Question about Amana Dryers
Trips breaker when plugged in
1 year old amana front load dryer trips breaker as soon as you plug it in. new breaker installed afterwards
    President:
  • 2,976 Answers
If it still does, you have a dead short in the electrical system of the dryer. Don't try to use it until you get it fixed. It could start a fire.
Posted on Sep 11, 2009
Whirlpool frontload dryer trips circuit when started all of the sudden. Gas dryer, replaced circuit, must be dryer
The dryer should be on a dedicated circuit. Is anything else on the same circuit? Try plugging the dryer into a different circuit and see if it still trips the breaker. The breaker trips because there is either a short or too much power is being drawn for the size of the circuit. Check how many amps the dryer uses, and make sure the circuit is rated for that load. If the dryer needs a 20 amp circuit, and the circuit it is plugged into is only a 15 amp circuit, that will trip the breaker.
If all that is good, there is a problem with the dryer, either a short or the motor is drawing too much power, which usually means it is at the end of it's useful life and need to be replaced. If you are handy, there are sites you can go to which will show how to remove the motor. There are appliance parts stores which will test your motor, and sell you a new one if you need one. I have a 30 year old dryer that still runs, with it's 4th motor and 5th belt, if you are handy. The cost of a repairman to come out is probably not worth it after the dryer is about 10 years old, better to replace the dryer at that point. The new ones are much more energy efficient and do a better job than the older equipment, so they are worth the investment.
Aug 02, 2013 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
LG dryer is shorting
A seriously dangerous problem! Call a repairman immediately!
Sep 04, 2012 | LG DLG3788W Gas Dryer
My Sylvania - ground fault 15 amp breaker (32740) is tripping with minutes of reseting. It is for 3 washrooms & hallway & is 30 years old .....does or can it loose its life span? What is the cost...
A circuit breaker can go bad, but usually not in the way that you describe. That's not to say that it can't happen, but just not typical. GTE Sylvania breakers were once popular - I installed quite a few GTE / Sylvania electrical panels in homes in the late 80's. You may have trouble finding replacements; do not put an breaker that "fits" into the panel, unless the breaker is designed for use in the panel you have.
The first thing to do is determine the source of the problem. The breaker will trip, but not indicate if it was the result of a heavy electrical load or a ground fault condition. A 15 amp circuit breaker is designed to carry up to 12 amps continuously. The greater the load, the more quickly it will trip. it may carry a 14.5 amp load for several minutes to an hour before tripping, and a 20 amp load may be carried a second or two. GFI breakers are designed to carry 5 thousandths (.005) of an amp (or 5 milliamps) to ground, or the 12+ amps to neutral before they trip.
The way I would attack the problem is to install a new GFI outlet in front of the old wiring, by "inserting it" between the panel and the other plugs and lights, switches, etc on that circuit. The GFI outlet will provide the same GFI protection that the circuit breaker provided at a fraction of the cost.
Turn off the old GFI breaker, and remove it completely. Install a new, standard (non-GFI) single pole 15 amp circuit breaker in its place. Completely remove from the panel the cable that the old GFI breaker fed. Buy a new electrical outlet box (surface or flush mount as desired) that is large enough and deep enough for a GFI plug and 2 cables (if surface mount, use a 4" square deep box and appropriate cover - or if flush mounting use a deep plastic / fiber single gang box). It will be installed in a place close to the panel, but where the old cable will be able to reach inside. Bring the old cable removed from the panel into the new box. Run a new cable that has the same number and size wires from the panel into the new box, too. Connect the circuit neutral and circuit ground to the neutral and ground bars in the panel (they are probably the same bar) and the hot wire to the circuit breaker. make sure that the circuit breaker is OFF. Twist the two ground wires together and combine an 8 inch length of bare or green insulated wire with them in a wirenut.
Next, wire a new GFI plug in the new box. Connect the green wire from the wirenut to the green terminal of the GFI outlet.
Connect the plug's LINE terminals to the neutral and hot wires in the cable that you ran from the panel to the outlet box.
Now, connect the GFI plug's LOAD terminals to the neutral and hot wires in the cable that you removed from the panel and reinstalled into the new outlet box.
Secure the GFI outlet into the box and install the cover. Cover the electrical panel.
Power up and test. if the GFI trips, there's a ground fault in the circuit. If the circuit breaker trips, the circuit is overloaded.
Jun 13, 2011 | Your One Source Qo Single Pole Ground...
My Amana dryer won't turn on. It's plugged in but
First, check the circuit breaker at the circuit box and make sure the dryer breaker isn't tripped. If you have a voltage tester or access to one and know how to use it, unplug the dryer and test the voltage at the wall plug-in, This will tell you if you have good power to the dryer and indeed if the problem is with the dryer itself. These steps are usually overlooked by most homeowners and can save you a service call.
Good luck!!
Apr 04, 2010 | Amana NED7200TW Electric Dryer
Breaker keeps tripping when I use Amana NED5500TQ electric dryer.
Heating element or motor. Usually heating element. Replace limit switch (inside dryer) during repair. Limit switch should shut off before breaker if working correctly.
After repair clean or replace plug/wire. Inspect or replace receptacle in wall.
Sep 28, 2009 | Amana NED5500TQ Electric Dryer
I have a Amana Electric Dryer NED5500TQ. When I
It is possible that you could have a bad breaker in the panel. They will start to trip randomly when they are going bad. If not the dryer is drawing too many amps and the breaker is doing it's job. If the heating element is defective and drawing extra juice that could trip the breaker. Usually replacement breakers are not too expensive if you electrical panel is less then 20 years old and can be purchased at most home improvement stores. I would try replacing the breaker before you try repairing the dryer. If you install a new breaker and the problem continues to happen then you should check the dryer heating element. That component is what draws the most amps and would be the most common one for tripping the breaker.
Sep 25, 2009 | Amana NED5500TQ Electric Dryer
Dryer Repeatedly tripping circuit breaker, Apartment Maintenance man said we had a defective dryer, Bought new dryer and 5 minutes after first load was put in it tripped the breaker, Maintenance man...
You probably have a bad plug connection, make sure all the wiring in there is tight, you may see signs of arcing. A bad connection causes resistance, and therefore causes the breakers to trip. It is best to replace the receptacle on the wall outlet with a new one because the problem will just resurface again soon.
Aug 12, 2009 | Dryers
Kenmore dryer
first dryer should be on circuit by itself..if dryers runs ok for a while before tripping breaker call electrican to change breaker..change it not ck it ..too many times had electricans tell cust breaker ckd ok but after explaining to cust a breaker can not be ck without load they had breaker changed and solved problem ..not just old breaker but even new ones can cause problems..if breaker kicks as soon as dryer is turned on ck wiring at connection where ac is connected very seldom does any other issues with dryer cause immediate tripping of breaker
Sep 16, 2008 | Kenmore 63012 Electric Dryer
HE4 Kenmore Dryer tripping Circuit Breaker
If you put a light load in the dryer will not trip the circuit at all. That means heavy load made the motor work harder and over heat, it going to trip the circuit , pretty soon, the motor will be warn out.
Jul 01, 2008 | Kenmore Elite HE4 Electric Dryer
Dryer internal breaker trips
If you are using dryer sheets in the machine the filter screen may be plugged and will have to be cleaned. You can check it by placing a bit of water on the screen if it beads and does not flow through then the screen is indeed plugged reducing air flow. There could be lint and build up in the dryer's internal ducting and sensors, the machine will have to be disassembled for a complete cleaning this will also reduce air flow and cause the machine to heat abnormally.
Mar 01, 2007 | Asko T731 Electric Dryer
Dryers Logo
101 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you an Amana Dryer Expert? Answer questions, earn points and help others
