Question about Husqvarna Backpack Blower 25cc, 140 Mph, Model# 125bt
Is there a choke or primer? - Husqvarna Backpack Blower 25cc, 140 Mph, Model# 125bt
  • 124 Answers
Most models have both.
Posted on Sep 14, 2009
I have a Ryobi S430 4 stroke Weed Eater Trimmer. How many times do i pump the choke (primer) to start cold?
Page 4 and 14 of the manual. A choke is just a device that reduces air flow to the carburetor by closing a flap. You don't pump it, you just move it to the full choke position. I think you may be confusing the 'primer bulb' which pumps fuel from the tank to the carburetor.
http://lawnandgarden.manualsonline.com/manuals/mfg/ryobi/s430_ry34441.html
To start a cold engine:
? Slowly press the primer bulb 10 times.
NOTE: After the 7th press, fuel should be visible in the primer bulb. If it is not, continue to press the primer until you see fuel in the bulb.
? Set the choke lever to FULL CHOKE position.
? With the throttle trigger at idle, pull the starter handle sharply until the engine attempts to run. Do not pull the starter handle more than 4 times.
? Set the choke lever to HALF CHOKE position.
ryobi s430 4 cycle weed eater manual Google Search
Mar 20, 2018 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
4 lawn mowers same problem wont start until I prime the by hand. Briggs Stratton 917.387500/ 12AV566n01124987/20043/SDSP2245D Will the same primer bulb fit the above mowers.
If its identical it should work ,if not take the old one to a mower shop,to get correct one and make sure the choke is going right on when the cable is in choke position.
Aug 05, 2014 | Ryobi Snap In Primer Bulb Pump 683974 ...
Primer pump lacation
Not all mowers use this feature to start their fuel flowing. Try using choke for 2-3 pulls, and reduce to half-choke if it starts. If all else fails, make sure it's not flooded by opening up the throttle for a few pulls.
May 06, 2014 | Poulan Pro 22" Self Propelled High Wheel...
Fuel primer
The primer bulb fills the bowl of the carburetor on initial start-up. Most primer bulbs are depressed 4-6 times. Set the choke at half and either pull the starter cord four times. If it doesn't start, re-prime and take the choke off.
Mar 16, 2014 | Garden
I have a Coleman Powermate Maxa 3000 OTV generator that is powered by the Techumseh Enduro Overhead Valve 5.5HP engine. To start the engine take an act of congress. I can't find any "choke" so its like...
I'm working on one right now. Make sure that all the gas in it is FRESH!!!. Then push the red primer bulb about 6 times. It should start. If it does but dies, push the primer as it dies to keep it going. If it does not start, push the primer 6 more times. You are right-there is no choke.
Oct 03, 2010 | Computers & Internet
I have a Sears craftsman lawn mower that will not stay running. The model # in the engine is 12h887-2314-E1. Can you give any suggestion?
Your engine parts list can be found here: http://www.briggsandstratton.com/maint_repair/manual_and_more/docsearch.aspx?enginelookfor=12h887-2314-E1
There are 3 different carb variations on this unit.
Primer type
Choke type
Auto-choke type?
On the Primer type with the plunger on the side of the carb the primer bulb gets a pin hole in it that allows air to be drawn through the primer bulb. So the engine will start an then die after priming.
On the Choke type carb debris in the bottom of the float bowl AND bowl nut will cause this.
On the Auto Choke type there is a diaphram under the carb that can get damaged and allow airflow where there should be fuel flow.
I am pretty sure that your mower has the float bowl on it. remove the bowl nut... take some carb cleaner and spray directly up into the hole the bowl nut screws into and clean it. Then also spray around the float needle.
If your still having problems.. just fro grins remove the fuel supply line to the carb and check for fuel flow. If there is little or no flow either the fuel slector is off or the fuel tank outlet has debris covering the tank outlet hole inside the gas tank.
Thanks for using FixYa.
Kelly
Jul 04, 2010 | Garden
I can't start my powerwasher. Where is the choke?
This Power washer has a 3.75 hp Briggs and Stratton Engine. It does not have a choke but does have a primer bulb. You must depress the primer bulb at least 3 times to start the engine. The primer bulb is on the side of the carb. It can be black or red. If your still unable to locate the primer bulb please provide your ENGINE model number and I will provide you a link to a diagram for the location of the primer bulb.
Kelly
May 29, 2010 | Briggs & Stratton Gas Pressure Washer...
I don't know how to start the blower (gas powered) and I don't have the owner's manual...any help is appreciated. There's the choke, the primer, and the blow strength gauge
I would push the primer in about 3 times, then pull the choke out, then try and start it. It probably won't start, but it might turn over. Then push the choke in and try starting it again. It should start within the next 2 pulls.
Sep 01, 2009 | Poulan Featherlite Gas Blower, with Low...
Husqvarna Backpack Blower 25cc, 140 Mph, Model# 125bt Logo
49 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
