Question about Brother Office Equipment & Supplies
Was printing in colour and suddenly the Magenta disappeared - there is still lots in the cartridge (both visually and according to the auto monitor
  • 1,606 Answers
This sounds like your print head has clogged up on you. What you can do is simply run a few print head cleaning cycles and you should get your magenta again. It may take 5-10 cycles or more before it is printing again. You should find the clean cycle option in your monitor software. Run it a few times before you do any test pages. It will save a small amount of ink as it won't print properly at first.
The cause can be from either the printer not being used enough, or a ink that isn't compatible with other inks or even the print head picking up clay from poor quality paper. If you don't use the printer enough the ink can dry or gel. Incompatible inks can form a gel when they touch. If the print head takes up particles off of the paper it can form an sludge that also blocks the print head.
Posted on Sep 12, 2009
Colors not matching computer
It is possible your colour cartridge has cross contaminated the ink reservoirs. To check this take the colour cartridge out and turn it over to see the coloured pads. They should look red, dark blue, and orange ( the colours are actually Magenta, Cyan, and Yellow, but are concentrated). If any of the pads are pale or particularly green - change the cartridge.
If the colours look alright, your issue is probably that your monitor makes colour by emitting light frequencies so is bright, printed images make colour by absorbing light frequencies so will always be darker. There is always the issue of course that your monitor also has a colour "temperature" bias. Photo pros calibrate their monitors and printers to match.
Mar 25, 2012 | Canon PIXMA iP90v Printer
My printer is hp laserjet cp 1515n. After printing some documents it writes "printing cool down mode" and begins working very slowly. Please help me
1515n - I have the Magenta colour 'shadowing' the blue test. A mirror image of the blue text. [slightly staggered] Black is fine. Applies to all Word docs when printing in blue - can you help please?
I only use genuine cartridges.
Thanks
Jules Radstock
Jul 23, 2010 | HP LaserJet CP1518 Printer
My out of warranty l7680 will not print or photocopy in colour. Printhead status says Refilled supply Detected in printhead Black No/Yellow Yes Magenta Yes/Cyan Yes Detected in Printer Black No/Yellow Yes...
The error states that you are using non-HP cartridges for all colours. If black prints fine then you should replace the colour cartridges with genuine HP colour carts. You should be able to get a refund on the refills since they clearly do not work as intended.
May 25, 2010 | HP Officejet Pro L7680 All-In-One Printer
Colors are not printing the acutal color
It all depends on the meaning of 'not properly'.
Try creating a document with four different squares, or words, of these colours: yellow, magenta, cyan and black. If all of them print (albeit not with the correct shades) it is probably an ICM driver error. But my guess is that only one of those four colors will print badly, due to a defective color cartridge.
The OKI 5150 makes all perceivable colours using cyan, magenta, yellow and black toners, so if one of these malfunctions, the resulting colors will lack the required shade of, say, yellow, and will appear to be "wrong". The yellow colour itself, of course, would simply disappear (the "yellow" you use might actually be 95% yellow and 5% cyan; then the "yellow" square will be printed as a very light shade of cyan, while the other colors - say, 95% magenta and 5% yellow - will turn out almost exact).
Try with the color test and replace any failing cartridge; if all four (almost) pure colours do print incorrectly, it's unlikely to be a cartridge problem, and we'll have to dig deeper.
Sep 09, 2009 | OKI C5150n Led Printer
I have a used C60. I have replaced both ink cartridges with Epson cartridges. When printing in color, the colors are not accurate. For example, red comes out yellow. Also, there are lines running through...
Hi there. The reason for your problem is that the colour cartridge contains cyan, magenta and yellow ink, plus a black cartridge of course. All the other myriad colours are produced by mixing these four basic colours. So, if you print red, it requires ink from both the magenta and yellow cartridges. Thus if your red produces a yellow print, it means your magenta is not printing. This can be due to a number of reasons, mainly an empty or faulty magenta cartridge or blocked magenta print nozzles.
If you wish me to help you with sorting out the lack of magenta, please post a new comment to this effect.
Mar 04, 2009 | Epson Stylus C60 InkJet Printer
Colours have suddenly become washed out and lime green.
I read a lot of complicated stuff about cleaning the print head after my similar problem this week. Finally I found an old, soft toothlbrush, gave it a very light spray with windex and lightly brushed the magenta print head. I put the cannon cartridge back in and everything is printing perfect again. This worked for me, good luck to l you.
Dec 08, 2008 | Canon PIXMA MP780 All-In-One InkJet...
The printer suddenly refuses to print black but will print colour
try to set it in the default printer settings. it will go back to the original set up
Nov 28, 2008 | Canon PIXMA MP810 All-In-One InkJet...
Won't print red
Red is a combination of Magenta and Yellow. Print a nozzle check and observe for Magenta, Yellow and cyan. If the three colours are printed, no problem with the cartridge. Then it must be the problem of seeing colours in your monitor. .
May 02, 2008 | Canon PIXMA iP2000 InkJet Printer
MP700 Magenta horizontal stripes
I have the same problem. Here's the advice I found somewhere on the internet:
If a jet (nozzle) in your cartridge has gone bad you will see horizontal bands and/or white streaks in your print. Print characteristics may appear incomplete and/or the filled in areas on may not show up.
1) Run some warm water over the print head. This can wash away any ink which might have dried in the cartridge print head. Dry the cartridge with a lint-free cloth before placing back into the printer.
2) Clean the contacts on the cartridge (the copper colored circuitry) and the contacts where the cartridge clips into the printer with water or alcohol. After cleaning, insert and remove the cartridge from the printer a few times to be sure you have a good connection between contacts on the cartridge and the printer.
3) If your print is smeared cleaning the wiper blade may fix the problem. Do this according to your printer manual instructions.
Nov 25, 2007 | Canon MultiPASS MP700 All-In-One InkJet...
Incorrect colour is printed
I would try to replace the printhead and the magenta cartridge at the same time. Lots of people with leaky cartridges have this same symptom only, it is with whatever color is malfunctioning.
Apr 25, 2007 | Canon i850 InkJet Photo Printer
42 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
