Question about Air Tools & Compressors
Wiring diagram for single phase two pole 2.5 HP induction motor.
Wiring diagram for single phase, two pole 2.5 HP induction electric motor to run anti-clockwise at shaft end. Has reset button and two capacitors. This unit is on a twin compressor and wiring has been interfered with. Can you give me a visual diagram please?.
  • Lunatic_75 May 11, 2010
    Read the numbers off the leads, what are they? is the motor 230/115? I would also take the belts off till you get your rotation right so you don't ruin the pump
  • Anonymous Mar 17, 2014
    Need wireing diagram in the pecker head of a dayton 3 horse modle #6k145m single phase 230 v
There are two windig in the motor starting and running the two winding end are joint and take nutral and other two wire connect to capacitor paralel and take one lead starting winding and give supply
Posted on Sep 09, 2013
  • 41 Answers
All you have to do is (a) open the connection box of the motor look for the two wires of the starting or running coil, inverse only one coil wire.(a) If there is no centrifugal switch in the rotor, try this it might help open the motor both end,change the direction of the shaft ,which i mean pulley side goes to fan side and fan side goes to pulley side and tighten all bolts.
Posted on Sep 27, 2009
I NEED TO REWIRE A DOERR LR24684 ELECTRIC MOTOR,ITS 1/2 HP, RPM 1725 115 volts to a metal lathe AND ON SWITCH IT'S WRITE- FOR IN DOWN IN CENTER STOP AND UP REV -I SEARCH TO CONNECT THIS...
Motor terminal box sometimes has a connection diagram inside the lid.
Basically a single phase induction motor has a run winding and a start winding and to reverse the direction the connections to one winding, usually the start winding, must be reversed and that is the function of the lathe switch.
Single phase motors are easily damaged and so if any doubt exists I strongly suggest you ask a motor specialist for assisstance.
Oct 09, 2017 | Cars & Trucks
Century single phase 2 hp 3450 rpm type cs motor Frame f56
the motor is on 220 volts ,i like hook that up on 120 volts ,,thanks
May 10, 2012 | Air Tools & Compressors
Taking my P660 out out a building with 3 phase power and into one with only single phase. Converter says motor will run on 2/3 power. Good or bad idea????
Good!
MOTOR:
21?2 H.P., Hobart designed, high torque ball bearing,
ventilated within mixer enclosure. Single-phase is
capacitor-start, induction-run type.
Three-phase is
polyphase squirrel cage, induction-run type.
Single Phase 208V 20.0 Amps
240V 17.0 Amps
Three Phase 208-240V 8.6 Amps
Nov 26, 2010 | Hobart P660 Stand Mixer
How do I wire a three phase electric motor to 110 plug
You can't run a 3-phase motor on 110V unless you use a 3-phase inverter. Depending on the size of your motor, these will probably run you around $150 for the least expensive type. Take a look at--- http://americanrotary.com/static-phase-converters.html
Jul 24, 2010 | Electric 1HP Century Single Phase Extra...
Need a wiring diagram for 5kcp39fg general electric motor
if it has a brown/purple,and black wires and is a single phase motor, the purple and black are your 2 hot phase wires, and the brown goes to the motor capacitor and on other motor cap term that goes back to the purple phase wire
Sep 26, 2009 | Heating & Cooling
I wish to rewire a single phase electric motor with compositor's that is currently setup for 230 VAC to 115 VAC. The motor is a Ingersoll-Rand Air Compressor motor with the following nomenclacher. Single...
The motor itself should have a sticker which describes the wiring for 115. It is a small change involving a single wire moving from one pole to another inside the motor starter cap (the bump on the motor itself).
Aug 26, 2009 | Air Tools & Compressors
Carrier multi hi wall split a/c
I don't have a diagram, but maybe I can help you. You have 2 compressors, o.k. 2 stage system. A single phase contactor? do you mean a single pole, one side breaks, the other is always hot? Speaking of phases, is this a commercial unit with 3 phase? Also, Each compressor needs a separate contactor to carry the load. What is the question?
Dec 22, 2007 | Carrier 38CKC036 Air Conditioner
Air Tools & Compressors Logo
3,693 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
