Smoking Kenmore Washer
While running a load the washer started smoking (burning rubber). I took off the front and removed the belt. Belt was cooked at the motor pully. Motor and tensioner seem to turn fine, I fear it is the trans. The trans pully will turn clockwise by itself, counterclockwise it turns the whole transmission. The drum will turn ccw but not cw. A tag states the trans is not rebuildable. Questions: 1) Is it the trans? 2) Can or should the trans be rebuilt? 3)How tough is it to R&R the trans and where can I get a step by step to do so? Kenmore Model 417.90802990 Washer/Dryer
Thanks, John
  • Anonymous Aug 01, 2008
    We are having the same problem. Went to do a load in the washer and it sounds like it is spinning, but it is not moving at all. There is a strong smell of burnt rubber. How long does the factory warranty the product? This is the second unit we have had, same model. The first one we sent back because the dryer caught on fire.
  • 625 Answers
Try www dot partselect dot com they have exploded diagrams on appliances.
Posted on Dec 11, 2007
The bearings have been replaced but now it is smoking (mostly seems from the inside) and smells like the belt is burning, but the belt isn't hot. HELP!! :)
i think this washer has a heater with doing the bearing probably wires crosed over or damaged [heater goes on and no water smokes then ] ceck your wiring on the element green is ground.
Jan 22, 2013 | Maytag Neptune MAH5500B Front Load Washer
My washer wont spin or agitate and there was a burning smell
Hi
Older top load washers use a belt to drive to transfer the energy from motor to drum. However, if the belt slips, stretches, or breaks, it can cause friction and a burning smell, most likely a burning "rubber" smell. The belt is located either from the back access panel or from the underside of the washer. The solution is to replace the belt with a new one. To replace the belt you can open the back lid of the washer
To replace the belt carefully pry up on front washer top to release plastic keeper pins, remove 2 Phillips screws from beneath lower front washer panel, slightly lift upward on panel to release. Now remove old broken belt, push new belt beneath large tub pulley and put belt on small motor pulley. After this push back belt tension /idler arm, start belt on large tub pulley, turn tub pulley by hand to run belt on, release tension on idler arm. Replace front panel and lower top.
Hope this helps... Please post back if you need more information.
Daniel
Jan 30, 2011 | Kenmore 24032\24036 Top Load Washer
Smells like rubber burning and then the machine starting smoking...
probably the belt . Make sure the tub is turning freely . If not check for nail in one of the holes or an article of clothes jammed between tubs. If it turns freely just change the belt
Oct 29, 2010 | Frigidaire GLWS1339CS Top Load Washer
Load was to heavy and I smelt burnt rubber now no spin
Hi
Older top load washers use a belt to drive to transfer the energy from motor to drum. However, if the belt slips, stretches, or breaks, it can cause friction and a burning smell, most likely a burning “rubber” smell. The belt is located either from the back access panel or from the underside of the washer. The solution is to replace the belt with a new one. To replace the belt you can open the back lid of the washer
Please check this diagram for the part number F28(drive belt)--
Please post back for any further assistance.
Thanks
Daniel
Jul 24, 2010 | Frigidaire FWS833A Top Load Washer
Smell like burning rubber
if it smell's like rubber it likley is .. smell's like a belt driven and it needs a replacment belt & idler .. remove the two screws at the bottom of front panel an remove .. in the front center at the bottom .is the motor / belt and pump .. if there is black rubber in bottom / wala . the belt is burning . / look for pump leakage / this would get belt wet and slip.. thanks mm .
Dec 02, 2009 | Amana 3.2 cu. ft. Top-Load Washer
Replaced broken washer belt, but drum still won't spin.
you may have a bad bearing in a pulley,could be motor coupling. Take belt off and spin motor shaft and pulley both ways if it's free, then its more than likely not the motor. Now spin the drum with belt off and see if it does the same as with the belt on if it does it has to be a bad bearing or coupling to the drum. hope this helps
Aug 24, 2009 | Amana ALW480DA Top Load Washer
Washer started smoking
You might have overloaded the machine and the belt will smoke;the machine will still work,the items still might be wet due to the fact the machine couldn't spin fast enough.
May 04, 2009 | Kenmore 24032\24036 Top Load Washer
Smoking burning rubber smell from machine
Welcome
You said, frigidaire GLWS1349AS1 TOP LOADING WASHING MACHINE
pls help - is the machine done with- it set the smoke alarms off ???
Sounds like the belt is loose and smelled like rubber burning from spinning fast!
Change belt
Let me know.
Please remember to leave a rating
Oct 06, 2008 | Frigidaire GLWS1339CS Top Load Washer
Maytag Legacy top load washer is SMOKING!
this is a bogus website that is trying to push smelly washer product....no real fixes and there are other products out there for less just use bleach first
May 05, 2008 | Maytag Legacy Series Top Load Washer
Stacked kenmore tranny problem?
yep. belt started smoking because motor is turning and not the tranny.
Jan 15, 2008 | Kenmore 98702 Stacked Washer/Dryer
Washing Machines Logo
388 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
