Question about Kenmore Cooktops
Need to reprogram my kenmore rang model 790.9568 it flashes ''F1'' and locks and unlockes the door automaticly
Why is door locked and will not self-clean?
Hey Kimberly, thank you for your inquiry!
I understand that the door on your Frigidaire range is locked and it will not start a self-clean cycle, it is also displaying an error code of "F91". The "F91" error code means that the door has exceeded maximum oven door unlock time. This means you could be experiencing an issue with your door latch, control panel, or a miscommunication within the range. To clear out a miscommunication within your range you need to disconnect power from it for at least ten minutes. I hope that this information is helpful to you. -Matt
Feb 11, 2016 | Frigidaire Gas & Electric Stove/Oven/Range...
What does the F93 code mean and how do we fixt it
i know that it can be very difficult to have issues with your oven. the f93 on this model of kenmore range indicates that you have a problem with the oven door lock assembly (see image below). this can be caused by a failed oven door lock assembly, a wiring failure or a bad electronic oven control board.
i recommend that you unplug the range and check the wiring between the components first. you can remove the upper back panel of the range to access the electronic oven control board in the console. you may need to remove the lower panel to access the door lock assembly on the back of the range. the image below shows the wiring diagram and other information that should help you check the wiring connections. check for a mechanical binding of the door lock assembly as well. if the wiring connections are okay, you will likely need to replace the oven door lock assembly. if you need further assistance, please reply to this thread. thank you for using manage my life.
May 23, 2015 | Kenmore Elite 30" Slide-In Gas Range White
What does F1 mean
The Fault Code/s will show up in the appliance Display
F0 - No Alarm Signal
Replace Main Electronic Control
F1 - Door will not Lock
Check door lock. Is Door Lock Getting Power
F2 - Door will not Un-Lock
Check door lock. Is Door Lock Getting Power Supply? Check Control Thermostat
F3 - Self Test Error
Disconnect Appliance from Mains Supply, Wait 5 Minutes and then Reconnect to Mains Supply
F4 - Shorted or Open Circuit Oven Temperature Sensor
Replace Oven Temperature Sensor, Check Sensor Harness Connection between Sensor and Control Unit
F5 - Relay Contacts Failed - Sticking
F6 - Power Board Temperature Too High
Check Correctly Installed, Check Cooling Fan Assembly, Ducting and Airways
F7 - Incorrect Polarity - Mains Supply
Check Mains Connection - Live & Neutral round the wrong way
F8 - Power Supply to Interface Problem
Check Wiring Harness, Replace Main Electronic Control
F9 - Procesor is Auto Resetting
Apr 05, 2015 | Electrolux White Westinghouse Stove Range...
I continue to get code F11 on my Kenmore Elite Gas Range Oven and therefore, I am unable to unlock / open my oven door. I have pressed and held down the STOP button as well as the oven light button.
Your model number should be much longer than 790 30 Open drawers and doors to look for the whole model number around the frame.
With the whole model number you can get more information at Sears Parts Direct. There are parts diagrams and user manuals and you can order parts.
http://www.searspartsdirect.com/
This site gives instructions for repairing F11 and recommends checking the temperature probe and tells how to do it.
How to fix Frigidaire oven error code F10 F11 F30 F31 etc AskGene com
Sep 10, 2014 | Kenmore ELITE 790 30 FREESTANDING DUAL...
Frigidaire stove oven want come on model # FGF368GSJ
Hello Larry D Harris - Does any part of the range work? I would recommend verifying that a fuse is not blown or a circuit breaker tripped. Test the power outlet with a lamp, hair dryer, etc. Another questions, does "Loc" appear in the display if any button is pushed? The Oven Lockout feature automatically locks the oven door, prevents the warmer drawer and most oven controls from being turned ON. If so, press and hold CLEAR/OFF for 3 seconds. A beep will sound. LOC will clear. The "DOOR LOCKED" will continue to flash until the oven door has completely unlocked. Do the maintop burners work? Granting that it does, you can try confirming that the shut-off valve on the gas pressure regulator is in the "ON" position (usually located on the back left-hand side of the range). This valve shuts off gas to the oven. If after the basic troubleshooting, you continue to experience the issue I would suggest contacting a certified technician to assist in the full diagnosis and repair of your range.
Nov 06, 2012 | Frigidaire Stove/Oven/Range Cooktop -...
We have a Five Star gas oven and attempted to use the self cleaning process to clean the oven. We started yesterday and it appeared to complete the cleaning cycle. This morning, however, the locking...
There are two reasons for the lock to remain locked. One: the thermostat/wiring failed. This results in the oven's control still believing that the oven is too hot (over 450 degrees) and thus will not unlock. The other possible problem is that the unlock mechanism failed.
You can try to unlock the oven manually. (For some ranges, you can do this from the back of the range.) Please add a comment with the model of the oven/range for more assistance.
I hope this gets you started on solving the problem.
Jul 06, 2017 | Five Star 48 in. TTN045 Gas Cooktop
How do you unlock a kenmore elite cooktop?
You can do this by:
Check the oven display to see whether the screen says "LOC." When "LOC" is displayed, the oven lock is activated and the door cannot be opened. You need to make sure it is locked so you do not mistakenly lock the door.
  • 2 Press and hold the "Stop" button on the oven control panel until "LOC" disappears from the display. Some oven models have a button marked "Oven Lock," which should be used instead of the "Stop" button.
  • Lock the oven again by pressing and holding the "Stop" or "Oven Lock" button until "LOC" appears in the display
  • Feb 03, 2011 | Kenmore Elite 44173 30 in. Electric...
    My Kenmore Range had theoven and stovetop locked symbol on it how do i unlock it
    Either hold down the 'Unlock' button or if the little red pad lock symbol is lid in the main display hold the 'Oven light' button for about 7 seconds...
    Jan 18, 2010 | Kenmore Elite 44173 30 in. Electric...
    How do I know when my stove is done self cleaning?
    to get all the detailed instructions
    just click this link directly
    http://www.applianceaid.com/selfclean5.html
    The oven door lock needs approximately 1 hour to cool down before the oven door can be opened after a self cleaning cycle has finished. If the lock does not open after the oven has cooled down, you can try....1) Unplugging the range or shut off the circuit breaker for 5 minutes. Plug the range back in or turn on the circuit breaker. Set the clock and try moving the door lock lever or opening the door. 2) Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever or opening the door.
    Most ranges today use 3 different types of door locks...one is a solenoid controlled lock ( you hear a loud buzz noise when setting or unlocking the lock and has a arm that you must move to set the lock )...another is a heat sensitive lock ( has a arm that you must move to lock and un-lock, makes no noises and has a spring that slowly moves to lock the door will the oven is heating up )...Some locks are motorized ( no handle to move, the motor locks the door by it's self when you set the range for self clean )... If the motorized and heat sensitive locks fails to open after the self clean cycle, you must access the lock and move it yourself to open the door. On the free standing ranges, most times you must lift the cook top to access the lock mechanism. On built in ovens, the oven must be pulled out to remove the top access panel to get at the lock mechanism. Some build in ovens can have the control console removed to access the lock system. On the heat sensitive style of lock, there are no electrical parts to operate the lock, usually you will need to replace the lock. On the motorized style of lock, you will have to use a ohm/volt meter to test why the motor will not work. On the solenoid style of lock, the solenoid is often mounted on the back of the range and can be accessed by removing the rear panel, some may be mounted at the front, such as in a built in oven. The failure of the solenoid style of lock is normally caused by a bad lock solenoid. In order to get your door open, you must operate the door latch mechanism manually. Unplug or remove power from the range. Take the rear cover off the range. Locate the door latch assembly and operate it manually and open your door. Then check continuity of the solenoid. Some of the latch assemblies have micro switches to supply power also. You may need to check them. You should be able to get the door open and use your range until you can get a tech to repair if you can not repair yourself.
    If you've interrupted the clean cycle or have accidentally set the clean cycle with the oven door open, the latch may have engaged and now the door can't be closed because it will hit the latch. There may be a door activated* switch on the front face of the oven. In this case you may need to manually press that door switch with your finger while at the same time canceling the clean cycle to get the latch to retract so the door can close fully again.
    thanks.
    Nov 11, 2009 | Kenmore Cooktops
    Cooktops Logo
    273 people viewed this question
    Top Kenmore Cooktops Experts
    Dan Webster
    Dan Webster
    jdthefixer
    mcgsp
    Level 1 Expert
    Are you a Kenmore Cooktop Expert? Answer questions, earn points and help others
