Sony PlayStation 2 (PS2) Console Logo
Posted on Sep 11, 2009
I bought a used ps2 and it had a parental control code so i can;t watch movies at all
Anonymous
Level 1:
Problem Solver:
  • Contributor 12 Answers
  • Posted on Sep 12, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
12
Questions
0
Helped
6592
Points
24
7444 is the password reset for PS2 parental control. Enter that and you should be prompted for a new password.
1helpful
There was a parental lock code on our ps2 when we got it, is there a override code I can use to unlock it? I bought it at a yard sale last summer and they never mentioned that they put a lock on the DVD......
Try these directions, they *should* work.
1. Insert a DVD Movie into the PlayStation®2.
2. You should receive a message informing you that the Parental Level has been set, and asking if you?"d like to allow the disc to play. Highlight "Yes" and then press the X button.
3. A new window will appear asking you to temporarily change the Parental Control to a different level. Again, highlight "Yes", and then press the X button.
4. Another window will appear asking you to enter your Password. Above that window are numbers (0-9).
5. Do not enter your password, but instead, press the select button on your Controller. This will change the text in the window from "Enter Password" to "Delete Password".
6. Using the numbers above the window, input 7444. If successful, you will receive a message stating "Deletion Complete".
7. Press Select. You will now be asked to register a new password. Please select a four-digit code of your choosing.
8. You will be asked to confirm your password selection by inputting the same code once again. If successful, you will receive a message stating "Registration Confirmed".
9. Now you need to turn off the password altogether. The movie should of started playing by now. Press select and chose Setup. Go to the parental control "tab" and set the level to "off".
10. Now you should be able to watch any movie
Bought a used p s 2 and cant watch some movies due to parental codes
press 'select' button-->enter 7444->enter new code-->re-enter new code.
hope this helps :D
Can not unlock console to watch movies on it
Haha no, you don't need parental controls! It's been a while since I got into my playstation 2 but as I recall there is an area when you turn it on where you can access set ups. I think if there is a parental control code on the machine, you may have to call sony to find out what to do as that info was with the parents who set it up. I'm not sure off hand if there is a universal reset code; try the website as well and forums there for the info. I think that's the best advice I can give.
Oh, did you contact the people you bought it from? Perhaps they can find out for you and save you some time?
I need to reset my Parent Control code on our Song Playstation 2
there is a reset option on the software and on the remote control I believe or try 4 or 5 9s should fix it
Playstation 2 was bought used, has a parental lock, can't turnoff
try this:
press 'select' button-->enter 7444--> enter new pass code-->
-->re-enter new pass code
movie should start
2answers
I lost my code to watch movies
then it is your fault if you lost your code...
2answers
Parental password?
Here is the procedure to reset the parental lock code:
1. Bring up a screen where the unit asks you to enter in the parental code. You can either insert a restricted disc, or enter the DVD setup menu and go to "parental control" under custom setup.
2. When the screen asks for the code, press the SELECT button, then enter in the code "7444".
3. The level adjustment under Parental Control dictates the strictness of the player. The lower the value, the more strict it will be. Either increase the value to lower the restriction, or disable the lock entirely by setting it to "off".
4. Once you have made your adjustments, be sure that the DVD tray is empty, and press the RESET button on the front of the Playstation 2. It is imperative the tray is clear of any DVD or game for the unit to save your settings.
1helpful
2answers
Over ride the parental control level
Ok first try 0 1 2 3 because that is the preset code for the ps2 or if that dont work insert any dvd movie, go to setup and access the parental control settings(press select) When asked for your code enter "7444"; It will prompt you again to type in your password. Type "0000" and then scroll down to the movie rating options and choose "off". Hope it helps you out!
150helpful
14answers
PS2 PARENTAL CONTROL CODE
This is the only way to turn "off" parental control lock on the custom setup screen.
1) turn off ps2 with no dvd in drive.
2) turn on ps2 and insert dvd in drive.
3) when it asks about parental password, choose 'yes'.
4) when prompted for password, press 'select'.
5) the prompt will change and say 'delete password'. enter '7444'.
6) enter a new password (0000 works).
7) registration complete, dvd will start playing.
8) once the movie starts, press 'select'.
9) click the 'stop' icon.
10) click the 'stop' icon again (the icon must be gray even when you have it highlighted).
11) navigate to 'custom setup' ('select', setup icon, custom setup icon)
12) move to parental control option, press right directional button, enter password (0000).
13) move down to 'level'.
14) move up to desired level (off is at the top).
15) click 'x'.
16) go back to 'select' menu options, and press 'play'.
17) while movie is playing, eject disk and remove dvd.
18) turn ps2 off using switch on the back, keep off for five seconds.
19) turn on ps2, put dvd back in.
20) happy dance. ;)
Video Game Console
Start a DVD, then stop playback. Clear "resume play" (press stop twice), goto the Control Panel, the select SETUP, then ADVANCED SETUP. Select PARENTAL CONTROL, then press Select. Enter the number 7444.the old password is clear, now you can set a new one and change the rating.
Top Sony Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
Jose Ramirez
Alexander
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
