Question about Dual Electronics CECT P168 Cellular Phone
My Cect i9 does not receive texts from certain people. It used to work just fine, but friends have been getting message failed notifications when trying to text me. Please Help!
  • Anonymous Mar 29, 2014
    Getting "failed to sign-in" notifications for the samsung email.
Good day i have a i9 with vodacom simcard - how do i get gprs settings?
To get GPRS setting,You need to contact your service provider(Vodacom) through phone or go directly to their office.
They will send you the settings for your model.You will receive service settings in the special text message called as smart message. Please save the settings to your phone and set it has a default settings.Then you can start using the GPRS in your phone.
Thank You
Aug 17, 2010 | Dual Electronics CECT P168 Cellular Phone
My i9 sends text messages but wont le calls in or
go to call center/ more/ auto end ...switch this to off
Jan 26, 2010 | Dual Electronics CECT P168 Cellular Phone
Cect i9: memory full
delete all SMS messages and mp3 songs to get free memory.
Jan 11, 2010 | Dual Electronics CECT P168 Cellular Phone
Hello i just received my sci phone i9 +++ today and everything works great but i just cant receive text and mms messages please help! im really struggling
These phones comes with Chinese mms and sms settings only. You need to set it up yourself. if you want let me know what's your service provider, I have the info. about T-Mobile, but I guess we can get any other information from Google.
Dec 18, 2009 | Dual Electronics CECT P168 Cellular Phone
Need wap/mms settings for optus (aus) for cect i9 phone
If you have a I9 you must go to this site. very helpful every question you have has been asked at this site. Regestration is free.
http://www.i9forum.co.uk/
Most setups are listed directly on this site. I took this qute from someone asking the same question.
I didnt see the thread they were ytalking bout, but they are suggesting stting it up like the Nokia 2610. I would recommend posting this question again on the above site. Below is what I copied from there.
Hi I'm in Sydney and use Optus mms and wap with no problems. If you look in this thread under the topic Easy configure MMS. Follow the instructions to the Nokia site for the 2610 and you should get a text back to set up MMS and the internet. Good luck It worked fine for me.
Apr 09, 2009 | Dual Electronics CECT P168 Cellular Phone
I have a CECT i9 and sms messages only show phone #, no name
I realized that my contacts in my phone book did not have a 1 before the area code and number, so I went through my phone book and change all the numbers to 1-253-XXX-XXXX, and now they show up on my text messages.
Feb 18, 2009 | Cell Phones
When i receive messages on my i9 the number appears not name
I have the phone and have had the same problem. I found I have to add the "1" before the area code to all the saved contacts or at least the ones you use most and that should fix it... when the text message is received it has the "1" normally we don't save the number that way...
Feb 14, 2009 | Dual Electronics CECT P168 Cellular Phone
Free games for i9 phones
The CECT i9 and i68+ have JAVA. Unfortunately, most of the free JAVA games out there, are designed for keypad input. You will have to look for specifically "touch screen" apps and games. And among those, not all of them will work. I am afraid it's going to be "trial and error" for a while.
As for HOW to load the JAVA apps and games on your CECT i9, here's how:
On your computer, with the i9 plugged in with the USB cable, drag the JAR or JAD files into the "RECEIVED" folder. After you're finished with everything you want to add, disconnect the i9. Touch your DOCUMENTS button, then "memory card," then "received," you will see your JAR/JAD files listed. Touch the file you want to install. The next screen, choose INSTALL. It will bring you back to the menu choices of "phone" or "memory card." Choose PHONE and select YES. It should give you a message when it has successfully installed. Then exit out to the main screen, touch the JAVA button. Select "Installed Java Software" and you should be able to use your newly installed JAVA apps and games.
Hope that helps.
Dec 23, 2008 | Dual Electronics CECT P168 Cellular Phone
Dual Electronics CECT P168 Cellular Phone Logo
130 people viewed this question
Top Dual Cell Phones Experts
William Alequin
Computer Repairing
Computer Repairing
Shehu Pro
Shehu Pro
Are you a Dual Cell Phone Expert? Answer questions, earn points and help others
