I have just changed cartridge and printer prints a plain sheet
SOURCE: Printer won't stop printing alignment sheet, following changing of ink cart.
my printer only printed 1 page out of 3 so now it wont stop. it pulls the paper in and comes out blank. this will keep going unless i turn it off. how do i reset my printer?
Posted on Jan 11, 2009
ginko
  • 19396 Answers
SOURCE: Brother MFC 4420C prints plain sheets of paper.
To start ensure that is not a software problem.
Go to Control Panel >> Installed Printers. Remove the printer. Install the printer again using the software disk or downloading the driver software from Brother website.
If that does not fix the problem, and the printer prints blank sheets, then it is usually a clogged printhead.
The printheads can be cleaned removing the ink carriage and soaking it in isopropyl alcohol overnight. If that does not work, then the printhead must be replaced.
Regards
Posted on Jun 17, 2009
  • 295 Answers
SOURCE: Replaced print head and cartridges and still not printing.
Open the kodak all in one home center on your desktop and click on [?] on top most right hand side. choose maintenance under general links and choose printhead cleaning. if this does not solve the issue, call kodak @ 1800 421 6699 and they will replace the printhead for you free of cost..
Posted on Sep 21, 2009
Papa Ray
  • 15 Answers
SOURCE: The printer prints fine on plain paper, but on
I'm not clear on your problem but you can try this<a href="http://www.richardsnotes.org/archives/2006/05/17/canon-i9900-printer-problem-and-solution/" >Link for simular problems.</a> You may find the solution there.
Posted on Nov 27, 2009
  • 35 Answers
SOURCE: When printing or copying, I just get blank sheets
You may need to clean the printer heads. First try going to your printers properties and you should have an option via troubleshooting to clean, if this does not help, look inside the printer depending on the model, near the cartridge, you'll find where the ink comes out. Take a damp qtip and wipe them good. They are most likely clogged. I cleaned mine with alcohol but I'm also a risk taker :). Hope this helps!
Posted on Mar 09, 2010
Installed new ink. it says out of alenment
Dennis: According to an old FixYa.com, urbanhookupz said: "You need to run a printer alignment page like you do when you put in new cartridges.
unplug your printer plug it back in.
open door and take out print ink cartridges.
put them back in and then close the door.
It should now prompt you to do a test alignment page.
now try and print it should solve the problem.
if it does not prompt you to do a test page
Aligning the Print Head
This operation must be carried out when using the printer for the first time.
Aligning the
Print Head positions allows you to print without shifts in the color registration.
Print head alignment is performed either automatically or manually. This section deals with
automatic Print Head alignment only.
?? Ensure that the Inner Cover is closed.
?? The Print Head can also be aligned from the printer itself.
1.With the printer on, load a sheet of Letter-sized plain paper in the Sheet
Feeder.
2. Hold down the RESUME/CANCEL button until the POWER lamp flashes four
times.
1 With the printer on, load a sheet of Letter-sized plain paper in the Sheet
Feeder.
2 Open the Printer Properties dialog box.
See "Opening the Printer Properties Dialog Box Directly from the Start Menu" on
page 28.
3 Print the pattern.
(1) Click the Maintenance tab.
(2) Click Print Head Alignment."
May 26, 2015 | Canon MX340 AllInOne InkJet Printer
Scanner failure align the cartridge
To Align the new ink cartridge
The HP All-in-One prompts for an alignment of the cartridges every time a print cartridge is installed or replaced. Follow these steps to align the print cartridges from the control panel.
  1. Load unused, plain, white letter, A4, or legal paper into the input tray. note.png
    NOTE:If colored paper is loaded in the input tray when the print cartridges are aligned, the alignment will fail. Load unused, plain, white paper into the input tray, and then try the alignment again.
  2. Press Setup.
  3. Press 6 to select Tools.
  4. Press 2 to select Align Print Cartridge.
    The unit prints a print cartridge alignment sheet.
  5. Load the alignment sheet print-side down and top first in the center of the document feeder tray, and then press OK.
Dec 07, 2014 | HP Officejet 4355 All-In-One InkJet...
How tochange the ink cartridge
Open 'Printer properties' and go to 'Maintenance' page. There should be a button called 'Replace ink cartridge'. Click on it and follow the instructions...
Alternatively...if a cartridge is already indicating 'empty', opening the printer lid (with printer power on) should move the cartridges to the 'change position'. Replace the cartridge and close the lid when finished.
Aug 25, 2014 | Epson Expression XP-200 Inkjet...
How do I change the cartridge region from a xerox workcentre 3550
The toner cartridges have a small CRUM chip fixed on the end of each tube. If you change them from a previously empty cartridge then it will still show empty. You just can't fool them.
Good Luck.
Jul 14, 2014 | Xerox Corporation WorkCentre 3550 Laser...
How do you install an ink cartridge on an HP Officejet 4315 All in one Printer that I have had given me, with everything but the instruction book. Can you also confirm that the cartridge numbers are 27...
Working with print cartridges
To ensure the best print quality from HP All-In-One, you will need to perform some simple maintenance procedures and when prompted by a message on the display replace the print cartridges.
A) Handle the print cartridges
Hold the print cartridges by their black plastic sides, with the label on top. Do not touch the copper-colored contacts or the ink nozzles.
Note : Handle the print cartridges carefully. Dropping or jarring cartridges can cause temporary printing problems or even permanent damage.
B) To replace the print cartridges
1) Make sure the HP All-In-One is off whenyou open the print cartridge door to access the print cartridges, the Hp A-ll-In-One will not release the cartridges for changing. You might damage the HP All-In -One. If the print cartridges are not docked safely on the right side when you try to remove them.
2) Open the print cartridge door.
The print carriage should now move to the far right side of the HP All-In-One. If the print cartridge does not move to the right side, close the door. Then trun the HP-All-In-One offm and then on again.
3) Wait until the print carriage is idle and silent, and then lightly press down in a print cartridge to release it.
If you are replacing the tri-color print cartridge, remove the print cartridge from the slot on the left.
If you are replacing the black print cartridge, remove the print cartridge from the slot on the right.
4)Pull the print cartridge toward you out of its slot.
5. If you are removing the print cartridge because it is low or out of ink, recycle the print cartridge.
6. Remove the new print cartridge from its packaging and, being careful to touch only the black plastic, gently remove the plastic tape by using the pink pull tab.
Caution Do not touch the copper-colored contacts or ink nozzles.
Touching these parts can result in clogs, ink failure, and bad electrical connections.
7. Slide the new print cartridge forward into the empty slot. Then gently push on the upper part of the print cartridge forward until it clicks into the socket.
If you are installing the tri-color print cartridge, slide it into the left slot.
If you are installing a black print cartridge, slide it into the right slot.
8. Close the print cartridge door.
9. If you installed a new print cartridge, the print cartridge alignment process begins.
10. Make sure you have plain paper loaded in the input tray, and then press OK.
The HP All-in-One prints a print cartridge alignment sheet.
11. Load the print cartridge alignment sheet print side down and top first in the center of the document feeder tray, and then press OK.
The HP All-in-One aligns the print cartridges. Recycle or discard the print cartridge alignment sheet.
Align the print cartridges
The HP All-in-One prompts you to align cartridges every time you install or replace a print cartridge. You can also align the print cartridges at any time from the control panel or by using the software you installed with the HP All-in-One. Aligning the print
cartridges ensures high-quality output.
To align the print cartridges from the control panel when prompted
1. Load letter, A4, or legal unused plain white paper into the input tray.
Note If you have colored paper loaded in the input tray when you align the print cartridges, the alignment will fail. Load unused plain white paper into the input tray, and then try the alignment again.
If the alignment fails again, you might have a defective sensor or print cartridge. Contact HP Support. Go to www.hp.com/support. If prompted, choose your country/region, and then click Contact HP for information on calling for technical support.
2. Load the print cartridge alignment sheet print side down and top first in the center of the document feeder tray, and then press OK.
To align the cartridges from the control panel at any time
2. Press Setup.
3. Press 6, then press 2.
This selects Tools and then selects Align Print Cartridge.
4. Load the print cartridge alignment sheet print side down and top first in the center of the document feeder tray, and then press OK.
Black Cartrige no . :27/21
Tricolor Cartridge no . 22
Hope this helps.
have a good day.
Dec 04, 2009 | HP Officejet 4315 All-in-One Printer
Tops and bottoms of letters are cut off. I have changed the ink cartridge
Replace the old ink cartridge.
Verify that the unit is on. The On button is lit when the unit is on. If the device is not on, press the button to turn on the unit. Open the print cartridge door. The print carriage moves to the far right side of the unit. Wait until the print carriage is idle and silent, and then lightly press down on a print cartridge to release it. When replacing the tri-color print cartridge, remove the print cartridge from the slot on the left. When replacing the black or photo print cartridge, remove the print cartridge from the slot on the right. Pull the print cartridge toward you and out of its slot. If the print cartridge is being removed because it is low or out of ink, recycle the print cartridge. Remove the new print cartridge from its packaging. Remove the plastic tape by using the pink pull tab. Removing the Tape from the catridge.
  1. Will have Copper-colored contacts.
  2. Plastic tape with pink pull tab ( must be removed before installing ).
  3. Ink nozzles under tape
  4. The HP All-in-One prompts for an alignment of the cartridges every time a print cartridge is installed or replaced. Follow these steps to align the print cartridges from the control panel.
  5. Top & Bottom not printing properly.
  6. Load unused, plain, white letter, A4, or legal paper into the input tray
  7. If coloured paper is loaded in the Input tray when the print catridges are aligned, the alignment will fail. Load unused, plain white paper into the input tray when the Printer catridges are aligned, the alignment will fail. Load and unused plain white paper into the Input Tray and then try the alignment again.
    1. Press 6 to select Tools .
    2. Press 2 to select Align Print Cartridge The unit prints a print cartridge alignment sheet.
    3. Load the alignment sheet print-side down and top first in the center of the document feeder tray, and then press OK. Now the printer will print properly.
Jul 29, 2009 | HP Officejet 4315 All-in-One Printer
Hp2210 message ''press enter to align cartridges'',
from user manual::
To align newly installed print cartridges
1. Make sure you have letter or A4 unused plain white paper loaded in the input tray.
NOTE: If you have colored paper loaded in the input tray when you align the print cartridges, the alignment will fail. Load unused plain white paper into the input tray, and then try the alignment again.
Contact HP Support. Go to www.hp.com/support. ....
2. Load the print cartridge alignment sheet print side down on the left front corner of the glass with the top of the page to the left.
3. Press the Scan button.
Score the solution and download the manual if you need it
Mar 24, 2009 | HP PSC 2210 All-In-One InkJet Printer
I have a hpdeskjet f2180 and need to change the ink cartridges. How do I get to the cartridges to change them !
Installing print cartridges
  1. Make sure the HP All-in-One is on. CAUTION: If the HP All-in-One is off when you open the print cartridge door to access the print cartridges, the HP All-in-One will not release the cartridges for changing. You might damage the HP All-in-One if the print cartridges are not docked safely when you try to remove them.
  2. Open the print cartridge door. Figure 1: Opening the print cartridge door c00906461.jpg Make sure the print carriage moves to the center. If it does not move to the center, turn the device off and then turn it back on again.
  3. Remove the tape from both cartridges. Figure 2: Removing the tape from a cartridge c00651128.gif CAUTION: Do not touch the copper-colored contacts or re-tape the cartridges. Figure 3: Copper-colored contacts c00651129.gif
  4. Hold the cartridges with the HP logo on top.
  5. Insert the tri-color cartridge in the left cartridge slot and the black cartridge in the right cartridge slot. Figure 4: Carriage slots c00853116.jpg Figure 5: Inserting the tri-color cartridge in the left slot c00853117.jpg
  6. Make sure you push the cartridges in firmly until they snap into place. Figure 6: Pushing the cartridge in firmly c00853118.jpg Figure 7: Tri-color cartridge and black cartridge correctly installed c00853119.jpg
  7. Close the print cartridge door. Figure 8: Closing the print cartridge door c00906462.jpg
Aligning print cartridges The HP All-in-One prompts you to align cartridges every time you install or replace a print cartridge. You can also align the print cartridges at any time from the control panel or by using the software you installed with the HP All-in-One. Aligning the print cartridges ensures high-quality output. NOTE: If you remove and reinstall the same print cartridge, the HP All-in-One will not prompt you to align the print cartridges. The HP All-in-One remembers the alignment values for that print cartridge, so you do not need to realign the print cartridges. To align newly installed print cartridges
  1. Make sure you have letter or A4 unused plain white paper loaded in the input tray. The HP All-in-One prints a print cartridge alignment sheet. NOTE: If you have colored paper loaded in the input tray when you align the print cartridges, the alignment will fail. Load unused plain white paper into the input tray, and then try the alignment again.
  2. Load the print cartridge alignment sheet print side down on the left front corner of the glass with the top of the page to the left. Figure 9: Loading the alignment sheet c00906464.jpg
  3. Press the Scan (c00906465.jpg ) button. The HP All-in-One aligns the print cartridges. Recycle or discard the print cartridge alignment sheet.
Jul 29, 2008 | HP Office Equipment & Supplies
13 people viewed this question
k24674
