009 | Cell Phones
Palm treo 700w stuck
Have you tried a Master Reset?
Hold the red power (end call) button, take the battery out, replace the battery. You will be prompted if want to reset the phone with Up for yes, and Down for no. This is how to completely wipe the phone to the state it was when you first bought it. Please make sure to have any custom applications and data on the device (other then data that comes from outlook) backed up. When you resync it to outlook, your contacts, emails, calendar etc will come back.
If after a master reset, the phone does not power on, then you will need to get it replaced, as this is a definate sign that the mainboard inside the motherboard is bad.
Mar 13, 2009 | Palm Treo 700w Smartphone
My mobile is dead
I just had this happen to me yesterday. I fought with my phone for about 3 hours removing the battery and trying to restart it. It would take about 5 minutes for it to finally boot and once it did the touch screen would not work. So I did a hard boot and within 5 minutes my phone was back to normal. I lost all my contacts but I just did a restore with the backup software. To do a hard boot hold down the red and green buttons on the front of the phone and push the reset button on the bottom of the phone with the stylus. The reset button is on the right side of the power/usb plug. As I said my phone was back to normal in just a few minutes.
Jul 16, 2008 | HTC Touch P3450 Smartphone
Treo 750 p
Personally 10 to 15 minutes is not normal, I have had my 755p battery get hot after a couple of hours of straight talking, but not right away.
I would just take it back where you got it and tell them the problem that you are having and get another Treo. I have owned all of the Treo's ever made and they make great phones.
It does take some getting used to but the pros vs the cons of owning a Treo are much greater. Blackberry has come along way with their phones and if you are used to the Blackberry then the Treo just might not be the phone for you.
To get back to your question if the phone getting hot is normal, no, but it will happen from time to time when talking on the phone for long periods of time.
Hope this helps,
Glenn
Jun 20, 2008 | Palm Treo 755p Smartphone
Palm Treo 680 does not power up
ive had my phone for almost 2 months now. My old treo 680 didnt even turn on... this was a replacement. Now it seems i'm having the same problem again where the phone froze and now it wont even turn on. Its really starting to piss me off now and if anyone can give any advice besides "taking out the battery" or "hard and soft resets" it would be great.
Feb 02, 2008 | Palm Treo 680 Smartphone
Power Brightness dims after using Kinoma Player
Ok i think i can help,
Step 1: Go to preferences
Step 2: Go to power
Step 3: Change the Auto-off after: feature and increase it to 3 minutes, the maximum.
I know this will only help it a lil from the 1 minute you had before, but if you pres the volume button or something within the 3 minutes it will restart the 3 minutes.
Masalama
Sheeraz Khan
Jan 02, 2008 | Palm Treo 755p Smartphone
Treo 755p will not boot up
u need a memmory card, then everything will be okay, the memory card is da key to the fone
Dec 09, 2007 | Palm Treo 755p Smartphone
Palm Treo 700wx Smartphone Logo
57 people viewed this question
Top Palm Cell Phones Experts
Computer Repairing
Computer Repairing
fhonwizards
wayne chamberlain
Are you a Palm Cell Phone Expert? Answer questions, earn points and help others
