Question about Hitachi Air Tools & Compressors
Gun will not cycle - Hitachi Air Tools & Compressors
  • David Ford
    David Ford May 11, 2010
    OK what is the brand and model number and I will try and find a parts explosion for you and some hints what it might be.
First off more information is needed. How old is it? Do you use oil when you use it? Most likely it needs a rebuild kit.
Posted on Sep 18, 2009
I have a Iver Johnson 12ga double barrel with 30" barrel's s/n 28586 How old is it and What is the Value?
These will all help you.
Iver Johnson's Arms & Cycle Works - American Firearms
www.american-firearms.com/.../Iver%20Johnson's%20Arms%20.../Iver%20Johnson's...
  1. Cached
  2. Similar
Aug 7, 2011 - Single top latch, 100'000 were manufactured in 1894, serial number without letter prefix, marked on the top of the barrel rib. IVER JOHNSON'S ...
*IVER JOHNSON SERIAL NUMBERS ' The Firearms Forum
www.thefirearmsforum.com > ... > The Ask the Pros & What's It Worth? Forum
  1. Cached
  2. Similar
Jan 11, 2012 - 15 posts - ‎10 authors Is the gun large frame or small frame, hammerless or a hammer gun? ... I have a Iver Johnson Top Break 5 shot hammer gun. ... I just purchases an iver Johnson hammerless 5 shot top break revolver. Iver Johnson Serial Numbers 6 posts 26 Jun 2016 Iver Johnson Serial number help 15 posts 1 Nov 2014 Old Iver Johnson shotgun 12 posts 10 Nov 2011 Need Info on Iver Johnson Hammerless Revolver 15 posts 13 Apr 2006 More results from www.thefirearmsforum.com
Blue Book of Gun Values - IVER JOHNSON ARMS & CYCLE WORKS
bluebookofgunvalues.com > Gun Values
  1. Cached
  2. Similar
IVER JOHNSON ARMS & CYCLE WORKS gun model and pricing information.
Iver Johnson Arms - M1CarbinesInc.com
www.m1carbinesinc.com/carbine_ij.html
  1. Cached
  2. Similar
Introduction to Iver Johnson, Iver Johnson's Arms, & Iver Johnson's Arms & Cycle .... With the exception of the D-Day Carbines the serial number on Iver Johnson ...
manufacture date of Iver Johnson revolvers based on serial number ...
www.rimfirecentral.com > Other Rimfire Guns > Misc -- Other Rimfire Rifle Brands
  1. Cached
May 17, 2016 - 14 posts - ‎3 authors There is a serial number listing for the Iver Johnson SuperShot 22 Top Break Revolvers in W.E.Goforth's book/reference, "Iver Johnson Arms ...
Iver Johnson - Wikipedia
https://en.wikipedia.org/wiki/Iver_Johnson
  1. Cached
  2. Similar
Iver Johnson was a U.S. firearms, bicycle, and motorcycle manufacturer from 1871 to 1993. .... William McKinley in Buffalo, New York on September 6, 1901 with an Iver Johnson .32 caliber Safety Automatic revolver (serial number 463344). Iver Johnson 12ga Google Search
Nov 30, 2016 | The Optics
Nail gun problem
This is a bottom fire tool. (NV83A2) You need to hold the trigger down and then as you place the nailer to the wood the safety will depress and it will fire once. This is usually done in one, swift action. If you do this in the opposite way by placing the tool to the wood and then pulling the trigger they often will double fire.
Jul 05, 2012 | Nailers Hitachi Nv83a2 3 14" Coil Framing...
I just put the rebuild kit back in my roofing nail gun and its still leaking air out through the top vent HELP!!!!
Did you check to make sure the driver is not jambed with a nail? Look for flat spots on the O rings and sometimes rotate the piston 180 degrees. Load the piston edges at the O rings with gun oil. Last resort turn the gun upside down and smack cap on wood with no air plugged in then plug air to it. Gun should cycle after this. Old Framer with many guns.
Apr 13, 2011 | Garden
Coil nailer wont feed nails, fires no problem
Remove nails from the gun and dry fire the gun by bumping it against thick rubber mat or coiled up rubber hose. As the gun cycles notice the feeder moving back then forward in time with the cycle. Make sure that the feeder is connected to feeder driver with a roll pin and that the check feeder is in place in the latch door. The check feeder is thin metal and should have spring action. The driver should return completely to top of cylinder with some degree of force. There should not be much air leaking out the nose as the gun cycles. If a quantity of air is leaking out nose with each cycle, then lower bumper may have broken/cracked. Replace as needed. If very little air is leaking out nose with each cycle then driver could be bent, piston oring could be worn or lack of lubrication in cylinder. If all lower parts seem good, then only area left to check is head valve. There is a 1/4 inch dia. rubber ring at the very top of head that could restrict air flow out of exhaust port. Adjust as needed. Good luck.
Mar 18, 2011 | Duo Fast DuoFast 1015141 CNP65Y Siding...
I will make about 12 3" passes over 3" square
Nothing's wrong with your gun or machine. Your unit has a duty cycle of 20 percent at 90 amps, meaning that it will work (weld) great for 2 straight minutes and then it needs to cool down for 8 minutes. The duty cycle it is measure in 10 minutes lapses.
All you need to do is to let it cool down, and start again. That's all.
Jan 19, 2011 | Hobart Handler 140 Mig Welder
Roofing nail gun will not cycle- blowing air out around trigger area-Stanley bostich
you need a new trigger assembly TVA6 or if you have a local repair shop they might just have the o ring that is split.
May 23, 2010 | Stanley Bostitch Nail Gun
My remington 1100 does not cycle do i have to change seals
Check to make sure you have the seals in the right position, 99% of all automatics out there are set up wrong. My 1100 cycles perfectly with low brass, high brass, magnum, reloads, you name it. My first 1100 was a joke, it wouldn't cycle at all, that is when I learned all about those pesky seals. Go to gunparts.com, they have an exploded view of every gun made just about, you will be able to see the seals set up. Check your vent holes in your barrel, Hope this helps.
Mar 10, 2010 | Remington Shotgun Mount 12Ga Lh, B Square...
Air Tools & Compressors Logo
201 people viewed this question
Top Hitachi Air Tools & Compressors Experts
John Trevino
Jim Thurston
Are you a Hitachi Air Tool and Compressor Expert? Answer questions, earn points and help others
