Question about Unitech MSR 206-33 (msr206-33) Magnetic Card Reader
I have a magnectic strip encoder but need an usb adapter where can i get one
  • 346 Answers
HI,
I did some research for you and found a website where you can order the USB adapter for about $40.
Here is that website.....
http://www.nationalbarcode.com/catalog/unitech/msr206.htm
Scroll to the bottom of the page. Best wishes.
Posted on Sep 11, 2009
Unable to print 48
The encoder strip may be dirty and needs to be cleaned with a lint free cloth. The encoder strip is responsible for relaying the position of the print head to the main pcb. If the encoder strip gets dirty, many different problems can occur. The encoder strip is exposed, which allows grease, paper dust, finger prints, ink, etc. to get onto it. (it's the white strip when you open the scanner cover)
If the machine still errors, the encoder strip needs to be replaced or there may be a problem with the main pcb
OR
In Case You Still face Problem and Need Online Assistance Then Please Follow Us For On :
Brother Printer Support
Jan 21, 2014 | Brother MFC-J220 All-in-One Color Inkjet...
Canon Multipass F60 error
Encoder strip is the transparent strip which behind the cartridges carrier2b85ffb.jpg
A: Encoder strip (semi-transparent gray strip)
B: Carrier belt (black and brown toothed belt)
Please open the cover and check if the carriers is coming to the center ,if not gently pull the cart carrier to the center and then power on the printer , be carefully with encoder if its damaged then you cannot use the printer...
Good luck...
Oct 13, 2008 | Canon MultiPASS F60 All-In-One InkJet...
When i was replace the trailing cable my plotter writing the system error:86:01 how to solve
86:01 fatal error code resetable with power cycle- error is down to encoder not reading/ blockage on media path - encoder strip missing
1. clean and clear accuride rails ( long silver bar )
2. Clean or replace encoder strip
3. clean or replace encoder sensor
if all else fails contact Belmonte.co.uk for fast response
Jan 02, 2013 | HP DESIGNJET 800 42IN 1200DPI 96MB PAR USB...
Hardware error 0502 from A dell 940
Here is how to fix error 502.
Rick
» Reposition the Encoder Strip on the A940 All-In-One Printer
To reposition the encoder strip, perform the following steps:
  1. Remove the power cord from the unit.
  2. Lift the lid of the unit, just below the scanner portion of the All-In-One, to expose the inside of the unit where the printer cartridges are located.
  3. Gently slide the ink cartridge carrier to the middle of the printer.
Figure 1: Out-of-position encoder strip
  1. Gently move the top part of the printer belt to the right.
  2. Using your index finger, gently push encoder strip down and then back up to get it back into the slot located on the back of the ink cartridge carrier.
new_note.jpg Note: There is a small slot that the encoder strip fits into, which is located on the back of the ink cartridge carrier.
While working with the encoder strip, check it for dust or any unclean spots. If any detected, try to clean the strip by wiping it gently with clean cloth.
  1. Gently press the strip first to the rear and then forward to ensure that it is seated correctly.
  2. Manually move the ink cartridge carrier to the left, then to the right to check the positioning of the encoder strip.
Figure 2: Correctly seated encoder strip
new_note.jpg Note: If the encoder strip moves at all, it has NOT been repositioned correctly.
  1. Once the encoder strip has been re-seated, close the lid to the unit.
  2. Re-connect the power supply to the All-In-One.
  3. Press the Power button. If the encoder strip was re-seated correctly, the Hardware Error: 502 code will not appear.
Jun 14, 2011 | Dell A940 All-In-One InkJet Printer
How do I remove the Encoder strip on a designjet 500 24"
1. Remove the left hand cover
2. Remove the right hand cover
3. Remove 1 T15 screw that secures the Encoder strip to the left encoder holder
4. Release the Encoder strip from the left hand side
5. Release the Encoder strip from the Service station holder on the right side
6. Remove the Encoder strip from the printer
Apr 09, 2011 | Office Equipment & Supplies
Any one help my brother display error 48, init unable 48, what are the things that i have to do?
There are several issues that pertain to this code, including a service update. If your printer is still under warranty – visit your local ASC, find one here, this issue is covered! First off, the Service Update, the encoder strip needs to be cleaned with a lint free cloth. The encoder strip is responsible for relaying the position of the print head to the main pcb. If the encoder strip gets dirty, many different problems can occur. The encoder strip is exposed, which allows grease, paper dust, finger prints, ink, etc. to get onto the encoder strip. (The white strip when you lift the scanner cover)
If the machine still errors, the encoder strip needs to be replaced – Part Number LS4467001
If the machine still errors, replace the carriage PCB assembly – Part Number LS6543001
If the machine still errors, replace the Printhead – Part Number LK3211001
If the machine still errors, replace the Main PCB assembly – Part Number LT0284011
THANK YOU FOR USING FIXYA! – DON’T FORGET TO RATE OUR SERVICE!
Jan 21, 2010 | Brother DCP 165C Compact Color Inkjet...
Dell 922 printer jam
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} When printer does not have visible paper jam and printer is showing error paper jam
Check if the Encoder Strip is Broken or Missing
1.Power down the printer and unplug the power.
2.Slide the cartridge carrier inside the printer a couple of inches to the left.
3.Locate the encoder strip (Figure 1) on the right-side of the cartridge carrier encoder strip
Note:
The encoder strip is a plastic strip with small markings over its entire length. The strip may appear to be translucent.
1. Remove the power cord from the printer.
2. Lift the scanner unit to expose the inside, where the printer cartridges are located.
4. Gently move the top part of the printer belt to the right.
5. Using an index finger, gently push encoder strip (Figure 1) down and then back up, to get it back into the slot located on the back of the ink cartridge carrier.
6. Gently press the strip first to the rear, and then forward, to ensure that it is seated correctly.
7. Manually move the ink cartridge carrier to the left, then to the right, to check the positioning of the encoder strip.
8. Once the encoder strip has been re-seated, close the scanner lid.
9. Re-connect the power cord to the printer.
Reseat the Dell Printer Power Adapter.
If your printer has a momentary loss of communication with your computer, it may be necessary to reset the printer to re-establish communication. You can reset a printer by unplugging the printer power cord from the electrical outlet and from the back of the printer for 10 seconds then reattaching the cord at both ends.
Check with manufacturer if printer is still covered under warranty...
If yes then get it replaced.....or else get a new printer
Jul 31, 2008 | Dell 922 All-In-One InkJet Printer
Encoder strip
I tried for hours to reattach my encoder strip, and finally figured out the way to do it after reading many web postings, and my own trial and error.
The key is to use a "dental mirror" that you can pick up at a pharmacy or hardware store for about $5. (Perhaps a small compact mirror may also work.) And you need to focus light back there. (I used a head lamp.)
The problem is you just can not see the small slot through which the encoder strip must be threaded from the front of the printer. It sits in back of the ink cartridges. This thin slot "tunnel" goes though a rectangular piece of plastic. You can feel the rectangular piece of plastic in back of the ink cartridges, and looking with the dental mirror you can see how small the slots are on the right and left side, through which the encoder strip must be threaded. After "seeing" these small slots using the dental mirror, you then can feel them with the tip of a fingernail, and know exactly what you are aiming for as you then feed the encoder strip through. (It doesn't make any difference of you feed the strip from the left or the right, but the down arrow end of the encoder stip must end up on the right when you later attach it to the wire tab.) I fed the strip "blind" after I had formed a strong mental image of exacly what I was trying to do, and now being able to feel the small slot I was aiming for with the tip of a fingernail. (It is tough working in the small space in back of the ink cartridges, and if you have really big hands and fingers it may be impossible. I did not want to use forceps or tweezers because of a fear of damaging the encoder strip.)
The encoder strip then must be attached with the down arrow end on the right attaching to a flimsy looking wire on the right side of the printer. The left end of the encoder strip must be attached to a metal tab on the left side of the printer. You will need to hold tension on the encoder strip, and manually push the sliding ink cartridge back and forth out of the way as you attatch both ends.
(It's probably a good idea to gently clean the encoder stip of all your fingerprints and any smudged ink with a tissue after you get it back in place. Also be sure to clean the metal bar the ink cartridges slide back and forth on, so you don't get error message 0502.)
Be prepared for this to be a very frustating experience!
You will be maddened by how many times it will take to thread the encoder strip though the slot, how difficult it will be to catch the end of the encoder strip on the wire and metal tabs, and how you will have to figure out how to hold tension on the encoder strip so one end won't fall off as you attach the other end.
But once you use the dental mirror to see where you have to thread the encoder strip, and once you see the wire and metal tabs to which the ends of the encoder strip must be attached, then YOU CAN DO IT! It just takes persistance.
May 28, 2008 | Dell A940 All-In-One InkJet Printer
Hp g85 all in one
The "plastic strip" is the position encoder of the print head, it holds itself in place by two latches, one is fixed and the other is flexible, you have to put the encoder in the flexible latch first by holding it at an angle and then in the fixed one, probably you'll have to disassemble the MFP to have access and a better view of the parts.
Apr 27, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
Unitech MSR 206-33 (msr206-33) Magnetic Card Reader Logo
79 people viewed this question
Top Unitech Televison & Video Experts
Are you an Unitech Televison and Video Expert? Answer questions, earn points and help others
