Question about Cameras
I have two olympus 1010 camera's. Both have been dropped. The lens is patially open and the cover not fully closed. One will turn on so you can see through the LCD but only the top third of the field is visible. When photos are taken that is what shows up. Also it tries to focus but can't get it clear. The second powers up with information on the LCD but instead of seeing through the camera you see black. Phots can be taken but they too are black. What is wrong and what can be done to fix them?
  • ky35v Sep 21, 2009
    Thanks for the insight.
  • 291 Answers
I'll cover these separately:
First camera may be as simple as the cover blocking part of the image, or it could be that part of the sensor is damaged. Sensor is the part inside the camera that light hits and converts to voltage, you may hear it called the CCD or CMOS chip. You might be able to push the lens cover clear of the lens, but that may not be possible. Don't push too hard or it may break. The focus problem may be that the lens just can't move where it needs to focus the light. (The cover may stop it from moving.) It could also be that the lens or sensor has been moved so it's crooked and they don't line up anymore.
Second camera pretty clearly has a bad sensor. The LCD works and shows the menus and such, but it just doesn't get any information from the sensor.
If you're comfortable taking it apart, you might be able to take the sensor out of the first one and put it into the second, which would give you one good camera.
If not, it sounds like time to get a new one.
Posted on Sep 17, 2009
HAVE olympus 1010 stylus and the lens won't pop out. when I push the power button, it makes a sort of dragging chain sound and then 4 sort of "chimes". Looking at it facing front, the lens...
The internal plastic gears which govern the lens opening and closing are either damaged or out of alignment - this happens when a camera is dropped or has any other form of physical interaction for which it is not designed.
Jun 26, 2017 | Olympus Stylus 1010 Digital Camera
The camera shutter lens cover does not close completely
These things sometimes happen if the batteries are old. Might be worth testing the batteries and replacing it with new ones.
Jun 04, 2010 | Olympus Stylus 1010 Digital Camera
It wont turn on to take pictures, it wont boot up. but it will turn on when you want to review the pictures you took.
I experienced the same symptoms, with the exception that the lens cover wasn't opening correctly (I'd boot up to review mode then try and enter shoot mode from there [by turning the dial] in order to see if it was a battery or circuit board issue). I was seeing that the lens cover wasn't closing the full way when the camera went to auto shut off after this procedure. The solution to my problem was as per the below Olympus link:
Lesson learnt: The lens cover motor workings need TLC and should be opened and closed whilst immersed in fresh water periodically to remove any debris, and that the camera is sensitive to issues with the auto lens cover.
http://www.olympus.com.au/content/view/177/78/
Mar 23, 2010 | Olympus Mju Tough 8000 Compact Digital...
Focus problem olympus fe 34o
Not focusing at every distance - close to far ?? That seems like a lens problem to me and how the lens is focused, once its fully extended, varies between camera brands. .
Have you dropped this camera or knocked the lens when it has been open ?? Or have you dropped it at the beach and got sand or grit in the lens ??. If it is a lens problem it will have to go back to the service agent for repairs - ther is nothing you can adjust inside unless you are a camera technician
Nov 07, 2009 | Olympus FE-340 Digital Camera
Lens won't open
The problem you are describing is a problem witha sensor in the lens assembly of the camera. It seems to have failed and needs to be replaced. Following are the instructions to send your camera to Olympus for service.
http://olympusamerica.com/cpg_section/cpg_servicerepair.asp
Olympus will charge a flat rate repair fee for this product if beyond the one year factory warranty or the warranty is voided. The cost is $87.85 plus your local sales tax. This covers parts and labor, factory cleaning and diagnostic check, 6 month warranty and the cost of shipping the product back to you is all included in that price.
May 25, 2009 | Olympus Stylus 1010 Digital Camera
I dropped my olympus 540 zoom camera and lens cover is jammed
The problem you are describing is a problem with a sensor in the lens assembly of the camera. It seems to have failed and needs to be replaced. Following are the instructions to send your camera to Olympus for service.
Olympus will charge a flat rate repair fee for this product if beyond the one year factory warranty or the warranty is voided. The cost is $73 plus your local sales tax. This covers parts and labor, factory cleaning and diagnostic check, 6 month warranty and the cost of shipping the product back to you is all included in that price.
May 18, 2009 | Olympus SP-350 Digital Camera
Lens stuck open will not retreat battery fully charged when it is turned on lens moves in and out but will not fully close
The problem you are describing is a problem with something in the lens assembly of the camera. It seems to have failed and needs to be replaced. Following are the instructions to send your camera to Olympus for service.
Olympus will charge a flat rate repair fee for this product if beyond the one year factory warranty or the warranty is voided. The cost is $66.85 plus your local sales tax. This covers parts and labor, factory cleaning and diagnostic check, 6 month warranty and the cost of shipping the product back to you is all included in that price.
Apr 20, 2009 | Olympus FE-280 Digital Camera
Olympus 1010 lens stuck out. Won't shoot either
The problem you are describing is a problem with one of the chips in the camera that controls image processing. It seems to have failed and needs to be replaced. Following are the instructions to send your camera to Olympus for service.
Mar 29, 2009 | Olympus Stylus 1010 Digital Camera
Olympus Stylus 730 shuts off after few seconds. Battery is fully charged, tried a resetting: no change.
To save battery power, the camera automatically goes into sleep mode and the monitor turns off if there is no operation when the camera is turned on (when the lens cover opens and the monitor is on). No picture is taken even if the shutter button is fully pressed in this mode.
Operate the zoom lever or other buttons to restore the camera from sleep mode before taking a picture. If the camera is left for 15 minutes, it automatically turns off (the lens cover closes and the monitor turns off). Press POWER to turn the camera on.
Mar 26, 2009 | Olympus Stylus 730 Digital Camera
Nikon Coolpix S5 lens cover won't open
Hi Debscan, My 1.4 year old S5 developed the same problem and after checking out various websites I get the impression that it is a common one to these cameras. I found that if I put the camera on a level table and then turn it on (and off) 3 times the lens cover would open further with each try. On the third turn-on the lens cover would drop fully with a definite "Click" and the camera would work. The next time I shut it off, the lens would not close properly, but the same "Third times the charm" routine would always work. This may only delay the inevidable final crash of the camera, but it might get you a few more pictures out of it.
May 22, 2007 | Nikon COOLPIX S5 Digital Camera
Cameras Logo
27 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
