Question about Singer 2638 Mechanical Sewing Machine
Sewing machine eruro pro 385W will not sew if it does pulls right out stitches don't lock. It is brand new
  • 140 Answers
SOURCE: threading problem on Singer Sewing machine Inspiration 4206
This can be caused by incorrect bobbin tension or the bobbin is in backwards. Take out the bobbin and put it in according to the instructions for your Singer. If you still have the same problem try tightening the bobbin tension. Please ask if you have any questions.
Posted on Dec 30, 2008
  • 110 Answers
SOURCE: My Futura CE-150 beeps and stops sewing after only a few stitches
Look for the buttonhole lever, just in front of the presserlever, on the lefthand side of the machine. Pull it down and push it back to the top. Good Luck
Posted on Jan 10, 2009
  • 202 Answers
SOURCE: backward stitching
Knowing which kind of machine you have helps alot. Just guessing but maybe the reverse mechanism is stuck and needs some oil in it to free it up. Or the buttonhole mechanism is stuck in reverse part of it.
Probably you should have it looked at.
Posted on Jan 11, 2009
SOURCE: singer simple sewing machine will not sew
need needle threading instructions singer 3116 simple. pictures would help. thank you
Posted on Mar 15, 2009
SOURCE: singer stylist sewing machine 534 is not stitching
Feed dog drive gear(2) are plastic and are probably stripped. Always replace them in pairs. While you are at it replace both hook drive gears as well. It will run as good as new.
Posted on Mar 28, 2009
  • 268 Answers
SOURCE: my sewing machine keeps getting jammed when
Here are a couple of things to try.
* Un-thread your machine and remove your bobbin. Clean any loose thread or lint out of your
bobbin case. Re-thread your machine, reinsert and re-thread your bobbin.
* Change your bobbin
There could be a nick along the edge of your bobbin spool that’s catching your thread as you
* When you start to sew a seam, grasp the upper and bobbin thread tails. Hold them back
and out of the way as you sew your first couple of stitches. This will keep them from getting
caught in your machine.
I hope this helps.
Posted on Sep 15, 2009
0 characters
1 Points
Upper and lower threads are not making stitches
Be sure to use a brand new needle.
If the threads are still not making stitches, it could be a sewing machine timing issue. You can search the internet "sewing machine timing" OR take it for service.
Oct 10, 2016 | Sewing Machines
My euro pro EP382 problem: needle goes down & then it locks up. When I free it there is an extra thread with the bobbib thread that comes up. What can I do to fix this?
Euro Pro Sewing Machine - YouTube
? 0:59
Jan 20, 2009 - Uploaded by simplysoldstore
Euro Pro Sewing Machine. ... on piece on top then runs downthe right side of long and around the bottom up ...
EURO-PRO 380 INSTRUCTION MANUAL Pdf Download. > ... > Euro-Pro Manuals > Sewing Machine > 380
Sewing Machine Euro-Pro Dressmaker 998B Owner's Manual ... take-up lever Palanca tensora de hilo Presser Foot Prensstela Needle plate ... Drop Feed Control / Control De Gota A. Push feed dog lever down to drop feed dog below needle plate for darning, embroidery and button sewing. .... This manual also for: Ep382 ...
Euro Pro Mechanical 30 Stitch Sewing Machine - Overstock ... > ... > Sewing Machines
Rating: 4.4 - ‎5 votes - ‎$119.99 - ‎Out of stock
Shop for Euro Pro Mechanical 30 Stitch Sewing Machine. ... I can sew in the middle of the night and not worry about waking anyone up, it is so quiet, and it sews ... Distinctive Even Feed Walking Sewing ...
Jan 05, 2016 | Sewing Machines
I have a brand new singer stitch sew quick machine, apparently the machine works, when i use a cloth to try stitching it does not make any stitches
Have you tried Alans Alterations at the MID WALES SEWING CENTRE they have a huge presence on ebay.They should be able to help you,or point you in the right direction.
Apr 03, 2014 | Singer Stitch Sew Quick Sewing Machine
Needle keeps breaking Model 150 Euro=Pro Sew Machine
broken needles can happen if you are pulling the fabric through rather thsn letting feed dogs move it, or if stitch setting needs a wide hole foot but you have straight stitch foot on. could also mean timing between needle and shuttle is out of sync.
or needle size is too small for weight of fabric you are sewing.
check out for needle size info and use new needle for each new project.
if yoy suspect timing out take to technician for fulk service.
Jun 16, 2011 | Euro-Pro Sewing Machines
My janome sewing machine isn't locking the thread
If u r new to using sewing machines please take some ones help who knows using any machine. You obviously are not fixing correctly. It should click in right place and the machine shd be able pull the thread before u begin stitching.
Oct 16, 2009 | Sewing Machines
Euro pro model 385W sewing machine
Hi FixYa,
I'm fifi1076, and I'm having quiet a good bit of trouble with my sewing machine.
I'm new at this site so I don't know if I'm doing this correctly or not so please
forgive me if I do something I'm not suppose to do!!!!
I copied this question from off of this site for I wanted to make certain that
whoever answers my question will understand that all of the question
doesn't pertain to my problem.
"when we have it threaded the top thread keeps getting jammed up in the bottom bobbin. if i redo the bobbin as shown in manual then the bottom thread will not loop so it will stitch"
This is the only part that pertains to my problem...... when I have it threaded the top thread keeps getting jammed up in the bottom bobbin......and I can't get it to sew at won't do nothing.....the motor will just sit there and grind.
If whoever can help me with this and can give me a solution I will be forever gratefull
Kay Nowicki
Aug 27, 2008 | Sewing Machines
Euro pro 385w problems
if your machine is like mine the bobbin is not filling right. My bobbin thread is very loose when it should be tight. I am also looking for bobbin solutions. If I wind the thread around the thread tension guide 2 or three times it keeps the thread tight going to the bobbin winder. I hope this helps
Jun 25, 2008 | Euro-Pro Easy Sewlution 385 Mechanical...
Singer 2638 Mechanical Sewing Machine Logo
Top Singer Sewing Machines Experts
Bargain Box
Bargain Box
Mike Cairns
Mike Cairns
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
