Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Briggs & Stratton 17.5hp engine How do I set the timing
  • 582 Answers
IF YOU HAVE THE ENGINE APART YOU MUST LINE THE TWO DOTS FACING EACH OTHER THE PISTON MUST BE AT THE TOP OF THE CYLINDER FROM THERE PLAFCE THE CAM IN WITH THE DOTS ON THE CRANK AND THE CAM FACING EACH OTHER. YOUR ENGINE IS NOW IN TIME. NOTE: THE DOTS MUST BE PERFECTLY IN LINE
Posted on Sep 12, 2009
  • 54 Answers
There is no ignition timing setting on this engine. just ensure the crank keyway is in good condition ( as they have a tendancy to sheer off and spin). then place a business card between the coil and flywheel, loosen off coil let it settle against magnets, tighten then remove card.
Posted on Jan 17, 2013
2 Suggested Answers
  • 376 Answers
SOURCE: what is the valve clearance on a briggs &
.003-.005 intake, .005-.007 exhaust for single cylinder OHV
Posted on Jun 14, 2009
Cub cadet 30 inch 1450 briggs and stratton
About 625 results (0.89 seconds) Search Results
    Why wont my engine start - Briggs & Stratton
    www.briggsandstratton.com/.../why-wont-my-engine-st...
    Briggs & StrattonThe most common reason an engine will not start is due to an interruption in fuel ...(such as Briggs & Stratton carburetor cleaner to clean carburetor parts and body. ...gasoline be purchased in small quantities, not more than a 30 day supply. ... that canflood the engine, or cut the air supply enough that engine will not run.Missing: inch ‎major
    Information about the Carter, Kohler and Walbro Carburetors
    gardentractorpullingtips.com/carbfuel.htm
    Information about the Kohler Carburetor, Various Fuels and Fuel Systems. ... (Updated 5/23/15); Repairing Various Older Briggs & Stratton Carburetors. ... If used on a smaller engine, due to the larger venturi, the engine will not receive the ... which converts to 1.181 inches (30 ÷ 25.4 = 1.181"), but actually measures 1.200".
    Notes on the Troubleshooting and Repair of small Gasoline ...
    www.repairfaq.org/sam/lmfaq.htm
    May 19, 2015 - Timing; Lawn mower will not start after the blade hit an obstruction; Flywheel ... on Briggs and Stratton repair; Experience with Briggs & Stratton carburetor .... NEVER attempt to run a gasoline engine indoors. ..... For 2 stroke engines, special oil (not the usual 10W-30/40 type motor oil, nor WD40 or 3-In-One!) ...
    Briggs & Stratton - YouTube
Jan 21, 2016 | Garden
What do you set the timing on the camshaft/crankshaft of a Briggs & Stratton model 441777 type 0117B-1 2 cylinder?
There will be an arrow or line on the crank and usually a dot on the cam sprocket. line these marks up and your engine is timed.
Oct 11, 2014 | Briggs & Stratton Garden
I bought an Ariens, model #921031 Deluxe 24 with a Briggs & Stratton engine brand new online and haven't used it yet. It's been sitting and now I have a puddle of oil under it. The place t
Some times, the seals not sealed yet not being run. Check all your oil and gear oil levels and run it. Hope everything will be ok then.
Feb 10, 2012 | Briggs & Stratton Garden
Need valve clearance for 24 ohv engine,4457770168e1
You should be able to get the settings from the Briggs & Stratton Website
Aug 24, 2010 | Briggs & Stratton Briggs Stratton Intek V...
I have a Briggs & stratton 18hp ohv riding lawn mover. Model # 31D777 type: 0233 E1. Do you know where I can find an Owner's manual that can be downloaded on the computer? Went to briggs & Stratton...
I also have this same engine and am also looking for the owners/workshop manual . Also went to Briggs & Stratton with no satisfaction. If you find anything please drop me an email aswell. Thank you. harmsen2@bigpond.com
Mar 27, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Briggs & stratton Modal No 490179 carburettor linkage
it sounds like the governer needs to be set and the carb needs to be cleaned out> I would get a carb rebuild kit and go to briggs online and look up how to set the gov dont run it till you do or you may blow the motor
Aug 31, 2009 | Briggs & Stratton Power Products 5,550...
Timing for briggs and stratton 15.5 engine
There are no timing marks, timing is correct when the flywheel key is in place, the flywheel is properly torqued and the air gap for the magneto is properly set
May 18, 2009 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
657 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
