Question about Samsung LN-S4692D 46 in. LCD HDTV
We have a samsung digital tv (46Inches) which is 6months old and the pixels fall down like apuzzle. the PCB has been replaced but the tv still does it.The company has said its the aerial, but the aerial has been checked by specialists and is working fine. is this common and how does it get fixed or do we need a new tv?
    Genius:
  • Samsung Master
  • 1,039 Answers
If the main board has been replaced and it only does this when watching though the antenna input then there is a reception problem ,weak signal. Call Samsung ,this is under mfc warranty and they will make sure it gets fixed.
Posted on Sep 11, 2009
Samsung HLP5685 W
yeppers..the ballast has taken early retirement...can you unplug the ballast output, and see if it's running into a short condition?
Mar 09, 2008 | Samsung HLP5085W 50" Rear Projection...
Power supply or mainboard?
what is the model # of your TV
Jun 02, 2013 | Televison & Video
Samsung HLP4663W DLP 46' tv: Just replaced with new color wheel and the lamp is newer -6months old. When I plug in the hdmi cable, I get picture but no sound. However, if I plug in the coax, I get...
You still need to get an audio Left and right connected from the video source.And for the digital reception from the antenna source is not possible because your unit is not equipped with a digital tuner(it is NTSC or analog reception only)it needs an add on digital tuner that has an hdmi output.Newer ones now are equipped with digital tuners.
Oct 27, 2010 | Samsung HLP4663W 46" Rear Projection HDTV
Help! My Samsung PL70 which is 6months old has
Mine just did the same thing. It is frozen on and stopped working while I was trying to change the flash setting. Even the image of what I was pointing at is stuck on the screen. Mine is only about 3 months old. I tried holding down the power button and it did nothing. Taking the battery out and putting it back in worked. I hope this doesn't happen again!
Jun 07, 2010 | Samsung PL 70 SL720 Digital Camera
Why does my digital TV image fall apart into pixels and the sound breaks up - when I switch the digital box to TV antenna, the reception is ok, just not so sharp as with digital conversion. Is it a problem...
Tries directly to a good antena,like outside antena.or a digital antena,no need for any box,new LCD Flat screen tv have an converter in side,no need the box help only old CRT tv have no converter board in side.
Oct 31, 2009 | LG 42LG50 42 in. LCD HDTV
Can I see the difference
Visually, there is very little difference to the eye of the average consumer between 720p and 1080. However, 720p can deliver a slightly smoother-looking image, due to the fact that lines and pixels are displayed in a consecutive pattern, rather than in an alternate pattern.your tv is display format is 720p and blu ray is 1080p. what happen is it will be scaled into 720p. old tv set format is 480p 720p represents 1,280 pixels displayed across the screen horizontally and 720 pixels down the screen vertically. This arrangement yields 720 horizontal lines on the screen, which are, in turn, displayed progressively, or each line displayed following another. 1080p, on the other hand, represents 1,080 horizontal lines displayed sequentially. This means all lines are displayed during the same pass. 1080p is the highest quality HD display format. 480p represents 720 pixels displayed across the screen horizontally and 480 pixels down the screen vertically. This arrangement yields 480 horizontal lines on the screen, which are, in turn, displayed progressively, or each line displayed following another.
Apr 05, 2009 | Samsung Televison & Video
MODEL # HLN5065WX/XAA
Are you Technician ?
You should call Samsung. The problem is in the Digital printer circuit board where is the DVI input connector. It have a few of regulator 3,3V and surface mount ellectrolytics capacitors were leaked and when the unit get hot the regulator get lower then 3V that moment you get the pixel block on your screen
Depend your country and depend Technician if they can repair at component level or PCB level that mean they replace a complet board. In Australia it cost between $350 to $800. I hope that it give you some ideas
Cheers
Jan 15, 2009 | Samsung - Projection TV replacement lamp...
Samsung HD tv help
Is it a Plasma Television? I recently had a customer have the same issue with a 2 year old model Samsung 50" plasma TV. In his case one Of the computer panels failed. He didn't have a service plan and the warrenty was out, so i directed him to Samsungs help line. They inturn directed him to a authorized repair center. Repairs were roughly $800. Thats a possibility but it may not be the same as your issue. Try leaving your TV running for a little while when it has the issue, and see if it eventually goes away. Some older plasma models have started to require a warm up time for the pixel cells. This has been a down fall of plasma that for the most part no longer exists on newer models.
I hope eveything works out.
Have a great day
Mar 22, 2008 | Samsung LE40R72BDX 40 in. HD-Ready LCD...
Samsung LN-S4692D 46 in. LCD HDTV Logo
116 people viewed this question
Jerry Greenberg
Jerry Greenberg
