Question about Husqvarna , No.455 Rancher, 20" Gas - Powered Chainsaw
Husqvarna chainsaw no spark - Husqvarna , No.455 Rancher, 20" Gas - Powered Chainsaw
    Brigadier General:
  • 4,088 Answers
Ignition systems on newer saws are a solid state all-in-one package. Disconnect the kill switch wire from the ignition pack to make sure that the switch isn't broken. Use a fresh spark plug to check spark with. An old one that is black inside is likely shorted. If still no spark, replace the ignition module. Use a piece of card stock to set the flywheel magnets to module gap, then tighten screws
Posted on Sep 12, 2009
rwvanlue
  • 486 Answers
SOURCE: My Husqvarna 350 chainsaw won't stay running.
Fuel starvation - 'lean fuel' condition
Basic things to check:
1) spark plug
2) spark arrestor in muffler
3) fuel lines and tank filter
4) turn adjustment needles out (counterclockwise) 1/4 to 1/2 turn
Chain Saws:
5) check impulse tube and intake boot for cracks or leaks
*if all of the above are OK and/or do not improve performance then:
Remove Carburetor
6) replace gaskets/diaphragms
a) use a spray carb cleaner to clean jets, holes, and body of carb
b) fuel pump diaphragm goes against the carb body,
then the gasket towards the outside
c) metering gasket goes against the carb body,
and the diaphragm goes towards the outside
Posted on Nov 25, 2009
Testimonial: "Excellent info"
dontbother10
  • 2220 Answers
SOURCE: 353 husqvarna chainsaw, floods during start process
Husqvarna says the initial carburetor needle valve settings are from lightly seated 1 turn CCW for both H & L.
Your Operator's Manual can be downloaded here:
http://weborder.husqvarna.com/order_static/doc/HOUS/HOUS2004/HOUS2004_1140204-95.pdf
Once flooded Huskys are very hard to start. This works well on my 359.
Start Procedure
Cold:
  1. Ignition on/off to on
  2. Set compression release – optional step even if saw is equipped with a compression release
  3. Pull (close - sets fast idle) pull starter and listen for an attempt to start. once heard (usually two pulls)
  4. Set compression release – optional step even if saw is equipped with a compression release
  5. Push (open) choke pull starter until it starts. (usually the next pull)
Warm:
  3. Pull (close - sets fast idle) choke, - Don’t pull with choke closed.
  4. Push (open - fast idle maintained) choke, pull starter until it starts. (usually first pull)
Hope this helps
Lou
Posted on Oct 03, 2009
  • 97 Answers
SOURCE: no spark
Remove cover & unplug shutoff wir from coil and replace cover & check for spark,if you have spark repair shorted wire or switch.If no spark remove coil and have checked.
Posted on Mar 14, 2009
dontbother10
  • 2220 Answers
SOURCE: wanted coil ignition module for Husqvarna 394xp chainsaw
I found an IPL for your saw here:
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter 394 as model number (no XPs, Es, just the numbers)
Serial number decode – for use with IPL
06 1500198
06 = year produced – 2006 (single digit before 2000)
15 = week produced - March
00198 = 198th unit Husky produced that week
I chose the 92-10. The coil and wire were manufactured as separate pieces. I found both at Jacks Small engines. It is interesting that the same ignition wire fits a Poulan at 1/2 the cost. About $86 for both pieces at Jacks. HTH
Lou
Posted on Oct 19, 2009
Testimonial: "Most interesting and very helpful Thank You"
SOURCE: 350 chainsaw will not start and run, getting fuel
check set screws on the side of carb turn the all the way in the turn out till idles or check the screen in the muffler
Posted on Feb 04, 2010
Husqvarna 257 chainsaw wont start
The flywheel has an alloy key moulded into it, check the key has not sheared and the timeing is now out,
Dec 27, 2012 | Husqvarna Garden
Husqvarna 359 - No Spark
remove the side cover and then the small wire to the coil check for spark again if still no spark the coil is bad if you get spark back the problem is the switch or wiring
Oct 04, 2012 | Husqvarna Garden
My husqvarna chainsaw wont start
Try bypassing the switch by connecting the two wires together. If it starts then you know what the problem is.
Nov 23, 2011 | Husqvarna Garden
Husqvarna rancher 55 chainsaw having problem starting have spark new spark plug, plug is wet after trying to start it
You need to check that this machine is mechanically sound, remove the muffler and check the condition of the piston skirt through the open exhaust port, any signs of scuffing ( seizure ), and the cylinder will need to be removed to assess the damage
Aug 27, 2011 | Husqvarna , No.455 Rancher, 20" Gas -...
I have a husqvarna model 136 chainsaw that wont start.Has spark,gas compression
trie with another spark plug if not heling check maybe air leak between cilinder and carb. also if not helpin rebuild carburattor.
Dec 03, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
Feb 03, 2010 | Husqvarna Garden
No spark
Mar 14, 2009 | Husqvarna Garden
Husqvarna , No.455 Rancher, 20" Gas - Powered Chainsaw Logo
1,604 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
