Canon MP510 skips and makes 2 small blank lines going DOWN the pages, in only cyan and magenta. The two lines show up on the Nozzle Check Pattern but only on cyan and magenta.
    Novelist:
  • 85 Answers
If you have lots of flashing error lights or electrical problems then it is likely to be electrical.
However, if like most... and your printer has just been left unused for some time? You probably have an ink clog on the cyan and magenta.
Provided it worked OK before a period of non-use? Then you just need to use a PRINT HEAD CLEANING KIT to unclog the tiny jets.
Magic Inkjet Flush usually works a treat on those!
Magicis ideal for unclogging the tiny jets on any Canon, Epson HP andremoving those horrible white lines which usually appear in prints whendried ink clogs several jets...
So if yours appears to be a clog? all you should need to do is to usethe Magic Inkjet Flush kit to soak the print head and you should beprinting again like new.
You can read more here:
How to Clean, Fix, Repair, Unclog, Dry, Clogged Print Heads on CANON, EPSON, HP, Lexmark, Dell, Olivetti etc…
You are covered by a 30 day money back guarantee if not.
Good Luck!
Tinteiros (Ebay)
Posted on Sep 12, 2009
Why is my Canon Pixma 4820 suddenly leaving lighter lines through color pictures.
Worn print head. And for what they charge for a stinking print head you can get a new printer for less with a warranty to boot!
Mar 24, 2017 | Office Equipment & Supplies
Banding as they call this and skiped print is probably caused by the the print head being PARTIALLY BLOCKED. Do a nozzle check and check the 4 colour matrix patterns that are printed out do NOT have ANY missing lines. Mine did till I used recovery fluid to soak the head over 2-3 days this cleared the problem completely.
Sep 11, 2009 | Office Equipment & Supplies
Do a deep clean and printhead alignment on your device and then after that try it again and the problem should be corrected already....
MP830 Canon - NOZZLE CHECK does not print light cyan line
You will need a new printhead, QY6-0061-000, runs around $60.00 well worth it for your machine.
Sep 08, 2009 | Canon PIXMA MP830 All-In-One InkJet...
When printing a red line appears about every 8mm through the all of the page i am useing a epson rx630 fred
It means some nozzle not perfect. If you check nozzle, there is missing lines for some nozzle. Example : Print blue color ( 100% cyan + 100% magenta). If some point of cyan head is clog, the output will be shown that at some lines just show magenta. It repeated. Yous said every 8 mm, so, you must print it at best photo quality. If you have print at best photo quality, and lines still appear, it must some nozlle badly clog. Try do head cleaning, wait for 30 minutes. Check Nozzle.
Jun 25, 2009 | Epson Office Equipment & Supplies
Canon Pixma MP630 not printing all colours
Colour not printing. Check vent hole on cartridge not blocked by glue or bit of the orange tape, cleared mine with knife now works fine
Feb 19, 2009 | Canon PIXMA MP600 all-In-One InkJet...
IP4300 only recognizes magenta OR cyan
1. Get compressed air
2. Run Printhead under HOT water, do not worry about contacts getting slightly wet.
3. Blow compressed air with straw attachment into screens where the cartridge nozzle sits on printhead. then let it sit and dry.
4. reinstall print test page
5. if this fails open paint/photoshop and print a page of the color that is not printing correctly. rinse and repeat until colors flow freely.
I have several ip4300s and I have yet to give up the ghost on a printer with a clog ujsing this method.
Jan 04, 2009 | Canon PIXMA iP4300 InkJet Photo Printer
Printer doesn't print even with new ink cartridges.
turn the printer i turned on and Press the cleaning button ,. Cleaning takes about two minutes, the printer makes some noise when it finishes you run a nozzle check for print quality and reset the cleaning cycle.
load paper . go to the printer menu as follows: click Control Panel, and then double-click Printers. Select the Epson printer if have more than one printer is installed. Click File, click Properties, click the Utility tab, then click the Nozzle Check icon.
The printer will print a Nozzle Check pattern in black, and in cyan, magenta, and yellow. Each staggered horizontal and straight vertical line should be complete, with no gaps in the dot pattern. If any dots are missing, clean the head again.
If your software is different, and does not have these options, you can do it this way:
1. Same as above.
2. Same as above.
Turn off printer and computer. Disconnect interface cable from printer. Load paper. Hold down the load/eject button and press the power button to turn on the printer. Release both buttons.
3 Same as above.
4 Turn off printer and reconnect the interface
May 17, 2008 | Lexmark X1240 All-In-One InkJet Printer
177 people viewed this question
jasbo
jasbo
