Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
Red blue and green lines on top on phillips hdtv. What can I do to fix it.
    Top Expert:
  • Philips Master
  • 14,553 Answers
1.) This sounds like a convergence problem--with the original remote go into the customer menu and select convergence--see if red or blue will not move in some direction.
2.) If some color (red or blue) will not move in some direction--you need to replace both of the STK-392-120 CONVERGENCE IC'S THAT THIS SET USES along with any of the green 6.8 ohm resistors around them that are discolored(bad).
3.) With the back cover removed the chips are on the left large board on two metal heat sinks with fins--they are black and about 2 1/2 inches wide and 1 1/2 inches tall and the STK-392-120 is printed on the face of them in white. The resistors are in front of the one near to the front of the circuit board and left to right around several plugs there(convergence yokes).
4.) You can buy both chips on Ebay for about 13 dollars plus shipping; If you are able to do this repair you can save a lot of money---after the chips and or resistors are replaced you need to go into the Convergence Tech mode(I can tell you how to access it) and adjust the convergence in first the regular non Hd and then in the Hd.
5.) Most shops TRY to charge 300-400 for this kind of repair--I have done hundreds of them here for 200-250.
6.) If you are not able to do this repair shop around your area for someone who can do it---if a shop says "It has to go to the shop" keep looking----any good tech can do this repair in your home in about 1 hour.
7.) If you have any questions or need advice reply to this posting.
I do this here for free so if this information has been helpful please take a minute and give me a vote here-----I am here to help people.
Regards, SD TECH
Posted on Sep 11, 2009
Philips 55P8288A tv has a dull color and a red hue.
This sounds Like the the coolant for your piture tube has become cloudy and needs replacement (usually blue or green tube - thats why the image seems ovrely red).It's a big job (labour wise) since completee dissassembly is required ($200-300). It can be done youreself - check out TVrepairkits.com to get the coolant and instructions.
You can confirm that this is the problem by dissassembling the unit to the point where you can view the face of the CRT's (red green and blue) directly.
Nov 28, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Letters and numbers are 3d and curved picture
Hello
red, green, and blue lines curve across the top of tv is cause by defective convergence STK IC or you have open resistor at convergence section. if you have defective RGB Color vertical ramp probably you have defective STK IC..
Angel
Thanks...
Aug 02, 2009 | RCA D52W23 52" HDTV CRT TV
Picture stretching with Red, Green, and Blue Image Overlays
assuming that you have adjusted the convergence and this had no effect. you might have some blown convergence chips and/or resistors. these make the 3 color line up with each other.. my 55 in phillips did the same thing and the more i used it the worst it got. first it was the blue and the red and finally the green., replaced chips and resistors and the problem went away... good luck.. a lot of soldering involved. but the chips are only like 11.00 each and the resistors are like ten for all three.
May 30, 2009 | Sony KP-43HT20 43" Rear Projection...
Converging green?
jaymz, you can`t move the green, the green tube is always mounted in the middle and is not adjustable from the convergence menu. red & blue should be converged one at a time on top of the green, once you have accomplished this the crosshatch grid will be white and that means your done :)
Nov 30, 2007 | Philips 43PP9202 43" Rear Projection...
Blue Color spots on all pictures
Call a technician, sounds like an Integrated Circuit problem and would cost you about $250.
May 07, 2007 | Philips 60PP9202 60" Rear Projection...
Convergence not lining up
Sounds like the green is out of focus. If the focus control for the green does not control it enough to make the width the same as the red, then, the lens on top of the green can be adjusted to focus that tube. On the lens, there is a wing nut on a screw to loosen it and move the lens left or right a bit to help with the focus. Hope this helps.
Apr 15, 2007 | Mitsubishi WS-65315 65" Rear Projection...
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
144 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
