Washer will not agitate, after moving washer i noticed small pile of what looks like belt debris.
    Problem Solver:
  • 10 Answers
I had the same with my washer. Depends on the make and model but i found the parts guide on the internet (sorry cant remember where) but under the agitator there is a spline. The teeth were wore out and it was just slipping inside the agitator. wasnt that hard to change. belt debris was coming from a rusty pulley that had gotten sharp edges around it and the belt wasnt running right on it. not an expert but thats what was wrong with mine and i did fix it myself. hope this helps you
Posted on Sep 11, 2009
  • 5,911 Answers
If this is a Whirlpool manufactured washer (includes Kenmore, Estate, Kelvinator, Kitchenaid, Frigidaire), that small pile of debris could be an indication that your motor coupling has gone bad. If the washer will fill and drain, but won't agitate or spin, this is usually a sign that the motor coupling has broken. The black dust is an indication that the rubber bushing has sheared apart. The noise of the motor engaging, lack of agitation and ability to still drain are other common symptoms. This is a common fail item with this model washer through normal wear and tear. Newer versions of the coupler are more resilient and resist breaking. The following link explains how to replace one:
http://www.fixya.com/support/r385252-replacing_motor_coupling_whirlpool_top
The motor coupling is located between the drive motor and the transmission and takes the place of a drive belt. They do wear out and can break. The replacement part number is included in the link I provided and is an improved upgraded coupling that is more resilient. It should last longer. If you have questions, or require additional assistance, please let me know. I hope this helps you.
A replacement coupler can be purchased on line at appliancepartspros.com for about $11. Just use the part number in the link and "Search by Part Number" for your search criteria.
If you have questions about this repair, or if you require additional assistance, please let me know. I hope this helps you.
NOTE: If this is not a Whirlpool, or if you just don't know, post back with your model number (located along the wash tub rim under the lid), so that I may be able to provide you with better service.
  • Washing Mach... Master
  • 8,220 Answers
Take a look at these repair Photos
Maytag washer tub will not spin.
There is a clutch assembly under the tub that controls the tub and the agitator. It sounds like the problem is with that.
Jan 19, 2014 | Maytag Washing Machines
Washer makes grinding/loud sound and will not agitate-spins fine
Look under the washer. Is there a little pile of black rubber shavings? This sounds like the basket coupler between the motor and the drum. If the coupler is the problem it is inexpensive to fix. Some also call this part the "clutch". It kind of looks like a hockey puck with six holes in it... three for the motor, three for the clothes drum. In your case, I suspect that the holes are intact in the direction of spin, but as soon as it reverses for agitation, it breaks out through the back of the holes.
Jul 09, 2017 | Maytag Atlantis MAV6260AWW Top Load Washer
Machine not spinning dry
Top-loading washing machine has an outer tub that fills with water and sits stationary as well as an inner tub with holes in it. The inner tub has an agitator that attaches to the drive shaft. A drive belt turns the drive shaft, causing the agitator to move back and forth. Broken seals at the bottom of the agitator, or a broken belt, may cause the agitator to perform inefficiently and leave your clothes dirty
In order to properly wash clothes and prepare them for drying, a washer must agitate or spin the load. This helps wring excess water out of the clothing. If your washer has suddenly stopped spinning properly, you will notice that your clothes will be sopping wet when the washer is done. Typically, there is a simple reason for this problem that you can fix without calling in a professiona
1 Check the lid switch. You will notice on the lip of the lid there is a small stem that hangs down. This fits into a hole on the top of the washer housing and tells the washer the lid is closed and it is safe to spin the load. If the switch is faulty or has been blocked, the washer will not agitate or spin.
2 Clean out the switch receptacle. Use a multipurpose cleaner and a sponge (not a paper towel, it can shred and get caught in the switch receptacle.) Thoroughly clean the area around the switch and the receptacle.
3 Test the washer. Close the lid, allow the washer to fill with an inch of water, and move the selector to the spin cycle. Pull out on the selector. If it does not spin, stop the cycle (push the selector in) and turn the washing machine off. This means there could be three problems with the washer: the switch might be broken, something might be caught in the agitator, or the motor for the agitator may be burned out.
4 Check underneath the agitator. Small items such as underwear, panty hose or bra straps can become caught underneath the agitator and keep it from moving. Run your hand underneath this area and see if you feel anything. If you do, unwrap the item and test the washer again. If it still does not work, move to Step 5.
5 Contact a repair person. If the washer still will not agitate or spin, it will need to either have the switch replaced or the motor replaced. Contact a certified appliance repair person to have the machine inspected. If it is still under warranty, the repair person's visit should be covered.
However if its only the agitator arm, then
Instructions to Remove/replace the Agitator
1 Unplug the washer.
2 Slide a putty knife under each side of the washing machine top to release the springs holding the top in place. Lift up the top on its hinges.
3 Pull the tub clips from the inner tub using a pair of pliers.
4 Pull up on the agitator top to expose the nut holding it in place. Remove the nut using a socket wrench. Lift up on the agitator to remove it from the machine.
5 Turn the agitator upside down and remove the seals from the bottom. Replace them with a new set of seals. If the agitator is cracked, replace it.
6 Reassemble the washer.
Removing the Belt
7 Unplug the washer from the wall outlet.
8 Pull out on the bottom panel on the front of the machine. Look underneath to locate the drive belt.
9 Pull on the drive belt at the washer tub to remove it. Push down on the idler pulley near the motor to remove the belt from the machine. Route the new belt around the pulleys in the same way as before.
10 Reassemble the machine, plug it in and test.
Apr 20, 2012 | Whirlpool Washing Machines
After final spin all the clothes end up in a big pile. the washer has never done this before. please help.
Sounds like the agitator is not working (the post in the middle that oscillates opposite the basket while in the "wash" cycle). You'd have to take the back or bottom off the washer (after unplugging it!) and check the motor and belts/pulleys that go to the agitator.
Dec 19, 2010 | Frigidaire FWSB7800DS Top Load Washer
Mav39 fills, drains, wont agitate, makes loud riviting like noise instead of agitating. took off agitator and the mechinisim that would activate the agitator isn't moving, but making this loud noise....
There is a coupler if this is a direct drive machine. Tilt the unit back and look under for a pile of rubber shavings or a couple of broken plastic bits. The coupler is easy to change by removing the cabinet with the gold clips at the top. Then remove the clips from the pump and hold that out of the way. Remove the screws and clips from the motor after disconnecting the wiring harness. The coupler is on the shaft of the motor and the gearcase. Replace all three pieces...there are two hard plastic three fingered bits with a rubber isolator.
If you have a belt then it is very likely that you have a bad gearcase and you may consider a new machine for cost reasons. The coupler should be under $25.
Sep 18, 2010 | Maytag Dependable Clean Top Load Washer,...
Drum doesn't spin or agitate. Only drains. Timer works.
It doesn't spin If your washer won't spin, check these: It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows: If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt. If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it. It doesn't agitate If your washer doesn't agitate, check these: Lid switch If the lid switch is defective, the washing machine may not agitate or function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it. Motor coupler Many washers produced by Whirlpool® use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. If this happens, you need to completely replace it. Belts Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.) Clutch If your washer was made by GE®, it may use a clutch for agitating the clothes. As the clutch wears out, it may prevent the washer from agitating well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician. Drive motor Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor. Drive pulleys
Jan 02, 2010 | General Electric WJRR4170GWW Top Load...
Agitator not moving
Following are the main reasons for the agitator not to move.
Lid switch
Motor coupler
Belts
Agitator
The inside of the agitator--where the transmission shaft attaches--can become worn, and strip out the spline that allows the agitator to properly grip the shaft. Then the transmission shaft rotates back and forth as it should, but the agitator doesn't move properly. If this happens, you may need to replace the agitator and/or the transmission spline.
Thanks for contacting Fixya.
Oct 12, 2009 | Kenmore 22422 Top Load Washer
The agitator doesn't seem to agitate the clothes enough
Hi, Do you know if the lower half of the agitator is moving? Is this a two piece agitator? With the washer off, try and turn the upper half of the agitator. It should turn one direction and stop the other direction. If it turns both direstions, the agitator dog kit will need changed inn the agitator.
Please let me know if this helps you orif I can assist you further.
Vic
May 28, 2009 | Washing Machines
GE washer not agitating
when you pulled up agitator was the splined shaft moving back and forth ? If so replace the insert in the agitator. If not the problem is in the transmission .
Dec 11, 2008 | Washing Machines
Washing machine will not spin or agitate.
Lid switch
Motor coupler
Belts
Clutch
Drive motor
Drive pulleys
Transmission
Agitator
Drive pulleys The motor or transmission drive pulley may be worn and unable to turn the drive belt. If so, replace the pulley.
Transmission The transmission could have either of these problems:
  • Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may not agitate properly or at all.
  • The transmission may have a worn or broken gear, or some other internal problem.
If you suspect a transmission problem, you may have to call a qualified appliance repair technician to repair it.
Agitator The inside of the agitator--where the transmission shaft attaches--can become worn, and strip out the spline that allows the agitator to properly grip the shaft. Then the transmission shaft rotates back and forth as it should, but the agitator doesn't move properly. If this happens, you may need to replace the agitator and/or the transmission spline.
Nov 30, 2008 | Amana 3.2 cu. ft. Top-Load Washer
Washing Machines Logo
160 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
