Question about GE Refrigerators
The compressor is not running and there is a clicking noise coming from the circuit board panel on the back of the refridgerator
  • GE Master
  • 1,606 Answers
You have to replace the main control board . The clicking is the compressor board relay , which the only repair , is to replace the main board .
Posted on Sep 12, 2009
Why does 15 amp 250 volt fuse in my lg refridgerator keep blowing
the 15 amp fuse is blowing because the current draw to run the compressor exceeds 15 amps
that problem could be from a failed start/ run capacitor or a failed compressor motor (I am betting on the capacitor)
the best answer is to get a fridge technician to check it out as the capacitor is a cheap fix while the compressor unit is as costly as a new fridge
Jun 25, 2015 | LG Refrigerators
Refrigerator wont run. Clicking noise coming from main board preceded by a short humming noise every several seconds. Unplug for 30 minutes then plug back in and compressor starts up after several clicks...
That condenser fan motor needs to be replaced. You and doing the right thing as far as using a seperate fan to keep compressor cool,buy replacing the fan the compressor will run cooler and click off by being too hot as you have heard/seen.
Find your model number and call your local appliance parts store and see if they have a CONDERSER FAN MOTOR in stock
Gene
Aug 15, 2011 | Refrigerators
Loud clicking noise in the back panel, took off the three screws and metal panel and clicking is louder, also the fan on the bottom of the refridgerator stops and starts with the clicking of the i would...
The compressor is not starting...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then checkout the last two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Sep 27, 2010 | GE GSS25SGMBS Side by Side Refrigerator
Clicking noise coming from refrigerator
If the "clicking" noise is from a relay on the board or compressor, it's likely th compressor would be cycling on and off.
It could be a fan blade (evaporator or condenser) hitting something. Both fans only run when the compressor is on. This should be addressed ASAP as it could be a wire it's rubbing on.
Finally, the noise could be caused by the refrigerant within the sealed refrigeration system. This noise is more of a nuisance rather than a mechanical failure.
Apr 27, 2009 | Refrigerators
Whirlpool Refridgerator Problem
you didnt include the model, but i would assume that the "control panel lights " are also out??, and a clicking noise when the refrig door is opened??? if so you have a bad electronic control board. its located behind the refrig on the left hand side munted inside a little white box next to the compressor,
Oct 26, 2008 | Refrigerators
Refridgerator
IF THE BUZZING SOUND IS ONLY THERE WHEN THE MOTOR IS RUNNING THAT COULD MEAN ONLY ONE THING.YOUR PISTON IN SIDE THE COMPRESSOR IS NOISEY THE ONLY WAY TO SOLVE THAT IS TO REPLACE THE COMPRESSOR.BEST YOU HAVE A TECH TO ADVICE YOU FUTHER.GOODLUCK.MOHAMED
Jul 21, 2008 | Whirlpool ED2FHEXN Side by Side...
Don't start smooth
restarting of refridgerator may damage your compressor motor due to overload.
when you switch off the refridgerator the compressor is in load condition, sudden restart overload the motor, it consume more current so the light going to dim.
solution. If your refridgerator have no delay circuit inside,
use a refridgerator stabilizer or attach a delay circuit,
if you have the the restart delay circuit may problem repair it.
Jan 18, 2008 | Refrigerators
Frige not cooling and click noise.
Sounds like a relay is chattering on the board. First thing would be to change that circuit board, it controls pretty much the whole unit. Make SURE the clicking is coming from the board and NOT the compressor though! See item 801 below http://www.partselect.com/Schematics/GE/00118404i08.gif
Feb 05, 2007 | GE GSH25JSRSS Stainless Steel Side by Side...
Refrigerators Logo
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
