Question about HP Pavilion Slimline s3400t, Intel Core 2 Duo processor E4600 , 4GB DDR2-800MHz dual ... PC Desktop
Connecting xbox 360 to play through hp pavilion
The desktop has a tv tuner and av inputs (red white yellow) in the front of the computer. once hooked up how can i play my xbox through the computer?
  • pelejr44 Sep 12, 2009
    how do i set to av in?
  • 298 Answers
Turn on your pc'd TV application and set to the AV in.
Posted on Sep 12, 2009
I have a daenyx lcd tv, model DN-15, input 12VDC-4A and am trying to hook it up to an xbox 360 console.
If you are using the Red/Yellow/White cable, that's composite cable, but if you're using the one that's Red/Yellow/White/Blue/Green, that's called component. So basically, you set your TV's input to the corresponding color match. 5 colors: Component, 3 colors: Composite.
Sep 13, 2014 | Video Game Consoles & Games
How do you get your xbox 360 to play, on a 65'' mitubishi projection tv,its connected but nothing comes on screen when i put a movie in just a blank screen and no sound,if i'm on a channel,the channel...
Hello
The Xbox 360 connects to a TV using either
- COMPONENT (red blue green for video, red and white for audio
- COMPOSITE (yellow for video, red and white for audio)
- HDMI
So, if your TV is on a "Channel", it is not on the correct input to view the Xbox 360.
Check the Xbox and verify which cables it is using to connect to the TV. When you find this, follow the cable to the back of the TV and find the input selection. It should be listed as the type and a number (i.e. HDMI 2, COMPONENT 1).
Have the Xbox on. Use the TV remote and use either the INPUT or the MENU options to change the input to the input that matches the port that the Xbox is connected to.
This should make the Xbox work.
When you are done with the Xbox, use the INPUT or MENU to change back to the tuner to watch TV.
Nov 03, 2013 | Mitsubishi WD-73734 73" Television
What's your problem?Im trying to hook up my xbox 360 to my JVC 27 inch TV, I installed the yellow to video input and the red and white to audio input and all get is the audio and no video. What am I...
Troubleshoot.
1. Ensure yellow is actually connected to an "input" slot.
2. Ensure TV is set to the correct input source.
3. Ensure your yellow, white and red RCA connectors are grouped in a single input source to TV. Sometimes the "component" and "composite" inputs are grouped closely together.
4. Consult the TV manual for hookup instructions.
5. Conduct a continuity test on the yellow xbox wire with a multi-meter.
Oct 04, 2011 | Sega The Club - Xbox360 for XBox 360
No picture or sound with brand new xbox friend's xboxs worked ok
Look like ur Xbox 360 AV RCA cables is not making contact to the input board very well.Take some rubing achahol cleans the all those input holes,take the RCA AV connections make couples twises to the red,yellow and white,will help.Make contact with ur input board it should work.
Apr 28, 2010 | Zenith SY2551S TV
Composite connection on Gateway Desktop
They are Video and Audio for connecting device together
  • Yellow = Video
  • White = Audio - left channel
  • Red = Audio - right channel
the connectors on a Desktop PC from the graphics card will be an OUTPUT-possibly labelled TV output, so what ever is displayed on your monitor can also be sent to a TV or recorder etc The connectors on the Xbox are also OUTPUT and designed for connection to a device which has the same connection but for INPUT
Your monitor may have composite inputs and allow you to switch to those Some TVs will have those connections as inputs and you would select one of the AV options to see the signal, often a separate button to choose AV input /HDMI / PC etc Some DVD and Video also have these as an INPUT as video cameras often have that type of connection - to record the signal
  • If this solutions solves you problem, please do not forget to rate my solution.
  • If not, then please comment back so I can help some more
Mar 25, 2010 | Gateway GT5453E Refurbished AMD Desktop...
I just need to see a visual connection of xbox 360 to bacig flat screen tv.Eight now i am not getting a picture.Ihave regular x box hooked up and iam getting a picture for that.
First check the AV audio/video wires to determine if you have SD or HD wires. If you have 3 plugs (red, white, and yellow) then you will get standard definition (SD). If there is 6 wires (2 red, white, yellow, blue, and green) then you can connect High Definition (HD) and you can also connect SD as well. Now what you need to look @ if you have the wires with 6 ends (component HD AV wire), is on the part where you plug into the back of the Xbox 360, there is a switch on the box that is on the wire. It should say "TV" and "HDTV". If you have the component wires hooked up (5 wires) then select "HDTV" if you have only the 3 wires (red white yellow) for SD hooked up switch it to "TV". That is the first thing to check. The next thing to check is the way the wires are hooked up. If connecting HD, you very easily could've mixed up the 2 red wires, 1 is video and the other is audio. The way to determine which is video and which is audio is, for video, the actual plug itself is gray with a stripe of color which indicates where it goes on your tv, the audio plugs are solid white or red. And remember that the yellow plug is not used for HD setup. If you have a Xbox 360 that has the HDMI (High Definition Multimedia Interface) input, then I would recommend using that to hook up your console. With the HDMI its only 1 wire to hook up and is extemely easy to set up. The HDMI wire transfers audio and video all in 1. There is only spot it can fit into, and its located right next to where you plug in the AV wire on the console. To me, the HDMI is "cleaner" looking b/c its only 1 wire.
Feb 27, 2010 | Video Game Consoles & Games
Can't find where to get the input from red/white/yellow cables
if u have a look on the back of the pc, u shud see a card with a lot of connectors on it, video, audio and an antenna, if this has then connect to the video in connector and set the tv tuner software to composite and then it show what is bein imputted...
hope this helps
Feb 15, 2009 | HP Media Center m7250n (ED842AA) PC...
Xbox 360
Yes I have mine hooked up to a old Tv
Regards
Mick
Nov 12, 2007 | Microsoft Xbox 360 Elite Console
No color on Sony TV, all other tvs are great
check the av cables in back of your tv and also check the wires connected up to the xbox 60 it's self
Sep 01, 2007 | Microsoft Xbox 360 Console
HP Pavilion Slimline s3400t, Intel Core 2 Duo processor E4600 , 4GB DDR2-800MHz dual ... PC Desktop Logo
1,022 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
