Question about Maytag Neptune MAH5500B Front Load Washer
Water leaks from wash bowl - Maytag Neptune MAH5500B Front Load Washer
    Top Expert:
  • Maytag Master
  • 76,132 Answers
U will need to have the tub seals replaced.
Posted on Sep 11, 2009
The machine has recently developed an 'out of balance' problem and has started leaking water on to the floor. I am wondering if it could be a problem with the water level sensor allowing too much...
WEL THE PROBLEM THAT IS CAUSING THE LEAKING OF THE WATER IS SIMPLY THE VALVE HOSE COS THAT IS THE ONLY THING THAT CAN MAKE THE WATER 2 BE COMING OUT OF THE MACHINE BUT WEN U CHECK THE VALVE HOSE IF IS NOT IT THEN U CALL UR TECHNI9CIAN 2 RUN A CHECK ON IT BUT MOST ESPECIALLY CONCENTRATE ON THE VALVE HOSE
Jun 28, 2011 | Washing Machines
I have a f&p Smartdrive 708 washer that is leaking water underneath the machine. It is only a small leak at the moment. Could the seals be worn out?
Hi you need to identify where the water is coming from three main places are 1: pump seal 2: a hole in the drain hose 3: Main bowl seal my advice is turn it off at the wall lean it over and have a look underneath and clean floor area. does the base of the main motor look clean if yes its probably not the main bowl seal. So its down to the last two if your models got the plastic removable cover on the front its easy to remove it and watch where the water is leaking from my "guess" is a pump seal you will see it drip/ splash of the pump fan during drain/ spin cycle Be very careful to turn off at wall as there is voltage around these things even when power is off at the machine panel
Jul 02, 2010 | Fisher and Paykel GWL11 Top Load Washer
Water is leaking out the top it appers that the
Hi just read your posting.When you say the water is leaking out of the top ,does that mean it is leaking on the floor or leaking into the bowl even when the machine is off.If it is leaking into the bowl then it is a faulty water valve.Turn off the cold tap and leave for an hour and see if the water stops and if it does stop then the problem is the cold valve.If it doesn"t stop the leak turn the hot off and leave for an hour and see if that stops the leak.By memory I think your water valves are a double unit and to change one you must change both.Please reply with additional information about where the water is leaking to and I can help you rectify this fault,
Jun 16, 2010 | Fisher Paykel EcoSmart GWL15
Water leaks into the bowl after clothes havve been removed for awile
Unplug power and see if water still leaks in. If it does, it's probably the valve.Water valves can become corroded or clogged causing slow leaks. Most are easy to replace and cost under 50$. Hope this solves it- Thanks---ED
Feb 27, 2010 | Crosley Washing Machines
Kleenmaid top-load washing m/c leaks water and then smokes!
It sounds like you are leaking from the bottom of the unit. If you are leaking at the top then you need to check the water inlet valves, and also the drain pump and all water hoses. This doesnt sound like a seal issue.
Jan 02, 2010 | Washing Machines
Bowl continues to fill up with water causing
Pressure switch or pressure hose leaking ....or both
Oct 18, 2009 | Kenmore 22422 Top Load Washer
Bowl keeps slowly filling with water when turned off.
I think your water valve is bad , change it
Aug 12, 2009 | Washing Machines
Hoover automatic 830 washing machine - leaking from under bowl
The water seal has been damaged. Will need to be replaced by a qualified technician.
Nov 03, 2007 | Washing Machines
Maytag Neptune MAH5500B Front Load Washer Logo
52 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
