Question about Marantz Audio Players & Recorders
Marantz cc870 how do you reset it? Once a cd is stored, that slot is forever ''occupied'' even with no cd in it. Can't put another cd in that slot,
5 Suggested Answers
SOURCE: Marantz CDR 615: Msg: ''No CD''
I've owned one for years, and yes... depending on how many discs you burn, you may need a new tray. You can call Marantz and they will ship one to you. They will also send you a diagram of how to replace it. Pretty simple.
Posted on Aug 16, 2009
SOURCE: my marantz cdr 630 gives an error OPCFAIL with all
There are only two possible sulutions. First, the machine is quite fussy about which brand of discs you use, so a different type may work. However, as you say "all the discs" I believe you may have tried this already. The second and in my experience most likely cause is that the lazer is getting weak with age / use. Sometimes cleaning it (very carefully with a q-tip and neat isopropyl alcohol) can extend its life to a degree, but I am afraid once it reaches this stage the only rel solution is to replace the lazer mechanism. I have owned my machine for about 7 years and in that time it has had three new lazer mechs and the the third one is now giving the same problem. I don't recall how much the last repair was, but it wasn't cheap. Frankly I am not going to bother now as PC writers are a much cheaper and more dependable option. I going to put my 630 on Ebay for spares or repair. Of course if you do a lot of "real time" recording to disc the Marantz may be worth fixing. If so, these people may be able to help http://www.nsslimited.co.uk/ Best of luck. Les.
Posted on Aug 16, 2010
  • 99 Answers
SOURCE: Laser is malfunctioning on my Marantz CD Recordable DR6000
the laser in your DR-6000 is exactly the same as what's in the philips cdr-775 and cd-r-770.
a brand new laser for these are very hard to get hold of and are very expensive. personally i would look out for the above philips models on ebay for less money then take the whole mechanism out and unscrew the servo board and then fit the marantz servo board in place of it and fit it back into your recorder.
i have done this on numerous occasions with no problems.
hope this helps.
Posted on Sep 12, 2010
  • 99 Answers
SOURCE: Marantz CD48 - CD spins backwards
Check the small signal transistors BC338 and BC328, they're under the transport mech and will be near where the spindle motor plugs in to the PCB.
One of the transistors acts as a brake which momentarily puts the motor in reverse polarity to stop the CD rotating during 'stop' or 'open tray' modes. The reason the CD is spinning backwards is that the transistor which drives the spindle motor forwards during playback is faulty and is triggering the braking transistor hence spinning backwards.
The transistors should be 'BC328-25' / 'BC338-25' (25v)
Replace these and all should be well.
Hope this helps
Posted on Sep 01, 2012
How do I connect CD player to marantz NR1504 with phono leads
Connect the cd audio out to the line in or cd in on the marantz
Nov 25, 2014 | Marantz NR1504 5.1-channel Home Theater...
How do i reset a Marantz cd6005?
Here is the manual for the machine. I don't immediately see anything that says 'reset'.
May 09, 2014 | Marantz CD6004 CD Player
MARANTZ MA 700 NOT SURE HOW TO MAKE CONNECTIONS. NO MANUEL. LIGHTS UP
you'll want to use the rca sub out from your pioneer, to almost any input (aux, tape, cd) of the marantz, then speaker cable from marantz to sub. once you get them hooked up, adjust volume, bass, on the marantz to blend well with main speakers at a nominal lvl,
Mar 20, 2013 | Audio Players & Recorders
Is there anything in particular I need to do to use the digital outputs of the Marantz pmd340? My ps audio dac works with a rotel cd player automatically but I can not get it to work with the marantz with...
You may have indicate on the CD player that you wish to use the Optical output and then even when that is correct there are different bit rates that may not be compatible with the input of the amp.
Dec 26, 2012 | Marantz PMD340 CD Recorder
Marantz CD4000 dim display fix?
CD 4000 have two types of displays. Flourocent type and LCD type. It yours' have flourocent type, the display module is faulty. If it is LCD type, backlight LED is faulty. This LEDs can be replaced.
Jun 05, 2012 | Marantz CD-4000 CD Player
Remote not working on Marantz 63cd. Tried
check the back of your marantz player, some old marantz products have a buttom at the back saying system or intermal, if it is on the system side, the remote will never works.
May 06, 2010 | Marantz CD-67 SE CD Player
Marantz CDR633
Try the following link.The manual will be automatically downloaded once the link is clicked.
click here for the manual of Marantz CDR
Good luck.please do rate my answer if accepted.Also feel free to post further comments.
Jan 18, 2009 | Marantz CDR632 CD Recorder CDR-RW with...
Marantz support question
This is the problem with computerized stereo's. The old analog stuff we could fix forever, but many of these digital problems, only the maker has the tools to repair. Feel fortunate that yours will even offer you support, even though expensive.
Good luck.
Jan 28, 2008 | Marantz SR-7200 Receiver
102 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
