Question about ASUS A8V-VM Motherboard
Bios installed new graphics and ram..know the pc not reboot?
  • 556 Answers
Consider installing the ram or checking that it is installed properly. computers may not boot if the ram was not seated properly (installed fully) in the ram slots.
Posted on Dec 10, 2007
  • 55 Answers
Try to come back with old configuration second time check new ram , may be something no good
Recently I bought the ATI SAPPHIRE Radeon HD 6770 flex edition on ebay. Today it arrived and I put it in my motherboard MCP73PV ( from oem pc Acer Aspire M3641) (also i have a new power suply 450 Watt so...
in the bios, there are usually settings for onboard devices. try turning off your onboard vga in the bios. and/or enabling/disabling pci-e video settings in the bios. it also helpful to ensure there is a monitor plugged into the video card. if there are 2 video outputs on the new card, try plugging the monitor into one, reboot, if nothing shows up, plug the monitor in the other one, reboot, if nothing shows up; i dont know :)
Sep 12, 2013 | Computers & Internet
I have a compaq presario pc. Motherboard is Asus P5LP-LE : Lithium UL8E. I have 3 Gig of RAM installed, a 400w PSU. I have just purchased a new graphics card - Radeon HD5570. My MoBo has 1 PCI-E x16 and 3...
I think you have not connected power connector to your Radeon HD5570 .
This graphics card have 6pin power connector .
You need a 6pin power connector cable that comes with the graphics card box.
1.First connect your 6pin power connector to Graphics card.
2. Then connect other part of the cable to PSU.
Hope it will work for you.
Thanks for using FixYa.
May 14, 2011 | Computers & Internet
HOW TOI DISABLE ONBOARD GRAFIC AND INSTALL NVIDIA GRAFIC CARD
fit the graphic card to your pci-e port of the mother board
on bootup press F2 to edit the CMOS/BIOS options
and disable the VGA graphics or noboard graphics there
ENABLE PCIE graphics.
save the settings
boot to windows
upon boot install new drivers for PCI-E card
restart the pc
Mar 04, 2011 | Asrock PV530 - 1.8 GHz processor - VX900 -...
I have an hp pavilion a6403w desktop. I have upgraded the stock ram to 4 GB crucial, and have installed a Galaxy 9500 GT vid card. Everything else on the system is entirely stock. After a Windows update,...
Wait a minute! Hold the phone here.
You made three major changes here.
1) The Windows update. You have to watch what Microsoft put's in their updates. Manually install the update/s, and look at each one before you install, don't use the automatic feature.
With all of the cr@p out there, Windows updates include a lot of security add-on's.
Some of these can bring a computer to it's knees.
Some updates have 'bugs', and guess who is the one who gets to test it?
Yep, the user.
Install one update at a time, so if something happens to your computer, you'll know which one it was, and can delete it.
2) New Ram Memory, and 4GB's.
Who knows if you got a bad stick from Crucial, and even if the stuff is correct?
Did you pick up DDR2 Sdram at 800Megahertz?
(PC6400)
Each stick can use up to 5 Watts.
Has to use 1.8 Volts, be Low Density, Unbuffered, and Non-ECC.
CAS Latency (CL) around 6.
Still doesn't mean the factory, couldn't have sent Crucial some bad ram.
Happens.
3) New graphics card.
The Nvidia 9500GT requires a Power Supply with at least 350 Watts, and the 12 Volt power rail should have at least 18 Amps.
The Pavilion a6403w comes with a generic 300 Watt power supply.
Actual wattage for this baby is more like 70 percent of the maximum stated Wattage.
210 Watts.
Probably 12 Amps on the 12 Volt power rail.
Doesn't mean the graphics card itself needs 350 Watts.
The Wattage is based upon a test computer unit.
[The test unit will have a powerful Processor, (Core2 Duo, or Quad, probably), maxed out with 4GB's of ram, an average motherboard, plus two optical drives, two computer case fans, and a Processor fan]
But if you're still running that generic old Power Supply that came with the computer, this ain't gonna cut the mustard.
I would go back to the old ram, remove the graphics card, and use the Integrated Graphics.
(Plug the monitor back into the motherboard VGA connector, {Blue}, or the DVI connector, {White} Whichever one you were using originally)
[You are following Anti-Static Precautions, correct?]
Computer unplugged from power, press the Power On button in, and hold it in.
Hold it in for a count of 5 Seconds.
(Count, 1001, 1002, 1003, 1004, 1005)
Let go of the Power on button.
Do this procedure two more times.
What you are doing is clearing CMOS Error Codes, and resetting BIOS back to the factory default settings.
Let's get this computer working again, and install Windows 7.
Then come back, and install ONE stick of ram at a time.
A pain I know, but you need to see if there may be a bad stick of ram, and if the ram is compatible, before you go on.
(NO old ram installed)
When installing just one stick, make SURE it is installed in Slot 1.
That is the ram memory slot that is closest to the Processor.
(May have DIMM 1 printed on the motherboard, next to Slot 1)
Computer works with 2GB in Slot 1?
Computer off, unplugged from power, Anti-Static Precautions taken, install the other 2GB in Slot 2.
Everything works so far?
Install the Nvidia graphics card.
(Doesn't matter WHO makes it. It's still has an Nvidia GPU chipset on it)
BE SURE to put THE Drivers in the computer first, THEN the graphics card.
Windows operating, put the installation CD that comes with the 9500GT in the optical drive.
Install the software.
Then computer unplugged from power, Anti-Static Precautions taken, install the graphics card. Plug the monitor into the graphics card.
(Hey, don't laugh! Sometimes we computer geeks get in a hurry! lol!)
When you go to install Windows 7, do you have the first boot device in Boot options, in BIOS Setup, set to CDROM?
Would like to 'hear' how this comes out, and am here for questions.
Post in a Comment.
[ What I 'see' so far is an underpowered Power Supply.
I thought at first it was a Vista problem, and it may be.
Vista, and the Windows update.
With a new harddrive, and Windows 7, Vista shouldn't be an issue anymore.
There is one more hardware issue. Could be bad Electrolytic Capacitors used on the motherboard.
Specifically the one's used in the motherboard Voltage Regulator Circuit, but I'll reserve judgment on that, after you have posted your findings.
A) http://www.capacitorlab.com/visible-failures/index.htm
B) http://www.hardwaresecrets.com/article/616
Aug 14, 2010 | Computers & Internet
PC does not boots
Change the SMPS, preferably with 450 & above wattage. Also you must be using an UPS(uninterrupted power supply or battery back-up so there are no chances of voltage fluctuation. At the time of changing the SMPS also remove the RAM and clean the contact points with a piece of normal white paper..............sodeep
Jun 28, 2009 | Computers & Internet
How we can share RAM memory with graphics memory of our PC?
go into the system BIOS by pressing the DEL or F2 or F10 key and the you will see the BIOS menu, ther you will see intergreated peripherals and there you will see video ram something like that and there it will show you 8Mb change it to 32 or whatever you want press F10 and reboot and your memory is changed.
Mar 23, 2009 | Computers & Internet
Toshiba satelite m35x-s111 computer won't boot. get 1 beep followed by 3 beeps followed by 3 beeps and 1 beep. must be a coded describing boot problem
The laptop is not recognizing your extended RAM. Try removing one of your RAM sticks and restarting it. Replace and remove the other and restart it again. If it works with only one module installed, then those two cannot run together. If it will not work and you have only one in there then the RAM is bad.
Dec 06, 2008 | Computers & Internet
Installing ram
You need to go into the bio and update the memory there and the Yellow ! will go away. Boot the PC, select the F8 key during post, go into the setting for Memory and accept the change and you should be good to go. Let me know //D
Apr 25, 2008 | Dell Inspiron 1000 Notebook
Medion pc keeps rebooting just as starting to load win xp home
Sir your useing windows xp os ok your Probalm finaly turns off & reboot some .dll fils are missing so your install new software for your pc ok by .
Mar 15, 2008 | Medion MD-1704 PC Desktop
ASUS A8V-VM Motherboard Logo
62 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
