Question about Panasonic PT-53WX42 53" Rear Projection Television
Sony kp-46wt500 color spectrum visible on centre screen
Hi,the picture is fine when your sitting,but when u stand you see the 3 colors red ble and green form an upside down triangle in middle of screen
and also a little oval shaped right above sony label,i opened screen just to see and it appears to be coming throughcan someone tell me what this is and how to fix it? thanks
    Genius:
  • 1,694 Answers
Does the "Magic Focus" make any change...?
Posted on Dec 10, 2007
Colors seperate
Yes, this problem is fixable.
Replace convergence out chips on D board of tv to fix the color separation issue.
Jun 05, 2010 | Sony KP-46WT500 46" Rear Projection...
Problem with Sony KP46WT500: Each line on the
These sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks Distorted/3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking screen
  • White looking sceen
  • Halos around objects
  • Red/Orange looking
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 16, 2010 | Sony KP-46WT500 46" Rear Projection...
My Sony KP-46WT500 screen shows the tv image in blue only for a few seconds, then it goes completely blank (as if it were off). Do I need to replace the bulbs?
It is rear projection TV that use 3 picture tubes of red-green-blue to show color picture on tv front screen.
Do you see standby red light blinking when TV shuts off after showing blue image for a while?
If red standby light is blinking, please count it how many times it blinks, there would be 3 seconds pause between blinks so count pause to pause and post it here to find out possible solution.
Thanks.
Dec 22, 2009 | Sony KP-46WT500 46" Rear Projection...
Sony KP-46WT500 Red, green and blue lines appearing on screen
your convergence IC;s are out, they cost about $40, if you know how to solder, you can do it your self, if not , I would try to find somone that can, service centers charge about 4 or 5 hundred, after you get the new ones, there easy to find on the board in the back of the tv
Nov 26, 2008 | Sony KP-46WT500 46" Rear Projection...
Convergence issue
You need to replace both STK392-560 convergence ICs and some of the 4.7 ohm 1/2watt resistors. You can get replacement ICs and resistors at the following link with free instalation instructions.
http://servicemanuals.vstore.ca/
Jul 23, 2008 | Sony KP-46WT500 46" Rear Projection...
Red hue on TV
I have the same problem. Researching a replacement lamp. After 5 years the lapms expire and it is the most likely failure. Confirm with a local service person using the Sony website to locate a service center.
Replacent in not difficult but the bulbs are >$200. Cheaper than a new TV.
Jul 09, 2008 | Sony KP-46WT500 46" Rear Projection...
Power surge may have blown tv- Sony KP-46WT500- worth fixing?
Take a look at my post on Convergence IC replacement..Thank you GURU JAY
Feb 18, 2008 | Sony KP-46WT500 46" Rear Projection...
SONY KP-46WT500 Arched red lines appearing, mostly noticeable when the screen is dark. I have heard there is a simple fix for this problem. I read something needs to be tweaked with screw driver, but i do...
After all the screws are removed, the panel pops on . They use plastic dowls inserted in rubber. The brightness may need to be turned down on the color that has little lines appearing. The brighness is on the picture tube board on each picture tube. Good Luck
Ed
NC Electronic
Mills, Wyoming
Jan 01, 2008 | Sony KP-46WT500 46" Rear Projection...
Sony TV KP-46WT500, 46" Rear Projection TV , colors mixed up
You have a pair of Bad STK392-560. replacing these will definitely fix the set.
Best regards
CircuitCity
Dec 19, 2007 | Sony KP-46WT500 46" Rear Projection...
Panasonic PT-53WX42 53" Rear Projection Television Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
