Question about PfaFF Tiptronic 2040
I have lost my manual and can't remember how to thread the Tiptronic 2040
  • 14 Answers
Make sure you have your spool of thread pushed all the way back on the spool pin with the proper size thread cap. Make sure your foot is in the up position, as this opens the tension discs. There is a small metal circle on top. Pull the thread behind it and under it and directly down. Come back up the other side and around the take-up lever. If you cannot see the take-up lever, move your handwheel until it is all the way up. After you have threaded it around the take-up lever, it comes back down this same side. On either side of your needle bar are two small metal clips. It doesn't matter which side you put the thread into. To put it into the clip, hold the thread taunt and pull it from the outside in against the clip. Now put your foot in the down position. When you pull the thread, it should be tight. Push your needle threader all of the way down. It has a tiny (extremely tiny) hook that will come through the eye of the needle. Wrap the thread around the metal bar/hook on it and gently bring it in front of the needle but under the metal guides that are in front of the needle eye. This next part takes some coordination, gently realease the thread as you simultaneously release the threader. It should pull a loop of thread through the back of the needle.
Also, when you wind a bobbin, you must thread it through the top of the metal disc on top and not underneath it. This provides the correct amount of tension for bobbin winding.
If you are not sure if you have threaded correctly, with the foot in the up position, pull on your thread. It will pull freely off the bobbin. With the foot down you should have a lot of resistance. Good luck to you!
Posted on Sep 12, 2009
Testimonial: "Thank You so much for the info. This helped a lot. I got the machine threaded with your directions and I am back in business sewing. Thanks again."
I have a pfaff 2040 and when the needle goes down to pick up the bobbin thread the main thread wraps around the bobbin housing and jams. Doesnt grab the bobbin thread. How can I fix this?
Be sure to use a brand new needle because a bent needle could miss the bobbin thread.
Search the internet for sites and videos relating to sewing machine timing or take it for service.
Dec 02, 2016 | PfaFF Tiptronic 2040
How do you change the tension
try this link for a manual that should show about the thread tension
http://www.sewingpartsonline.com/instruction-manual-2040.aspx
May 11, 2013 | PfaFF Tiptronic 2040
How do i fix the tension on my pfaff tiptronic 2020
It sounds like you need to adjust the bobbin tension. There is a small screw on the bobbin case to tighten/loosen the thread's tension coming out of the case. Refer to the user manual on the procedure to set it.
Nov 28, 2011 | PfaFF Tiptronic 2040
I inherited my mother's Tiptronic 2040, and needed to sew a simple seam. I admit to not having much experience. I have re-threaded it several times,; re-worked the bobbin but the top thread keeps getting...
Deep breath. Ohmmmmm.... ok now.
Few things you need to know.
1. Try to remember TTN when you run into problems like this it stands for Thread, Tension, Needle. Contrary to popular belief, there is no such thing as universal thread and needles. You'll need to determine what kind of thread and needle is best for your application.
2. When things gets bunched up under the fabric it Usually means that the tension for the top thread is too loose. However, a bad, bend or just plain wrong needle will cause these problems too.
3. Always grasp the threads (both top and bottom) and pull gently backwards when starting a seam. Some old school seamstresses and seamsters say to make sure your needle is at its upper most position (just before it starts to move down) before you begin sewing.
4. since you've had a couple instances with this issue... you might have to clean the bobbin race area. I'm a bit reluctant to tell you about this but remove the bobbin and look carefully for other stray threads, dust bunny's etc.
I hope this helps some. ;o)
S
Mar 12, 2011 | PfaFF Tiptronic 2040
Threading the machine
what is the setting to hem
Feb 21, 2008 | PfaFF Tiptronic 2040
Sewing Machines Logo
433 people viewed this question
Top PfaFF Sewing Machines Experts
SewTechWayne
SewTechWayne
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
