Question about Maxtor DiamondMax Plus 8 30 GB Hard Drive
Hard Drive capacity up to 8GB
Hi, i have a Maxtor HD (6E030L0), and i recently install on it windows 98 (before i had windows XP), and when i was creating a partition for windows 98 and one for my data, all this using a win98 bootdisk and fdisk, it appeared on screen that my HD full capacity was of only 8GB, but i know that my hardrive has a capacity of 30GB. I was doing some research and i found that te problem could be that the bios version of my mainboard was to old, but it has the latest version (my mainboard is a MSI model: MS-6738).
Besides, when i had winXP it show a 27GB harddrive, so maybe the bios is not the problem but that you should know it.
  • minutero Dec 11, 2007
    sorry, but i'm not sure if i understand what are you saying. I think you said i have to give a Fat32 format to my hdd, thing i've already done when creating the partitions.
    I'm from South America (i speak spanish) so all those contractions are hard for me to understand them.
I have Windows XP with service pack 3. My system no longer recognizes the Maxtor 3200 external hard drive. Do I need to get an updated driver to the hard drive? When I first connected the Maxtor HD. ...
When you plug in via USB, does the USB recognize it and not display as HDD? If that is the case, then it's probably disabled somehow. Access Computer management, and check from there.
If that doesn't work, try on a different computer. If it doesn't work, your HDD has gone faulty. And if you recently changed your board, make sure you have a high speed USB port.
May 24, 2010 | Maxtor Personal Storage 3200 (U01E200) 200...
Product Will not install
According to the Maxtor website, this device is only supported on Windows Vista, XP, and 2000. It does not work with Windows 95/98/ME.
Jul 06, 2009 | Maxtor OneTouch III R01E080 80 GB USB 2.0...
Maxtor One Touch II - installation Software
I have a disk that worked for me and I am running windows xp. I also have the website address that is supposed to have the 98 drivers which could work perhaps.
Guess you could try them first and if that doesnt work I could perhaps make a backup of the disk/package/mail/ worth anything?
Feb 05, 2009 | Maxtor One Touch II E01H300 (EO1H300) 300...
Only 100gb of my 200gb hardrive are showing
Welcome to the wonderful world of windows disk size limitations.
What you are running into is the Windows 137GB Capacity Barrier AKA the 48-bit Logical Block Addressing Support for ATA (IDE), Serial ATA or ATAPI disc drives.
In English this means windows will only “acknowledge” between 127 and 137 Gig of a disk drive without some updates.
In most cases after he latest Service Packs are installed, any additional gigabytes will show up as unallocated space on the drive and you can create a second partition with the Windows disk management tools. Unfortunately this will mean that you have 2 partitions on the drive (if you placed your os on the drive or partitioned it before the updates were installed.).
If this is a secondary drive (in other words your OS is on a different disk drive), install all of the system updates first, you should then be able to format the entire drive as one partition.
Dec 20, 2008 | Seagate (ST3100203U2-RK) (ST3100203U2RK)...
Dell Dimension 2400 - Adding second HD
set the jumper on the maxtor to cable select and see if that fix's things ?
Nov 29, 2008 | Dell Dimension 2400 PC Desktop
Hard drive
hi dear
use a cd booting
in command prompt c:\
type c:\fdisk /mbr
to fix your master boot record\
and make your partiiton active.
after that installing your windows XP
Mar 15, 2008 | Maxtor Hard Drive
Maxtor OneTouch II 300Gb can't recover data after a system restore
I had the same problem a few weeks ago.
The way I solved my problem was to make sure when I restored Windows to the default settings that I did it up to the same support packs and hot fixes then when backing up the system with the Maxtor HD. It took me many days to figure this out... was written it the Maxtor HD documentation and it works fine.
Hope this helps.
Jan 15, 2008 | Maxtor OneTouch II external hard drive...
New maxtor sata II/300 h/d installation
throw windows in the trash bin and get Linux !!!
goto Maxtor website and download one of their drive install/diagnose/format programs (such as MaxBlast 5). Run it making sure to select appropriate options for XP.
Dec 27, 2007 | Maxtor Hard Drive
My hard drive shows only 1.5 GB instead of 100
is it correct that you installed XP from an "upgrade" pack?
when you installed XP did you convert the file system to NTFS?
Dec 26, 2007 | Maxtor Hard Drive
Maxtor 500gb internal hard drive
To fix/restore to full capacity, you may need to delete the existing partition and re-partition then reformat again.
Most old computers have limitations on the CMOS/BIOS as to how big the capacity of the HD that it can recognize.  Windows however would recognize big HD size and therefore can partition, format and check.
Alternately, a third party disk utility program may be used such as Partition Magic.
Hope this be of some use/help. Post back how things turned up or should you need additional information.
Good luck and kind regards.
Oct 26, 2007 | Maxtor Hard Drive
Maxtor DiamondMax Plus 8 30 GB Hard Drive Logo
147 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
