Question about Refrigerators
When we plug in the kegorator, the kegorator beeps and the temperature gauge flashes EE. What does that mean?
    Scholar:
  • 149 Answers
EE is an electrical related error. Check wiring on the back of the panel and and temp sensor to make sure nothing has gotten lose.
Hope this helps,
Bill
Posted on Sep 11, 2009
I've owned it for about a year and have not had any trouble. But my Danby Kegerator just started beeping and flashing EE on the display one day and it won't cool. I had to unplug it. Any ideas
An EE error code means that you have loose connections (loose temperature sensor connections) check all the wires for a loose connection
temperature touch pad
the units main control board
the control board is in the back of the unit there is a panel covering in the middle lower back near the compressorInside your unit on the left side in the lower rear theres a vented piece of plastic pry that off thats the temperature sensor make sure all the connections are tight
If the error does not clear then your temperature sensor is faulty
you can get a new sensor at
www.repaiclinic.com.or
or at
www.appliancepartspros.com
hope this helped
Good Luck!
May 01, 2012 | Danby DKC646BLS Full Size / Pony Beer Keg...
When I plug it in the screen shows EEE, and beeps continually. It is around 65 degrees in the area. Nothing clears it or stops the beeping. It worked great yesterday.
The error code E:EE means the breadmaker thinks the temperature is too cool i.e below 59 degrees F or 15 degrees Celsius.
As you say the temperature is actually 65 degrees - then this means that the temperature sensor on the Bread maker has failed and will need to be replaced.
The EEE code and beeping will continue until the failed sensor is replaced and as this is a component failure it cannot be reset unfortunately.
Thanks for using FixYa.
Sep 11, 2011 | Regal Ware K6725 Kitchen Pro Bread Maker
Getting an "EE" and it
Check this against your code, but iff EE is flashing you may have an internal electrical fault that needs to be checked out by a repair person.
  1. Frigidaire
  2. GE
  3. Panasonic
  4. Sharp
  5. Whirlpool
Sharp commercial grade microwave codes....
EE Mode Reason Action Required EE 1, EE 2 Magnetron failure
Call for service*
EE 3 Both magnetrons failed Call for service. EE 4 R-23GT, R-24GT and R-25JT only
Voltage too high Follow instructions on page 5 of Operation Manual under VOLTAGE SELECT to change from 208V to 230V. If problem is not corrected, call an electrician. EE 5 R-23GT, R-24GT and R-25JT only
Voltage too low Follow instructions on page 5 of Operation Manual under VOLTAGE SELECT to change from 230V to 208V. If problem is not corrected, call an electrician. EE 6, EE10, EE16 Thermistors failure Call for service. EE 7 Exhaust air temperature too high
Check that nothing is blocking air intake openings on oven back or that oven exterior is very hot. Correct. Wait a few minutes and try again. If problem persists, call for service.
EE 8 Circuit failure Call for service. EE 9 Maximum time is exceeded
Check page 11 in the Operation Manual. Touch STOP/CLEAR pad, and reprogram correctly.
EE 0 Fan lock error Call for service. EE17 Magnetron temperature too high
Touch STOP/CLEAR pad. Wait a few minutes and try again. If problem persists, call for service.
* EE 1 and EE 2: Can continue to use oven before service; however, check food carefully as additional cooking time will be needed.
Any time the EE is flashing, the servicer should be called. When EE is not flashing, check the reason and correct. Service is not necessary.
Aug 20, 2011 | Microwave Ovens
Error code on keypad EE L before screen went out. What does it mean.
Hi
Error code EE means temperature sensor issue. This error appears when the oven temperature turns bad or when a high temperature is detected by the sensor. Try and unplug the range for 1-2 hours and check if this clears the error. Hope this helps... Please post back if you need more information.
Daniel
Apr 10, 2011 | Sharp Insight KB3425LK KB3425LW Electric...
The oven warms up and then starts beeping and flashes f10 err.
The "F10" oven error code means "Runaway temperature".
If you have technical skills, you can try to diagnose and repair yourself, otherwise, call a qualified appliance repairman.
Locate the temperature probe wire plug at the Electronic Oven Control (EOC) and measure its resistance. It’s supposed to be about 1100 Ohms at the room temperature.
If the reading is wrong, replace the oven temperature probe.
If the reading is correct, replace the EOC.
Jan 28, 2010 | Kenmore Ovens
The oil light keeps flashing with a beep beep sound. i changed the oil pressure switch and the problem still continues.
DON'T DRIVE IT !!!! DON'T START IT AGAIN UNTIL YOU PUT A TEST GAUGE ON IT. you MUST have a gauge put on it to check for pressure. flashing and beep beep mean no pressure... not good. explain in detail how/when this happened ??
Dec 08, 2009 | 2001 Volkswagen Passat
Danby Kegerator is beeping and flashing EE and won't cool
I am having the same problem seeing if you found a fix??
Aug 26, 2009 | Danby DKC645BLS Compact Beverage Cooler
My 480 NT Royal Cash Managment System shows "EE" on the screen and beeps not stop
turn the machine to PRG - unplug for 20 seconds. while pressing clr plug back in
May 25, 2009 | Royal Office Equipment & Supplies
Whirlpool Oven beeps and flashes PF3 when oven is on
This is usually a case of over temperature - in which case the temperature sensor need to be replaced since it should be regulating the oven temperature
Aug 31, 2008 | Ovens
Refrigerators Logo
53 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
