The led display shows an h and continuous random numbers
I have a Scientific Atlanta 8300hdc dvr that is installed to a hdtv. I get no cable service and the led display shows an h and continuous random numbers.
2 Suggested Answers
  • 127 Answers
SOURCE: Scientific Atlanta 8300hdc remote program instructions
Don't know the exact code for your STB, but you can download the manual from http://www.yamaha.com/yec/products/productdetail.html?CNTID=5027893&CTID=5000300&RLTID=1505&DETYP=RELATION ,
There you can find the list of all codes and also how to program them into the remote.
Posted on Aug 13, 2010
I have the vc500 hooked up and the software installed. I can see the video on the computer screen but when I press record, the computer video looks like it is scrambled. How do I correct this?
Just a wild pitch here; is the video fine after its been recorded or does that play scrambled as well? Make sure your equipment is tightly plugged in. Other than that, all I can say is maybe your dvr is obsolete or your computer is too slow.
Sep 19, 2014 | Diamond Multimedia ( VC500) Video Capture
Top and bottom of the screen are cut off
That set has an aspect ratio of 4:3. The problem is that what you are sending to it is 16:9 So you are sending an hd signal to a non HD television. The tuner is NTSC which is not HD. Theres not much that you can do about this.
Jan 17, 2014 | RCA F27650 27" TV
I have a Scientific Atlanta 3250HD cable box that loses sound everytime a channel is changed. The box must be rebooted to get the sound back each time. I have no problems with the 4250HD boxes. Any...
Did you call Scientific Atlanta to find out if this could be a software issue in their box, or if there is a failure occurring?
I have had cable boxes do similar things to what you are describing. It turned out to be the box was defective and had to be changed. They were not serviceable. I believe these cable boxes were made by Scientific Atlanta.
Jerry G.
Nov 14, 2009 | Insignia 32" 720p Flat-Panel LCD HDTV
HDMI cable hooked up, now CLOSED CAPTIONING is stuck on!
It has got to be the box. I would try to contact Scientific Atlanta if any way possible. The TV doesn't choose what inputs it shows CC.In other words, it would show it on all Inputs if it was the TV. Good luck and Thanks
Oct 30, 2009 | Toshiba 32AV502R LCD TV
Apr 09, 2009 | Yamakawa DVD-218 DVD Player
I just bought a Samsung 40" LCD 550 series and hooked it up to a Scientific Atlanta 8300HDC DVR. When watching an HD channel, it seems to "skip" or almost "drag" continuously. Any...
The first step you sohuld take, in my opinion, is to have the cable company come out and test your line levels to make sure there isn't a lossy connection somewhere.
You might also try rebooting your cable box by turning it off, unplugging it for a minute, then plugging it back in.  I have this issue with the same box and I believe the problem may be that the live recording for pausing and rewinding gets bogged down after a certain period of time.  I've had four of these boxes and had this issue with every one of them.  They seem to have a problem when the cable company pushes an update sometimes that corrupts the firmware and causes problems (my fourth box just failed tonight, that makes four failures in about eight months).
Dec 06, 2008 | Televison & Video
Set top box and remote control
My remote wasn't working until I programmed it to work with itself ... (how odd it wasn't done already).
"CBL" button and ""OK/SEL" held down simulataneously for 3 seconds ... then "001" for the Scientific Atlanta. If the unit turns off, you're in business.
Feb 03, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Off Air?
The Scientific Atlanta box was a cable box and recieved CATV signals. The Direct TV box is satellite only. You might check if it has a built in ATSC tuner for off air digital signals. Direct TV in most locations offers the major networks in HD format.
Jan 04, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Front power indicator blinks, clicking/high pitch sound
  1. This how to is to repair hard drive, software and some firmware issues that can arise on specific cable DVR and DAC and DCT boxes, First instructions are for Scientific Atlanta hardware. Firstly, one should be certain that the cable box has the coax (cable antenna wire) hooked up to the CABLE IN or RF IN on the box itself and be connected to a "hot" outlet - one that you KNOW works. Test it by connecting a TV directly to outlet. If you get a weak signal, the box will too. Digital boxes require a clean SNR. Remove in-line "surge protectors" on the coax. These prevent the signal from being sent by your cable provider to your box.
  2. Scientific Atlanta DVR or High Def boxes:These need to be "booted" or reset when certain errors occur. No audio on certain channels when SAP is NOT set to ON and confounding error codes that one can't seem to get out of. Common yet confounding errors are : No Audio on DVR Playback. No Audio on Certain Various Channels (ruling out SAP which can be enabled through the box, OR the television set itself) there are easy ways to test. If some channels audio is in Spanish when they are normally in English...the obviously you will check SAP first.
  3. Disc errors. On screen error on your TV that says something like..."there are problems with your storage disc.." or upon DVR playback instead of playing your program it loops upon itself and plays nothing.
  4. two different steps to reboot box: Simultaneously press VOL+ VOL- and "INFO" buttons on box itself, not from remote. Box will then display "bOOt" and shut down totally. Do not press ANY buttons or try to power on said box. Wait for the correct time to display on the box. This process can take anytime from 40 seconds to hours, depending on how fast the cable company's servers are responding at that moment and whether or not you have enough of a cable signal to fire up the download process. If you call customer service for your provider if this does not work, most likely a truck roll will be run for a tech to come out to your residence to fix the signal issue.
  5. When the correct time display is on the Scientific Atlanta box, THEN power on box and problems should be solved. An alternate way to reboot box is to simply unplug unit from power supply and replugging it in. Simply powering it on and off with the POWER ON button will not solve anything.
  6. On a Motorola box and/or DVR, the easy VOL+ VOL- and INFO will not work to reboot. Remove AC power plug from wall socket and wait 30 seconds to a minute while box is powered ON. Plug back in to wall socket.Box will "do it's own thing" and power itself on on it's own after the cycle has been successful (30 - 60 seconds) and the box should power itself back to the ON without you doing anything. Time will not display on Motorola"General Instrument boxes unless you set it up to do so in the settings mode.
  7. Common IControl/On Demand errors:
  8. MOTOROLA BOX Error 225 : A billing lock to prevent you from ordering pay per views. If your account is past due, or if you have an order to move to a new address in the service provider's "system", this is a preventive measure to keep customers from loading up tons of expensive pay per views and skipping out. Your cable company cannot over-ride this error. If you are not in above situations, your provider can "up" the limit on the box and clear it so you can order PPV through your remote control.
  9. SCIENTIFIC ATLANTA: for above mentioned error code, your SA box will display not a code but a prompt to contact your provider by telephone. Same issue.
  10. MOTOROLA BOX ERRORS 204...203.. 207..these may be easily solved by simply reseating the coax and then rebooting box.
  11. SCIENTIFIC ATLANTA ERRORS 2207: reboot box. This is a general code meaning the box has lost contact with the server. All of your iControl /On Demand orders come through your local cable head-end's servers. If and when it gets overloaded and times out, error 2207/207 will happen. Most of the time this is temporary. Reboot box, try again in 15-20 minutes.
  12. DVR BOX not displaying/recording/playing items:
  13. Reboot. Good chance of fixing.
  14. If your TV displays "One Moment, Please. Your Channel Should Be Available Shortly..." this is a SIGNAL issue. Reseat the line running from wall to the CABLE/RF IN on the box and at the outlet at wall. If no joy, call cable operator.
Nov 18, 2007 | Hitachi 53UDX10B 53" Rear Projection...
Televison & Video Logo
244 people viewed this question
Top Televison & Video Experts
Electro Med Services...
