Question about Whirlpool Kitchen Ranges
Broiler turns on but wont shut off even when you press the off button the only way to shut off the broiler is to pull the plug,and as soon as you put the plug back in the broiler is on thanks mo
  • 999 Answers
Sounds like the broil relay is stuck. Yu may be able t free it up by tapping on it. The control should be replaced as a stuck relay will stick again. Eric
Posted on Sep 12, 2009
I have a Maytag super capacity oven and my broiler is staying on even after I push the off button
do you it beep when pressed if so keypad good next test best to have oven pulled out next time this happens while pulled out unplug I know the ignitor will stop glowing what I need to know does the gas valve shut off may take a few seconds if so then relay is stuck on control board
Feb 13, 2015 | Maytag Kitchen Ranges
Hi my washing machine door wont open, feels like the lock has broke ??
hi have you tried turning machine off at plug for a min then power back on put on a cycle press start. wait till it starts to fill and press stop and hold down the reset button till it beeps and wait till door unlocks. Or a quick way to open the door is unclip the foot kick stopper at bottom front of machine and pull the emergency door open which is a thing peace of hanging plastic. if none of this works try starting a cycle then press stop soon as it starts to fill and turn off on machine not at plug. hope this helps.
Sep 20, 2010 | Hotpoint Ultima WF860 Front Load Washer
Preheated stove put in cake a few minutes later smelled burning and cake was burnt on top.. Broiler was on and running hot as heck. tried turning off stove but would not shut off.. Unplugged. Let satand to...
Probably the control relay has shorted. But first check the voltages at your receptacle to insure that a neutral is not floating. You should fine 120 from each hot to the neutral.
Jan 09, 2010 | Kenmore Kitchen Ranges
Sansa e260 wont turn on indefinately.
did you try the lock on, rec button and the on button as you plugged it into the usb?
May 12, 2009 | SanDisk Sansa e260 MP3 Player
Powerbook g4 will not turn on
pull the battery out, put it back in, plug the mac in, and hold down the power key till u hear the chimb
Feb 16, 2009 | Apple PowerBook G4 Mac Notebook
Broiler won't turn off. Error code F-3
The broiler won't turn off even when you press the "Off/cancel" button? It sounds like the broiler control relay is stuck shut. The F3 code means the oven temperature sensor has failed, this probably happened because the oven got too hot when the broiler was stuck on. There is fail-safe thermal fuse that will blow if the oven gets too hot, so the oven won't melt down but you should leave the unit off so you don't blow the fuse.
To fix the relay, you will have to replace the oven control module. I think this is about $200 and not too hard to replace if you are somewhat handy. The temperature sensor is also serviceable, you can find parts at Appliance Parts Pros on the web. Hopefully you haven't thrown the range out yet, let me know if you need further assistance.
Nov 27, 2008 | Whirlpool RBS305PD Electric Single Oven
My ipod nano 4th generation won't turn on and it is charged. sometimes the screen freezes.
push the hold button on the top to the right then to the left then hold both the center button and the menu button till you see the apple logo it should work fine after than
Oct 05, 2008 | Audio Players & Recorders
Broil wont COME on
doble check the unit wiring, might have a wire out of place
it the display is showing the broil element on then check and see if you have proper voltage at the element, work bat to the board and find the problem
Apr 17, 2008 | Whirlpool GR465LXLS Electric Kitchen Range
Kitchen Ranges Logo
147 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
