Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Turning key does nothing ,not even a click. Battery tests 12.5 volts. I installed a new ignition switch, no help. I touch both lugs on regulator and engine turns over with key on. I think it has to do with clutch brake pedal. .
    Problem Solver:
  • 15 Answers
Or it could be one of the many other safety wires like the deck lever try pulling back on it and see what happens
Posted on Sep 12, 2009
1996 ez go 36 volt golf cart not doing anything. Where do I start?
You need a volt meter the problem is some ware between the battery and the ignition switch .Check battery grounds all if bat is grounded you should have 6.5 v D.C from B+ to anything on the engine or frame one at a time then test both for 13 v at the same time jump them together .This could be your problem 2 battery's with 1 bad ground .Then start from the other end the ignition switch use jumper leads hook to the switch in start position key turned to black to ground see what you have for voltage drop it should be around 12 volts if you have nothing its the ignition switch if you have less then 12 v its likely a bad ground from one of the battery's or something related to the drive motor
Apr 03, 2018 | Cars & Trucks
1995 Isuzu Rodeo won't start all of a sudden.
Check connection battery,could be starter.
Jun 05, 2013 | Cars & Trucks
Autopage alarm wont let my vehicle start
Is this a new installation? Is this a remote starter?
If you have an alarm with a starter inhibit installed and, after disarming the system the car doesn't start, there are several steps to take to ascertain the problem.
Begin by using a voltmeter or, low voltage testlight and test the starter wire at the ignition switch. Turn the key to start and test for voltage. If you do not have 12 volts on the starter wire at the ignition switch when turning the key to start, you either have no power (battery or fuse) in the vehicle or, your ignition switch is bad.
If you have 12 volts at the switch, move your test light to the other side of the starter kill and test for 12 volts. If there is no starter kill, move your tester to the starter relay under the hood. If there is no power coming from the relay, you have found your problem. If you have power coming from the relay to the starter then test the starter when turning the key. If you have power at the starter when turning the key you have found you problem. If you have no power going to the starter when turning the key then there is break in the line.
Jan 20, 2013 | Vehicle Parts & Accessories
WHAT ARE THE SIGNS THAT MY IGNITION SWITCH IS BAD AND NEED REPLACEMENT?
first is if your battery is charged and cable connections are clean and you have power everywhere else there is no click ,best way is to get a test light go to ur starter u will find a thick wire going to ur starter ground ur light touch to thick cable on starter check for power .there will be one other connection on starter touch ur test lite to that connection and have someone turn key to start position if it lites and nothing happens its the starter or starter solenoid if it doesnt its probly the ignition switch . but first check all ur fuses with a test lite .also a voltmeter would be your best bet instead of a test lite so u can make sure got 12 volts at test point make sure u got good connections and good grounds a volt meter is better thana test lite for that
Sep 14, 2012 | 1994 Toyota Camry
98 Toyota Corolla - won't start or turn over. It ran fine but when we tried to start again, there was nothing. Sometimes the dashlights light up when you turn the key, but then go black when you touch the...
Does the start try turning the engine?.. or does it just click? or not even click?
HOw is the battery voltage?
check with volt meter. it could be dead after many attempts
Apr 17, 2010 | 1998 Toyota Corolla
Mower sometimes will not start. Has new battery
You have to use a volt meter and test the ignition circuit to find out where the voltage stops. If you have 12 volts going in to and out of the switch, then switch is good
Nov 02, 2009 | Craftsman Garden
New battery but the engine will not turn over
check the starter..is there a click?if so... wiggle battery connections..if still nothing... try tapping on the starter under the jeep while somebody turns over the engine
Sep 30, 2009 | 1996 Jeep Cherokee Country
After changing the starter and alternator and installed a new ignition switch my 1997 Nissan p/u started up fine. Drove it around town, stopped, turned off the engine and it started again right away. Drove...
Check and make sure you are getting power to the ignition switch and to the stator wire on the starter. Turn the key on and and measure the volts going to the starter on both wires. You should a atleast 12 volts going to the stator wire and to the main wire from the battery. If you are not getting power there it could be a fuseable link in the power wire from the ignition. I noticed that you replaced the ignition switch make sure the rod from the key switch has not come out of the switch.
Sep 16, 2009 | 1997 Nissan Pickup
Won't start - Starter or ignition or what?
It could be the ignition going out. To test the ignition you would have to get a volt meter and find the hot wire to the ignition. When nothing happens when you turn the key, test the hot wire going out of the ignition that eventually goes to the starter. Your ignition is just like a light switch, just a little more complex. You will have to find the wire that connects the switch to the starter to see if the switch is working properly. If when you try to start the car see how many volts you are getting. It should be at 0 until you try to start the car. then it should jump up to either 12 or 24 volts depending on what your start used to start the vehicle. A lose wire from the battery can cause these same problems however. I would start with that and make sure you have good clean battery posts and connections. Then check to make sure they are tight. Then get into the ignition switch checks.
Nov 11, 2008 | 1996 Buick Park Avenue
Ford 300 -starts, but quits when you let go of the starter
With the ignition turned on, measure the voltage on the coil + terminal, it should be 8 to 12 volts, if there is nothing or very low ( ie 2 - 3 volts) then I would suspect the ballast resistor, )which may be part of the wiring from the key switch to the ignitionpack or coil.)
Nov 04, 2008 | 1985 Ford F150
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
183 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
