Question about Microsoft Wireless IntelliMouse Explorer
Program mouse I need to program a mouse to hold the control key down while selecting multiple files. I am handicapped and need to do this with one hand.
    Brigadier General:
  • 10,406 Answers
Hit the LEFT-side SHIFT-key at least 5 times.
This turns on "STICKY-KEYS" within Windows,
such that touching the CTRL key "sticks" it on,
so that you can use the mouse to select items,
and then touch CTRL once more to "unstick" it.
Posted on Sep 11, 2009
How do I delete large numbers of pictures at one time
Method #1 Click and drag.
Click and hold the left mouse button and drag the box around all the pictures you want to delete. This will select any it covers. Right click and click Delete.
Method #2 Shift select
Click on first picture you want to delete, hold down shift, click on last picture you want to delete. This will select any between them. You can also hold shift and press the down arrow to select them one at a time. Then right click and click Delete.
Method #3 Ctrl click
Use this if you only want to delete certain pictures, as you have more control. Select first picture you want to delete, then hold down Ctrl. While holding Ctrl continue to click pictures you want to delete. It will select them as you click them. In this way you can select many non-sequential files. Again, once you have them selected, right click and delete.
***These methods work to select multiple files, so can also be used to move or copy multiple files as well. It's easy one you've done it a time or two.
Mar 26, 2015 | Toshiba Computers & Internet
Tip
Windows xp keyboard tips
and also
and
Windows system key combinations
  • F1: Help
  • CTRL+ESC: Open Start menu
  • ALT+TAB: Switch between open programs
  • ALT+F4: Quit program
  • SHIFT+DELETE: Delete item permanently
  • Windows Logo+L: Lock the computer (without using CTRL+ALT+DELETE)
Windows program key combinations
  • CTRL+C: Copy
  • CTRL+X: Cut
  • CTRL+V: Paste
  • CTRL+Z: Undo
  • CTRL+B: Bold
  • CTRL+U: Underline
  • CTRL+I: Italic
Mouse click/keyboard modifier combinations for shell objects
  • SHIFT+right click: Displays a shortcut menu containing alternative commands
  • SHIFT+double click: Runs the alternate default command (the second item on the menu)
  • ALT+double click: Displays properties
  • SHIFT+DELETE: Deletes an item immediately without placing it in the Recycle Bin
General keyboard-only commands
  • F1: Starts Windows Help
  • F10: Activates menu bar options
  • SHIFT+F10 Opens a shortcut menu for the selected item (this is the same as right-clicking an object
  • CTRL+ESC: Opens the Start menu (use the ARROW keys to select an item)
  • CTRL+ESC or ESC: Selects the Start button (press TAB to select the taskbar, or press SHIFT+F10 for a context menu)
  • CTRL+SHIFT+ESC: Opens Windows Task Manager
  • ALT+DOWN ARROW: Opens a drop-down list box
  • ALT+TAB: Switch to another running program (hold down the ALT key and then press the TAB key to view the task-switching window)
  • SHIFT: Press and hold down the SHIFT key while you insert a CD-ROM to bypass the automatic-run feature
  • ALT+SPACE: Displays the main window's System menu (from the System menu, you can restore, move, resize, minimize, maximize, or close the window)
  • ALT+- (ALT+hyphen): Displays the Multiple Document Interface (MDI) child window's System menu (from the MDI child window's System menu, you can restore, move, resize, minimize, maximize, or close the child window)
  • CTRL+TAB: Switch to the next child window of a Multiple Document Interface (MDI) program
  • ALT+underlined letter in menu: Opens the menu
  • ALT+F4: Closes the current window
  • CTRL+F4: Closes the current Multiple Document Interface (MDI) window
  • ALT+F6: Switch between multiple windows in the same program (for example, when the Notepad Find dialog box is displayed, ALT+F6 switches between the Find dialog box and the main Notepad window)
Shell objects and general folder/Windows Explorer shortcuts
For a selected object:
  • F2: Rename object
  • F3: Find all files
  • CTRL+X: Cut
  • CTRL+C: Copy
  • CTRL+V: Paste
  • SHIFT+DELETE: Delete selection immediately, without moving the item to the Recycle Bin
  • ALT+ENTER: Open the properties for the selected object
To copy a file
Press and hold down the CTRL key while you drag the file to another folder.
To create a shortcut
Press and hold down CTRL+SHIFT while you drag a file to the desktop or a folder.
General folder/shortcut control
  • F4: Selects the Go To A Different Folder box and moves down the entries in the box (if the toolbar is active in Windows Explorer)
  • F5: Refreshes the current window.
  • F6: Moves among panes in Windows Explorer
  • CTRL+G: Opens the Go To Folder tool (in Windows 95 Windows Explorer only)
  • CTRL+Z: Undo the last command
  • CTRL+A: Select all the items in the current window
  • BACKSPACE: Switch to the parent folder
  • SHIFT+click+Close button: For folders, close the current folder plus all parent folders
Windows Explorer tree control
  • Numeric Keypad *: Expands everything under the current selection
  • Numeric Keypad +: Expands the current selection
  • Numeric Keypad -: Collapses the current selection.
  • RIGHT ARROW: Expands the current selection if it is not expanded, otherwise goes to the first child
  • LEFT ARROW: Collapses the current selection if it is expanded, otherwise goes to the parent
Properties control
  • CTRL+TAB/CTRL+SHIFT+TAB: Move through the property tabs
Accessibility shortcuts
  • Press SHIFT five times: Toggles StickyKeys on and off
  • Press down and hold the right SHIFT key for eight seconds: Toggles FilterKeys on and off
  • Press down and hold the NUM LOCK key for five seconds: Toggles ToggleKeys on and off
  • Left ALT+left SHIFT+NUM LOCK: Toggles MouseKeys on and off
  • Left ALT+left SHIFT+PRINT SCREEN: Toggles high contrast on and off
Microsoft Natural Keyboard keys
  • Windows Logo: Start menu
  • Windows Logo+R: Run dialog box
  • Windows Logo+M: Minimize all
  • SHIFT+Windows Logo+M: Undo minimize all
  • Windows Logo+F1: Help
  • Windows Logo+E: Windows Explorer
  • Windows Logo+F: Find files or folders
  • Windows Logo+D: Minimizes all open windows and displays the desktop
  • CTRL+Windows Logo+F: Find computer
  • CTRL+Windows Logo+TAB: Moves focus from Start, to the Quick Launch toolbar, to the system tray (use RIGHT ARROW or LEFT ARROW to move focus to items on the Quick Launch toolbar and the system tray)
  • Windows Logo+TAB: Cycle through taskbar buttons
  • Windows Logo+Break: System Properties dialog box
  • Application key: Displays a shortcut menu for the selected item
Microsoft Natural Keyboard with IntelliType software installed
  • Windows Logo+L: Log off Windows
  • Windows Logo+P: Starts Print Manager
  • Windows Logo+C: Opens Control Panel
  • Windows Logo+V: Starts Clipboard
  • Windows Logo+K: Opens Keyboard Properties dialog box
  • Windows Logo+I: Opens Mouse Properties dialog box
  • Windows Logo+A: Starts Accessibility Options (if installed)
  • Windows Logo+SPACEBAR: Displays the list of Microsoft IntelliType shortcut keys
  • Windows Logo+S: Toggles CAPS LOCK on and off
Dialog box keyboard commands
  • TAB: Move to the next control in the dialog box
  • SHIFT+TAB: Move to the previous control in the dialog box
  • SPACEBAR: If the current control is a button, this clicks the button. If the current control is a check box, this toggles the check box. If the current control is an option, this selects the option.
  • ENTER: Equivalent to clicking the selected button (the button with the outline)
  • ESC: Equivalent to clicking the Cancel button
  • ALT+underlined letter in dialog box item: Move to the corresponding item
reference: http://support.microsoft.com/kb/126449
on Nov 12, 2014 | Microsoft Windows XP Professional With...
Tip
Computer mouse tips
Using the mouse in combination with the keys on your keyboard can give you several different advantages and help improve your overall productivity on the computer. Below are just a few examples.
Almost all text editors
Many text editors or programs that allow you to edit text support the ability to quickly highlight all or portions of text by using the Shift key and the mouse. For example, move the cursor to the beginning of the text you wish to highlight, hold down the shift key, and click at the end of the text you wish to highlight. If supported and done properly this will highlight all text in-between the points you clicked.
Microsoft Word
In Microsoft Word holding down the ALT key on your keyboard while clicking and dragging your mouse and you will be able to drag a box and highlight only portions of text and not the whole line.
Windows Explorer and many other file
Microsoft Windows Explorer and other file managing programs allow users to select multiple files by holding down the CTRL key and clicking each file or folder they wish to select or hold down the shift key and selecting multiple files at once.
Microsoft Internet Explorer, Mozilla Firefox, and other browsers
Users who visit a website with tables and wish to only select one row of that table can hold down the CTRL key and click and drag on the text in the row they wish to copy.
Mozilla Firefox users
Mozilla Firefox users can also hold down the CTRL key and individually click on each cell they wish to copy.
on Sep 03, 2010 | Computers & Internet
How do i delete multiple messages at one time?
I assume the multiple messages you refer to are email messages.
If so, you can delete multiple messages as follows:
1. For messages listed one above the other in a row, use you mouse to select the first message so that is is highlighted. Then hold down your shift key and select the last message in your continuous list of messages. All the messages from the first to the last should now be highlighted (i.e., selected). While in this mode with the messages highlighted, press the delete key on your keyboard, or alternately, use your mouse and select the delete icon at the top of the email screen (it looks like a trash can).
You can also just drag the selected emails while holding the shift key down into your system trash.
2. For multiple messages that are not in a continuous list, while holding down the option key, use your mouse to highlight each message by clicking on it. When all the messages you wish to delete are selected, as above, press the delete key on your keyboard or use you mouse to select the delete button at the top of the email screen.
These instructions are for when you are using the apple mail program. It will likely work with other mail programs.
Sep 30, 2014 | Apple Mac/iMac&iPod Speakers-(Bondie-Blue)...
How to copy and paste
left click once on what you want to copy one item
hold down the left mouse button and move the mouse over the desired text you wish to select to copy and then let go of the left mouse button
so it is highlighted and then
hold down CTRL key and press C to copy
Hold down CTRL key and press V to Paste
Assuming it is a windows system
If it is apple the apple key and C I think does copy
Any edit tab option on the program usually has copy and paste
You can also use in Windows the right mouse button to bring up a menu where copy and paste are options to select.
If you are copying files you can also use CTRL A for select All
CTRL to select more than one item
Shift to select a range of items
if Windows
If you are using ubuntu the shift key plus CTRL plus V must also be used when pasting into the terminal window.
Aug 03, 2014 | Computers & Internet
How do i delete pictures and files from my pc
Just select the ones you want to delete with your mouse. You can hold down the shift key and click on the end file in the list to select a whole list of files to delete. You can also hold the control key down while you click on random files in the list to select a bunch of files to delete as well.
Jun 30, 2012 | Dell Studio XPS 1640 Laptop
How can I delete empty folders (multiple) quickly and free?
Click on the main folder where you want to delete the sub folders.
Hold down the Ctrl key and move the mouse pointer over the folder you want to delete and select it by clicking on the left mouse button.
Continue holding down the Ctrl key and move the mouse pointer to the next folder your want to delets and click the left mouse button.
Repeat this to select all the folders your want to delete
These folders will be highlighted. If you selected the wrong folder just click it again with the left mouse button whilst holding down the Ctrl key..
When you are ready to delete the folders take your finger off the Ctrl key and then press the Delete key.
After deleting the folders and you have changed your mind then click on the Recycle Bin, you can then click on the folder you want to restore then click File - Restore.
Apr 14, 2012 | Acer Aspire One D255 Netbook
How do i get rid of unwanted files
Removing the files mostly depends on the source of the files.
If you ware wanting to remove a PROGRAM that is installed on the system but you don't use, then you go to CONTROL PANEL, add/remove programs (IN VISTA, PROGRAMS AND FEATURES) select the program to remove, and click uninstall. Repeat for all unwanted applications. Some programs may not be listed in control panel, those usually have an uninstall application in the folder of the program in the Programs Menu (Click Start Programs [all programs] then application folder, then the uninstall link.)
If you ware wanting to remove DATA Files (Music, photos, documents you wrote etc.) then right click the start button, click in the folder tree to find the file(s) you want to delete and right click the file, click DELETE. You can select multiple files by holding hte CNTL key and clicking multiple files.
Jun 21, 2008 | Computers & Internet
How to delete multiple things off my acer laptop at the same time
A good place to start is...
Start>Run>Control Panel>Add/Remove Programs
You can uninstall lots of programs here.
If you are trying to delete, lets say a bunch of files at once, here are some useful shortcuts.
Ctrl+Click will highlight everything you click on then you can hit delete once.
Click one item then Hold Shift+Click to select all files inbetween your first and last click.
Drag a box with the left mouse button to highlight multiple icons/files then hit delete.
Apr 23, 2008 | Computers & Internet
Microsoft Wireless IntelliMouse Explorer Logo
96 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
