Question about Dishwashers
CLEANING LITE IS FLASHING OFF AND ON THE DISHER WON'T TURN ON.CAN'T GET THE TO TURN OFF
  • 5,911 Answers
This may help in your situation. The following link explains how you may be able to clear the blinking clean light problem:
http://www.fixya.com/support/r417123-blinking_clean_light_kenmore_whirlpool
Now...keep in mind all dish washers are not alike and have different panel options. If you do not have the same set up as I have referenced, the tech sheet for your dishwasher will explain. The tech sheet is located behind the lower toe panel under the door and lists the proper sequence of buttons to push for diagnostics and troubleshooting.
NOTE: Sometimes the tech sheet is located behind the inner door panel. You will need to remove the screws securing the inner panel to access it if this is the case. Make sure you turn off the main power breaker before doing so.
Sometimes this can be a momentary glitch in operation. However, if the problem keeps reoccuring the number of flashes is an indication of which circuit is causing your problem. Again, refer to your tech sheet to determine this.
If you have any questions, please let me know. I hope this helps you solve your problem.
Posted on Sep 11, 2009
The pilot got wet and it won't lite up ???
There could be water in the pilot line or pilot is blocked and needs cleaning out along with the pilot line .
Dec 24, 2012 | Heating & Cooling
Oven lite won't go off and when turn on self cleaning it says door
The door switch has gone bad. This will keep the oven light on and the self clean won't work because it thinks the door is open.
Dec 12, 2011 | KitchenAid KESC307 Electric Kitchen Range
Caution lite flashing over cartridge of hp deskjet 940c. error message says that there is not color ink cartridge in printer. There is and the interface says the tank is full. It won't print...
Even though the interface says the cartridge is full, if the printer detects it being empty, odds are you will have to replace the color cartridge, even though you are only printing black.
You can try taking the cartridge out and cleaning the contacts with a pencil eraser and reseat the color cartridge. If no change, replace the cartridge.
Jun 30, 2011 | Computers & Internet
Looking for reset code for whirlpool disher model #665.170.32401
If you have a flashing clean light then you can find the code and reasons why it is flashing at the link below, if something else is going on send a reply with details on what is happening.
http://www.fixya.com/support/r4628906-flashing_or_blinking_green_clean_light_7
May 11, 2010 | Whirlpool 24 in. GU3200XTP Built-in...
Standing water in botton of disher washer
It could be as easy as cleaning the screen in the bottom of your machine. Also it would be good to clean underneath while you have it apart. That should solve your problem.
Jan 08, 2010 | Frigidaire Dishwashers
My disher is not cleaning properly. It leaves
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
34taqg
Nov 27, 2009 | Bosch 24 in. SHX46A05UC Built-In...
Toshiba TV will not turn on
Try to have the TV unplugged over night. If that does not solve it you may have to have the TV power supply circuit inspected for leaking capacitors, loose solders or may be a bad IC.
Aug 29, 2009 | Toshiba 32A33 32" TV
Indesit dishwasher DI 450 stops after 10 mins
my disher washer dls 535 starts programme then lights 2 and 3 start flashing and does not work
Nov 19, 2008 | Indesit 18 in. D41 Slim-Line Free-standing...
Dishwasher will not fill with water
make sure you have the door lock on,also make sure there was not a knock ring on the disher washer side,did you remove the disher hose and check to see if hose is clear and disher hole is clear?let me know-mike
Jun 15, 2008 | Sears 24 in. 14181 Built-in Dishwasher
NOT CLEANING SILVER WARE OR DISHER PROPER
clean inside with a load of vinegar
Mar 18, 2008 | Washing Machines
Dishwashers Logo
53 people viewed this question
Top Dishwashers Experts
Owen Barnes
