Question about Freezers
Ice smells and taste funny that comes out of automatic ice maker
Recently moved and refrgerator/freezer has a automatic ice maker in it and the ice taste wierd to me how do i make that go away . I have cleaned and cleaned with bleach and I also have a baking sode thing in there and still it taste funny and smells funny to me
    President:
  • Freezers Master
  • 1,922 Answers
Change the water line filter
Posted on Sep 13, 2009
French door / lower freezer. The icemaker makes ice fine until tray is about full and then slowly drips water until about 1/8 of ice is frozen together with a upside down brown ice cycle fused to them....
The most common reason for this is that the fill valve for the ice maker is sticking slightly.
The brown ice comes from the leaking water sitting there on either the kickout bar or the gears and you are getting some residual rust deposit.
You will need to take the fill valve apart and clean it or possible replace it, I also recommend installing a water filter for the ice maker if you don\'t have one or replace the old one.
Calcium deposits in water are real hard on these small valves.
Oct 10, 2013 | Jenn-Air Freezers
The ice from my ice maker has a chemical taste...how do I get rid of it?
Run about 3 cycles of vinegar; then rinse with water. Run regular water through and then the ice should lose the chemical smell and taste.
Mar 30, 2013 | Igloo Cooler Igloo Portable Countertop Ice...
My ice cubes have a funny odor/taste.
Does your refrigerator have a water filter? if it has one it will be in the kickplate/grill below the freezer door. If it has one replace the filter.
Aug 17, 2011 | Whirlpool Freezers
Ice maker will only make crushed ice and no cubes, what could be the problem
Open the freezer door.
Pull the ice bin forward about 3 inches.
Push the ice bin to the rear of the freezer until it seats and locks in place.
Then try to dispense cubes.
The ice bin can become dislodged from its locked position and the crushed ice solenoid activates automatically.
Sep 17, 2010 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
My ice and water taste funny in my Whirlpool ED25PQ. How can I soleve this issue
You can install a filter in the incoming 1/4" line leading from the wall to the refrigerator. These can be purchased from Lowe's or Home Depot and come with installation instructions. Be sure to buy the whole new filter system not just a replacement cartridge.
If you have copper water line you will need a tubing cutter to cut the supply line for filter installation. If the line is plastic a sharp blade will do.
Good Luck
Sep 06, 2009 | Whirlpool Freezers
GE top freezer refrigerator automatic ice cube maker leaks water into the freezer, and eventually on the floor. Water seems to be coming from the area that fill up to make more ice cubes.
If it is leaking water in the freezer it will more than likely freeze amongst the ice cubes causing a block of ice.
It is more than likely leaking at the rear of the unit, near the valve or fill tube for the ice, this will run up the rear wall of the unit.
Mar 12, 2009 | GE Freezers
No water to ice maker or water dispenser
You're funny. This is a portable 12/120 volt model. It dosn't have a water dispenser or ice maker :-)
Dec 27, 2008 | Engel Freezer 22 Qt. Fridge/Freezer
Ice Maker
the LED's are optics they sense the level of the ice in the bucket on the door under the icemaker is 2 1/4" screws you can remove the IM and the white cover put a small jumper in the pins T and H this will cycle the IM the door and optices will need to be closed (or best to tape them so you can leave the door open the IM should cycle if nt check the power at the N and L pins see if you have 120vs then we can go from there
Apr 08, 2008 | Freezers
Freezers Logo
429 people viewed this question
Top Freezers Experts
Dennis Boxerman
AJMAL KHAN
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
