Question about Samsung SyncMaster 171S 17" Flat Panel LCD Monitor
Samsung syncmaster 710t
When i plug the monitor in my computer it comes up with something about the resoulution can you tell me what this means and what i can do to solve the problem so i can get it working
    Problem Solver:
  • 19 Answers
The problem is main board inside monitor which is needed to be changed with new one. So I suggest you to take monitor in nearest samsung's service center.
Best regards
Posted on Jan 16, 2008
How do I replace the inverter in a samsung syncmaster 930B?
The 930B and the 710T use the same power supply/inverter boards. Below is a link to a repair guide for the 710T unit that should get you going in the right direction.
Jan 27, 2013 | Samsung SyncMaster 930B 19" LCD Flat Panel...
Syncmaster 920N 5 Minutes of dark Screen It takes 5 minutes for screen to light after computer has been awaken from "sleep" mode or if monitor has turned off while listening to music online.
Hello Dfrank,
The 920N units use the same power supply board that the 710T uses and it was a known issue with bad capacitors that fail. When they fail it can cause the issues that you are having - Either slow to show a picture, wavy display or no power and flashing power light. The boards can be repaired if you can do a little soldering, the parts are cheap. We have a step by step repair guide posted on our tech support web site at: This is an easy repair for a very nice monitor, well worth repairing it.
I hope this helps, if so please rate my solution.
Jul 28, 2011 | Samsung SyncMaster 920N 19" LCD Monitor
Not optimum mode recommended mode 1280 1024 60hz
Open your Siplay control panel and select resoulution 1280x1024 and for refresh rate select 60hz
Jun 27, 2010 | Samsung SyncMaster 710m 17" LCD Monitor
My Samsung syncmaster 2220WM will not stay on. It
The picture board on your monitor has been malfunctioning for quite the period but you did not notice it, since the screen goes blank, it means the picture board of your monitor has developed fault and will need to be replaced.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
Apr 25, 2010 | Samsung SyncMaster 2220WM 22" LCD Monitor
My screen does not come on when computer is turned on.I have a samsung syncmaster 2253lw as my main screen and have had both operating in the past at the same time.
Please check your plug if it is plug in properly or firmly. Locate the switch and turn it on again. If stil persist, try to inspect whether cpu is beeping while turning on. If its beeping something is wrong in your cpu or monitor depending upon the beeps.
Jan 27, 2010 | Samsung SyncMaster 731B 17" LCD Monitor
My Samsung Syncmaster 930B was working fine unti I disconnected and then reconnected it to my computer. Now I get a black screen with a roaming box that says, "check signal cable".
1st Pull all power from pc from the wall.Plug back in and start pc up.
While starting hold down the f8 key and select safe mode.
once in go to control panel and select display.
set resoulution to default 60 hz and screen size to 800 by 600.
You may need to readjust your screen again.
Hope this helps.
Jan 14, 2010 | Samsung SyncMaster 930B 19" LCD Flat Panel...
Samsung SyncMaster 243T blacklight
indeed, probably the backlight...
Nothing to do about that but repair or replace, sorry...
Nov 13, 2008 | Samsung SyncMaster 243T (Black, Silver)...
Samsung SyncMaster 171S 17" Flat Panel LCD Monitor Logo
144 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
