Question about Mitsubishi HC1600 Projector
Will not light lamp. The power and status lights start as green. Then the power light turns red and the staus light turns green and blinks. Then the staus light goes off.
  • 2 more comments
  • patrickboyle Sep 12, 2009
    The manual says that when the bulb is burned out both the poewer and the staus light turn red.
    My projector is only a few months old. It did not make a pop or small explosion. It simply refused to light the lamp when I tried to turn it on this afternoon. I immediately thought that the bulb had burned out prematurely but the manual says that both the staus and the power lights glow red when that happens. This is not the case with my projector. I have a steady red power ligth and a blincking green status light. The manual says I should press the Power button when the green light stops blinking. I have done this and it just repeats but does not light the lamp.
    I have ordered a new bulb. I don't know if that is the problem but I figure I can use a spare.
    I woulkd like an "expert" who at least bothered to read what I wrote.
    I did state how old it is - about four months. I run it on low, At that illumination it is supposed to last 3000 hours. Naturally at first I feared that the bulb had blown but since it is it is such a new unit and the indicator lights did not show a blown bulb, I wondered if it might be something else. So I paided for the opinions go "experts". That's a mistake I won't make again.
    President:
  • 1,922 Answers
You have a problem in your "switching power supply" circuitry you will need to troubleshoot this circuitry to find the reason,its shutting down to protect the rest of the unit from further damage from over voltage and/or current
Posted on Sep 12, 2009
    Novelist:
  • 190 Answers
You don't specify how old this unit is, or how long it's been working fine. Lamps have a finite life span, measured in the hundreds of hours. It sounds as though you may need to replace the lamp. Look up your user's manual for instructions on how to replace it.
    Guru:
  • 1,326 Answers
Sounds like you have a fault somewhere. Do you ahve the manual to indicate what the fault is. Also how many hours are on the lamp, its possible it needs changing as when it goes out it will not light and promt you to change it or in some models give an error code/fault
    Top Expert:
  • Mitsubishi Master
  • 79,865 Answers
It is very likely the projection bulb is burnt out, contact mitsubisihi for a replacement bulb.
Posted on Sep 11, 2009
Why does my Mitsubishi XD221U projector click and blink red/green on the power light when turned on?
All projectors run a self diagnosis when you press the power button. This does a kind of "pre flight check". If some component isn't working right then the projector won't fire up.
There's no mystery to these status lights. The answer to what they show is written in the manual. Sorry to be blunt, but if you had bothered to read your manual then you would know that red green flashing power light means that the lamp housing cover isn't closed properly. If it is the status light, then it means that the lamp has gone past its due time for replacement. I only know this because I read the bit in the manual just now about the Status Lights.
Sep 03, 2014 | Mitsubishi XD221UG DLP Projector
Why does my Mitsubishi XD221U projector have a power light blinking red and green?
Reset the lamp timer by holding power and menu button down for 25 secnnds
Sep 03, 2014 | Mitsubishi XD221U New
Nec vt540 vt540k
probably needs filters cleaning or a new lamp replacement.
Oct 07, 2013 | NEC VT460 Multimedia Projector
Replaced bulb yesterday worked fine. Today light will not turn on. projector turns on both lights green for 10 seconds, then power goes red and status blinks green for about 5 seconds, then status light...
green green is power on, normal
then it tries to light the lamp, but it can't so the protection circuit comes activated.
you get red and green blinking
Then it goes to standby, red and off.
so something has happened to the lamp, or lamp ballast power supply.
Take the lamp out and check if all is OK with the 2 terminals in the connector, and the leads to the lamp are intact.
Failing that, I would suspect the ballast lamp power unit
Mar 25, 2011 | Mitsubishi HC1600 Projector
Powers on for only a few seconds
if the power light blinks and the status light is off, check the lamp door. if the power light blinks and the status light is steady red or blinking green, you have a power supply/ballast issue. you may have to send it in for repair. try www.avsolutionsny.com.
Dec 09, 2009 | Mitsubishi XL8U Multimedia Projector
NEC VT 470 projector won't work at all
Try pressing the HELP button. Don't release and press the power button. The LED lights should blink. Release then try to power on again.
Jan 11, 2008 | NEC Replacment Lamp Projector Lamp for...
Toshiba 62HM14
What are the labels on the lights? Timer/Lamp/Service and what color is wich?
Jun 03, 2007 | Toshiba TheaterWide 62HM94 62" Rear...
Mitsubishi HC1600 Projector Logo
165 people viewed this question
Top Mitsubishi Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Mitsubishi Office Equipment and Supply Expert? Answer questions, earn points and help others
