Question about Sony Audio Players & Recorders
CD player drawer pops open
My carousel CD player, Sony CDP-C57, will not stay closed. With or without a disc the tray pops open after trying to load.
SOURCE: player reads no disc
make sure you are putting them in correctly
Posted on Jan 27, 2008
cdj repairs
  • 68 Answers
SOURCE: Sony CDP-CX53 rotates the carousel and inserts the CD into the playing position, but it won't play the CD
It sounds like there is a cd tray alignment problem, there is no quick fix, all i could suggest is to send it to us or take it to your nearest dealer.
Regards.
http://www.audiovisualservices.info/
Posted on Jan 02, 2009
RFICKES
  • 51 Answers
SOURCE: Onkyo 6 disc cd changer DX-380 has CD stuck under carousel
Find the screws that hold the to of the case to the chassis. They should be on the bottom, and back. Once they're removed, gently pull the top off. You may have to fish under the carousel to get the CD, but if you're gentle, you should be okay. Make DARN sure the power's unplugged, and keep your tools away from the power supply, just in case there's some residual energy left. Good luck!
Posted on Jan 04, 2009
JULIANFIX
  • 975 Answers
SOURCE: sony model # CDP-CE415 Tray alignment off when closed
Your goin to need to re align the tray , your gonna need the service manual for this purpose. Go to this link :
http://www.nodevice.in/manual/Sony/page15.html ,hope this helps you, AJ
Posted on May 07, 2009
MNfisherman
  • 11896 Answers
SOURCE: Problem with my Onkyo DX-C380
Try cleaning the glass laser eye lens with rubbing alcohol and a cotton swab. If cleaning doesn't work, you may want to change or laser eyee unit.
Posted on Sep 14, 2009
How do I fix my Sony cd player with 5 disc carousel changer in which the door keeps opening up? When I close the door the carousel moves around a bit but then the door opens up again.
How to fix a CD player drawer problem - #1 - YouTube
? 9:21
https://www.youtube.com/watch?v=FngAg3mk2Ug
Apr 27, 2008 - Uploaded by Eric Barr
I have a Sony mini hifi stereo(pixy) and when ever I close the tray it continues to ... my cd player drawer opens ...
ToddFun.com: Repairing a 5 disk CD player - YouTube
? 10:09
https://www.youtube.com/watch?v=aKE1CbHOBVo
Nov 23, 2011 - Uploaded by Todd Harrison
ToddFun.com: Repairing a 5 disk CD player ... Sony CDP-CX300 300 Disc Changer Belt Repair and ...
Jan 01, 2016 | Sony Audio Players & Recorders
Tray will not open
It sounds like the CD is not in the correct location. Tap it gently in several directions, try this several times it may solve the problem. I think you will have to open it up and align the tray assembly and remove the offending CD.
Oct 30, 2015 | Sony 5 Disc Cd Player Carousel Cdp-c615
The disk tray will not open, and after a brief time the word ERROR appears in the display window. Is there some power on button combinations to reset the processor?
The fault is with its disc loading mechanism. Contact any service technician. Disk is not loading properly into the system. A loose loading belt, or a broken gear wheel can be the cause.
Jul 31, 2015 | Sony CDP-CE375 5-Disc Carousel-Style CD...
Have Sony cdp-c535 cd player. The door won't stay in. Keeps cycling in and out.
I had the same problem with our 5-CD Sony carousel player CDP-C535 (manufactured Nov 1993). I removed the top metal cover, and loaded five audio CDs into the carousel. After I closed the table, I pressed the carousel tight so that it stayed close, and hit the play button. The CD player tried to push the carousel out with quite a force. I needed to warp me fingers around the front panel to keep the carousel closed. After a few cycles of forcing the carousel to remain close, and caused two separate strong "clucks" from the gear area, the CD carousel became operational again. The diagnosis of gear problem seems right.
Nov 28, 2009 | Sony Audio Players & Recorders
Broken carouself? Can't properly open, close, rotate, etc.
Broken gears. The current replacement 5 disc is a CD/DVD player and sells for $129.00 at Sony or any other Sony retailer. The cost to have a service center even estimate the repair would be more than 50% of the replacement cost. Hope this helps
Nov 19, 2009 | Sony CDP-C265 CD Player
Jammed tray
Hi there, had a similar problem.
This unit is easy to open. the four screws on the sides and two i think on the back. When it is open you will have access to the discs in the machine. the last disc will probably be jammed between the facia and the caddy and will be impeding the carousel mechanism, once removed you should check the functions starting with eject, and again to cycle, load disc position 1 insert disc and check. this player i think rotated the disc on loading to a set position, would have to open one to check. hopefully the carousel is not out of sync and all is well.
May 01, 2009 | Sony CDP-C265 CD Player
This has just happened to us. Often when the changer tries to select a CD on random play, it somehow knocks one CD off the carousel, usually on top of the other 5 CDs and then you can retrieve it easily. This time it knocked it down behind the carousel so the drawer could not close. We left the drawer open, carefully took the player out and tipped it upside down and then tipped it forward. We then closed the drawer while it was still upside down and then turned the player back up the right way. The loose CD fell onto the carousel and we could then open it and retrieve the CD. No damage to either CD or changer and we are now listening to music again!
Jan 04, 2009 | Onkyo DX-C380 6-Disc CD Changer
Regards.
Dec 27, 2008 | Sony CDP-CX53 51-Disc CD Changer
CANNOT OPEN PLAYER
To open the drawer, unplug the unit while the power is on (so that the drawer doesn't try to open on its own). Keeping the unit flat on a table, look underneath and find the small hole where you can turn the loading gear. Rotate it until the unit opens, using a standard flat screwdriver. The loading gear is a white plastic part with a slot in it. You should be able to see it rotate if you move the drawer by hand.
After manually removing the disc, turn the gear with your screwdriver until the drawer is all the way in, The gear should be able to be turned for three or four more turns when the drawer stops loading. If it doesn't, turn it a bit further unit it "pops" past one more gear notch. It should then turn freely for a few more turns, at this point you should stop. Do not force it once it stops the second time. This is the "Disc Loaded" position.
Power the unit back up and see if it loads a disc and plays correctly.
Dec 18, 2008 | Sony CDP-C445 5-Disc CD Changer
42 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
