Question about Lexmark X4650 InkJet Printer
Won't Print x4650
It won't print. I press print on my computer and it says it has an error. No explanation
Lexmark x4650 wont print got black ink but colour is empty would this stop it from printing
Posted on Nov 07, 2010
    Novelist:
  • 85 Answers
Hi
Here are a few possibilities...
1. Try cleaning the contacts on the inkjet cartridge and where they make contact inside the printer. (use cotton wool and Alchol) if that does not work...
2. Pull out power cable from printer wait 1 MINUTE then insert cable and switch back on again. (some printers reset to factory settings)
3. Remove printer cable from computer... Uninstall Printer driver from computer... Switch off both printer and computer. Wait 1 minute... Reconnect cables and switch on printer and computer... Allow computer to find printer reinstall driver.
4. Try installing old cartridge to see if printer rejects that?
5. You may have a faulty inkjet cartridge (return it to store if so)
You may find more help here...
How to Clean, Fix, Repair, Unclog, Dry, Clogged Print Heads on CANON, EPSON, HP, Lexmark, Dell, Olivetti etc…
Good Luck!
Tinteiros Magic Inkjet Flush Kits (Ebay)
Posted on Sep 12, 2009
Paper aligns but nothing will print on Lexmark x4650
Are you getting any error msgs when you try to print? It's possible that you have a communication problem. Make sure that your computer and printer is able to talk.
Since no details were provided, you can try to uninstall the Lexmark software and download an updated driver online at www.lexmark.com.
Apr 20, 2012 | Lexmark X4650 InkJet Printer
My office jet G85 won't print. No error messages appear,it has a new color cartridge,it copies, but won't print from my computer.
If it copies ok, then the issue is either the way it is cabled to computer or the print driver software settings on pc.... How is it connected via USB? Check port and correct driver is in windows/control panel/printers. Reinstall.
Nov 30, 2011 | HP OfficeJet G85 All-In-One InkJet Printer
As soon as I press print on my computer the error light on the printer goes on and it won't print
Hello:
First try uninstalling the printer drivers in windows, and check for driver updates on your manufactures website. Reinstall the drivers and software and try printing again, If problem persists then you may have a hareware issue in the printer or comm problem.
Sep 09, 2011 | Brother HL 2140 Laser Printer
Lexmark X4650 prints fine & used to scan to computer, now when press scan>scan to computer>downloading application list & seems to freeze.
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
If that doesn't help, try the steps below:
1. Disconnect the printer from your computer.
2. Rebrick (pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds).
2. On your computer, go to Control Panel > Printers and Faxes.
3. Delete the Lexmark print object.
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list again, then try to print again.
Aug 31, 2011 | Lexmark X4650 InkJet Printer
When I try to print I get an error and it won't print. The error message never shows up so I don't know what the error is. I have removed and reinstalled this printer 6 times now. I have rebooted...
Sounds to me like a bad USB cable,
Also when you're re-installing the printer are you using new/different drivers?
I would try a new cable and the latest drivers direct from Lexmark.com
Jun 01, 2011 | Lexmark X4650 InkJet Printer
How do i change my lexmark x4650 print cartrige?
Installing/Replacing your ink cartridges:
1. Open the printer, and then press down on the cartridge carrier levers. printmastert_52.jpg
2. Remove the used print cartridge or cartridges. 3. If you are installing new print cartridges, remove the tape from the back and bottom of the color cartridge, insert the cartridge in the right carrier, and then close the color cartridge carrier lid. 4. If a black cartridge is included in the box contents, remove the tape from the back and bottom of the black cartridge, insert the cartridge in the left carrier, and then close the black cartridge carrier lid. 5. Close the printer.
Sometimes the ink cartridge carrier won't automatically move to its loading position even when the printer is on and the cover is open. Follow the steps below:
1. Unplug the printer from the power source.
2. With the cover open, hold the solid white strip that connects from the carrier assembly to the ink cartridge carrier and gently slide the cartridge carrier to the center of the printer.
3. Remove the used cartridges.
4. Load the new cartridges. Close the cover.
5. Plug the printer back to the power source.
May 15, 2011 | Lexmark X4650 InkJet Printer
Keeps pausing job won't print. also won't scan... "can't load application" scans only to flashdrive.
Your firewall could be blocking some printer communications. Make sure to allow full access to all Lexmark and printer communications in the program rules/permissions for your firewall. For more information on how to configure the settings for your firewall, visit the Lexmark website at http://bit.ly/iNwkNs.
May 14, 2011 | Lexmark X4650 InkJet Printer
When trying to print the paper won't feed through. It will on the left side (looking at the front of the printer) but won't on the right preventing it to print. I just bought and replaced both...
There could be something blocking the paper path. Remove the sheets of paper from the feeder. Grab a flashlight and look into the feeder. Make sure there are foreign objects or debris that could cause this problem.
May 13, 2011 | Lexmark X4650 InkJet Printer
Lexmark X4650
Here is how to align your print cartridges
Using the printer control panel:
1 Load plain Letter-size paper.
2 From the printer control panel, press tools , and then press ok.
3 Press the arrow buttons until Align Cartridges appears, and then press ok. An alignment page prints.
Using Windows
2 Do one of the following:
• In Windows Vista, click the windows globe (start button) .
• In Windows XP and earlier, click Start.
3 Click All Programs or Programs, and then select the printer program folder from the list.
4 From the printer folder, click Maintenance Align Cartridges.
5 Click Print.
6 Follow the instructions on the computer screen.
Using Macintosh
2 From the Finder desktop, double-click the printer folder.
3 Double-click the printer utility icon.
4 From the Maintenance tab, click Print Alignment Page.
5 Follow the instructions on the computer screen.
If you aligned the cartridges to improve print
Mar 28, 2009 | Lexmark X4650 InkJet Printer
Lexmark Z55
does an error message appear on the computer screen?
Jul 03, 2008 | Lexmark JetPrinter Z55 InkJet
Lexmark X4650 InkJet Printer Logo
501 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
