Question about Asko T700 Electric Commercial Dryer
Asko T700 dryer
Drum appears to rub against front plastic circle. Would replacement (or is there an adjustment?) of the drum support wheel recenter the front of the drum?
  • 126 Answers
Seems like you need new drum rollers. If one(or both) is bad, the drum will rub in the plastic.
Posted on Jan 23, 2008
How to Replace the belt for a Asko T700 Dryer?
I have a T760, and the way I do it is to take the top off (3 screws in the back and slide it out from under the front lip), take some pics of the wiring so I'll know where they go (they're marked, but pics still help), and take the back off (perimeter screws). The drum bearing is mounted in the back, so I have to tap the drum shaft thru the bearing (take the washer off and put the nut back on so it is flush with the end of the threads). Asko has a special tool to hold the drum in place while the back is off, but I made one out of a coat hanger (a hook on one end to hang on the lip of the drum, bend a couple of right angles to fit thru the holes in the front panel, make it before the back comes off). The real hassle is holding the drum in place while reinstalling the back and the tool does this nicely. The belt has a spring loaded tensioner, make sure the wheel and bearing are ok, put it back together, and you're back in business...
May 10, 2012 | Asko T700 Electric Commercial Dryer
The drum stopped turning on our Asko t700 dryer even though the dryer motor works fine so it runs and blows air but will not turn. Both of the fuses seem fine and as I say the motor and everything else is...
the belt is broken, here is a thread:
http://applianceguru.com/forum2/2043.html
here is a manual:
http://www.ajmadison.com/ajmadison/itemdocs/English-T711-721-731-761-781_UCG.pdf
Hope it helps Tim
Apr 25, 2011 | Asko T700 Electric Commercial Dryer
Trying to replace drive belt. How do I get the new belt around the drum?
hey to get the belt on the asko dryer you need to take all the screws out of the back of the dryer back plated dont worry you can do this take the top plate off 2 then remove the cap from the optional side vent pipe if applicable lay dryer on to the front side down position lift the back plat a littlew say 5 inches reach in and take the vent plastic manifiold out by pulling it right an inch or so then pull it toward you (back ) when you get it out you can see the motor wih the belt idler pintle (axle) if your belt idler has fallen loose locate it and or remove it temporarily figger out hay the idler fits to the belt onto the motor houseing (unit) pull belt off the drum towards you remove between the space between the back plate and dryer drum to preplace instale in reverse order note 1 wire you will need to reach into the bak at top to reatrtache the plastic clip so you can screw it up to keep it from rubbing ect and good luck
Oct 18, 2010 | Asko T700 Electric Commercial Dryer
How do I replace the belt on my Asko T761 dryer? Do I go in thru the front, the back? Are there instructions on-line for belt replacement?
How to install a belt on ASKO dryer
Belt Type: Flat belt with ribs
Installation Notes: Ribs go against drum
You could Refer to :-
http://fixitnow.com/wp/2006/05/08/asko-t700-dryer-wheel-drum-and-belt-replacement-instructions/
It would be a Generic one but would help you.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Mar 11, 2010 | Asko T761 Electric Dryer
HOTPOINT WASHING MACHINE - BELT IS RUBBING AGAINST BACK OF DRUM & WEARING BELT + INTO PLASTIC DRUM CASING. I HAVE TRIED MOVING THE BELT TO THE FRONT EDGE OF THE MOTOR PULLEY DRIVE, BUT AFTER A FEW...
if you have gotten that far your good
now try to look at the motor it sounds like your belt might be a lil off track on the mortor shaft
there is a adjustment srew on the top left of the motro its hidden under things but its there
you can looses this and swing the motor
make sure you have it lined up on the motor shaft and it should stay aligned on the pully
Oct 08, 2009 | Hotpoint Aquarius WD63 Front Load...
Asko t701 dryer makes exsessive noise and drum rotates slowly
Mine was very noisy. Then I found the impeller clogged with lint. I cleaned it and now the noise is gone.
Remove the lower panel (2 Torx T20 screws).
Remove the impeller cover (1 Torx T10 screw and 4 snaps).
Clean impeller.
Reinstall covers. Don't overtighten screws.
Sep 10, 2009 | Asko T701 Electric Dryer
Kenmore dryer front of drum rubs
Check your plastic drum slides. I get em(2) out of the drum and reverse them and that sometimes stops it.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Feb 14, 2009 | Kenmore 62602 Electric Dryer
Aslo T700 Dryer Heats but won't dry.
TRY DISCONNECTING THE EXHAUST FROM THE BACK OF THE DRYER AND RUN ONE LOAD THROUGH IT. IF IT DRIES O.K., THEN YOU HAVE A RESTRICTION IN THE DUCT WORK.
Apr 07, 2008 | Asko T700 Electric Commercial Dryer
Asko T700 loose belt, access from front?
I think you must replace the belt and the tensionarm. It MUST be done from the backside of the machine... Remove the backpanel, and the drum, change the tensionarm, and put the drum into the machine again. Put on the new belt, and mount it together again. Be careful for sharp edges! Hope this helps :-)
Jan 12, 2008 | Asko T700 Electric Commercial Dryer
ASKO t700 dryer thumping sound
usually whin you get one thump (or a quick double thump) you have a dent in the roller surface of the drum itself. Easiest way to check this is to unplug the unit and take the top off by removing the 3 torx screws in the rear, then lifting the top off. Once the top is off look at the very front edge of the drum as you rotate the whole thing by hand. If you see any irregularities on the surface, thats your problem. If you see nothing it could be a bad motor or roller, but its unlikely if its happening in the same place on the rotation evry time. What has usually happened with dents in the surface of the drum is that the unit was set down too hard (or dropped) and the wheels it rests on dented the metal they ride on. If thats the case the only solution is to replace the drum or live with it .Good Luck!
Feb 10, 2007 | Asko T700 Electric Commercial Dryer
Asko T700 Electric Commercial Dryer Logo
194 people viewed this question
Top Asko Dryers Experts
Marvin
Marvin
Craig Butler
Craig Butler
Lollo Pop
Are you an Asko Dryer Expert? Answer questions, earn points and help others
