Question about Admiral AAV7000A
Where is my cycling thermostat located on my Admiral dryer?
    President:
  • 1,776 Answers
Check at the rear of the dryer attached adjacent to the blower fan housing. Hope this helped and best wishes.
Posted on Sep 11, 2009
Does the heating element stay on continuously throughout a drying cycle?
No. The element is controlled by the operating thermostat located on blower housing .if its on all the time the hi limit near top of element should open and turn element off that part is nonresetable
Jun 17, 2015 | Admiral Dryers
Admiral dryer won't turn on or start
It could be a broken door switch. With the door open, look for the plastic tab that comes through the dryer frame. this is the switch. If it is broken, you know what the problem is. If not, depress the tab and carefully try to start the dryer. If it starts, then it is not your problem. I have changed two before. very simple.
Apr 24, 2014 | Dryers
Admiral Dryer Model #AGD4475TQ No Heat
This is very rare on a gas dryer but I have seen it. If you have already replaced all that other stuff I would say it has to be inside the timer. On one I worked on once I could remove that orange wire and the dryer would function ok so I ordered a new timer, they sent me a bad timer. Same problem. I finally got a working timer after going through a bunch of mess. That fixed it. So if all the other components are working it very well could be the timer.
Dec 02, 2013 | Admiral Dryers
I have an older Kenmore gas dryer model # 97260100 it heats up for 15 minutes then goes cold, drum continues to run can u give me any insight as to what needs to be replaced
The problem is either of the cycling thermostat, high-limit thermostat or the gas valve solenoid coils sitting on top of the gas valve assembly. Disconnect power then verify any of these condition by bypassing the thermostats. Refer to the image below and locate the thermostats.
Note: This is an image of an electric dryer but the thermostat and the thermal cut-off (cut-out) locations are the same.
Disconnect each of the thermostat wires then connect and insulate them properly. Once done, reconnect power and start the dryer. The gas valve solenoid coils are indeed faulty and both need to be replaced if the problem still persists. Click here for the procedure in replacing the solenoid coils.
Gas Valve Solenoid Coils Replacement Procedure
Either or both of the cycling thermostat and the high-limit thermostat are malfunctioning if the dryer continues to heat up with the thermostats bypassed. Disconnect power then reconnect the cycling thermostat wires but keeping the high-limit thermostat bypassed. Reconnect power then start the dryer. The high-limit thermostat is the culprit if the dryer continues to heat up. If not, then the cycling thermostat is the culprit.
Also do the other way; that is reconnecting the high-limit thermostat wires but keeping the cycling thermostat bypassed. The cycling thermostat is the culprit if the dryer continues to heat up. If not, then the high-limit thermostat is the culprit.
Replace the faulty thermostat and it should solve the problem.
Nov 08, 2010 | Kenmore 72872 Gas Dryer
Have a kenmore model # 110.72822101, where's the thermostat located, my dryer gets hot then cold
The cycling thermostat or the high-limit thermostat may not be the problem but rather the gas valve solenoid coils sitting on top of the gas valve assembly. Disconnect power then verify this condition by bypassing the thermostats. Refer to the image below and locate the thermostats.
Nov 08, 2010 | Kenmore 72822Gas Dryer
Admiral capacity plus stopped working mid cycle no power
When u press the knob to start the dryer is there a buzzing noise ???
If so i guess u nee to order a new moter ...
u can do it at..www.appliancepartspros.com
Jan 07, 2010 | Dryers
Dryer won't come on
and also change your cycling thermostat if your thermal fuse is bad chances are the thermostat is bad too
Mar 11, 2009 | Maytag Dryers
FRIGIDAIRE DRYER
I don't know what you mean when you ask about fuses since a blown fuse would stop power to the dryer, but I do know a common reason for a dryer to run and not produce sufficient heat is that it may be cycling on the "safety" thermostat. One common reason for this is that the "cycling" thermostat (which is the thermostat which the dryer should cycle on), located in the exaust air stream, is insulated with collected lint, which also lowers the air flow through the ducts. You may just need to thoroughly clean the accumulated lint. I would suggest buying the service manual for your dryer, if available, and go to the manuals troubleshooting guide.
A test for cycling on the safety thermostat is to run the dryer with a damp load and watch the flame through the small service door at the bottom of the dryer; if the flame stars cycling on and off every, say 15 to 30 seconds, then the dryer is cycling on the saftey thermostat, if the flame repeatedly burns for close to a minute or longer, than that is not the problem.
Feb 02, 2008 | Dryers
Admiral AAV7000A Logo
100 people viewed this question
Top Admiral Washing Machines Experts
Dan Webster
Dan Webster
Sal De
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
