Question about Jensen VM9510 Car DVD Player
How do I wire a brake controller for a bumper pull trailer with electric brakes on my 1994 chevrolet c1500 silverado pickup
  • 376 Answers
Well I havent seen a brake controller for a trailer that attaches to the bumper. usually if it attaches to the bumper, the weight is not that great that the vehicle cant stop it... follow me!
Posted on Sep 11, 2009
2009 Silverado 4x4 pickup with towing package and factory installed Trailer Brake controler installed at factory. The system has worked in past. I had my Stock trailer rewired and things tested out fine...
It sounds like you lost a ground.
check traier hookup first.
Probably not the controller.
P.S. There are multiple fuses for this setup. check all ! ! !
Aug 19, 2010 | 1999 Chevrolet Silverado 1500
Wiring 7 pin trailer plug for 1998 C1500 pickup truck Z71
Here is some information that I find useful when wiring trailer connectors, and the brake controller should be wired into the vehicles wiring according to the instructions that came with the brake controller and that identifies each wire from the brake controller.
Be sure that you solder all connections well for the best operation, and you should use 10 or 12 ga. wire for the Pos. (+) connection, and the ground or Neg. (-) connection, and you should run both wires all the way out to the battery, and about one foot from the battery on the Pos. (+) wire to the battery, make sure that you use a 20 or 30 amp Circuit Breaker and Do Not Use A Fuse.
The rest of these diagrams should help you to get your trailer properly wired up.
May 15, 2010 | 1999 Chevrolet Silverado 1500
1994 chevy truck 350...blowing fuse for brake lights.new brake switch..help
Canopy or trailer hitch? probably a wire shorting out. Check for places where the wiring harness goes around a corner or is on something sharp...
Feb 28, 2010 | 1994 Chevrolet C1500
Were do you hook up the two wires under the hood for trailer brakes on a 2000 silverado
Sometime around 2000, GM started putting trailering pre-wire harnesses in the vehicle. Your truck may have this harness built in and would greatly simplify brake controller installation. Look under the glovebox and see if there is a wire harness tied off. There will be four wires in this harness, which should be run over to the steering column to use it. Most trailer brake controllers are compatible with this harness.
The four wires in the harness are: Red, 12vdc; black, ground; blue or purple, brake pedal; and brown or white, trailer brake wire to seven pin, four pin, or five pin connector at trailer hitch, if your truck came from the factory with a trailer hitch.
If you are adding the hitch and do not have the four wire harness, the under hood wires from your brake controller are Red, connect to one of the studs under the distribution box cover (the distribution box is on the driver's side against the firewall. Underneath the cover are two large threaded studs which are hot from the battery all the time); and the other wire from your brake controller would have to be run the length of the truck along the frame, tied off in several places, to the trailer hitch connector on the bumper. Follow the directions that came with trailer hitch wiring connector to connect this wire to the proper pin in the connector.
If this has helped you, great, and please remember to vote/comment.
Feb 21, 2010 | 2000 Chevrolet Silverado 1500
Need a diagram or instructions to install a electric brake system
http://www.hayesbc.com/PDFs/SYNCRONIZER%20Installation%20and%20Operation%20Manual.pdf
Click on this site. This is the manual for you brake system. Looks like it might have the plug info in it also
Hope this helps
Aug 08, 2009 | 1999 Chevrolet Silverado 1500
Abs light and brake kight is on but no problem with tha ac
could possibly a issue with a wheel speed sensor, it will not effect regular braking but will disable abs
Jul 30, 2009 | 1996 Chevrolet S-10 Pickup
2001 chevy silverado brake lights stay on, when you push the brake pedal the brake lights go dim
It sounds like there is a wire shorted out or grounding through your brake lights, I would start by looking at the wires that lead to the trailer light plug by the rear bumper.
Jul 27, 2009 | 1999 Chevrolet K1500
Hooked my 2007 Sprinter camping trailer to the factory lights/brakes hook-up located below bumper of my 2005 Silverado 4x4 extended cab truck. Everything works fine except for the right trailer turn...
Is this a 4 way or 6 way connection system? If your truck is wrong, then all factory equipped trailer package harnesses would be wrong, tell your trailer guy...I don't think so.
Is this the first trailer you have hauled?
Let me know, and we will go from there.
REgards,
Mar 10, 2009 | 2005 Chevrolet Silverado
Jensen VM9510 Car DVD Player Logo
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
