Question about Bosch Axxis WFL 2060 Front Load Washer
Bosch hydrosensor washing machine WFP 3300 is flashing F03, can anyone help please?
3 Suggested Answers
blueextc3221
  • 15935 Answers
SOURCE: Bosh WFP 3300 HydroSensor keep blowing up fuses
It appears your motor/motor controller has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 14, 2010
Daniel S
  • 4323 Answers
SOURCE: Bosch Washing machine WFP 3300 Fault
Hi
F01 is a low water pressure error and is caused when the washer won't fill water, check the water inlet valve if that is fine and there is no clogs in the inlet hose then the water level switch/pressure switch should be replaced. Hope this helps...please post back for further assistance.
Daniel
Posted on Sep 12, 2011
Bosch shx36l05uc/21: After running diagnostics the 'wash' button keeps flashing, can someone tell me what the problem is?
Hi Jeff, As you can see there's 3 different Bosh washing machine models, Hope you can find your error code.... CHEERS..
Bosch Washing Machine Fault Codes
F16 - Door lock error
F17 - Inlet valve error detected
F18 - Drain error detected
F23 - Anti flood device has been activated
F34 - Door lock error
F42 - Motor fault
F43 - Motor fault
F44 - Motor fault
Bosch WAE Range Washing Machine Fault Codes
F16 - Door lock problem
F17 - Inlet valve
F18 - Drain pump
F21 - Motor
F23 - Anti flood system activated
Bosch WFP Range Washing Machine Fault Codes
F01 - Water intake timeout
F02 - Heating timeout
F03 - Draining timeout
F04 - Motor fault
F05 - Uncontrolled motor startup
F06 - Short on NTC Detected on hot water intake
F07 - Open circuit NTC Open circuit wiring
F08 - Door open when program started
F09 - Unexpected heating
F10 - Communication error
F11 - Overheating
F12 - Short circuit
F13 - Mains voltage too high
F14 - Mains voltage too low
F15 - Faulty temperature sensor on motor PCB
F16 - Faulty rinse sensor Displayed only in test
Mar 30, 2016 | Bosch Dishwashers
Display flashes f03....anyone know anything...?
FO3 is a Temperature sensing fault
the washing machine not heating on wash or dry settings.
Nov 23, 2014 | Hotpoint Washing Machines
How to use the delay timer on my washing machine
Each time you press it it changes the amount of time before the chosen program will be finished
eg 4hr means in 4 hours the cycle will finish
Sep 27, 2014 | Bosch Washing Machines
Fault code f03
Not sure that the model you have given is correct, but generally F03 on an older Bosch machine indicates the the pump out has exceeded the allocated time, check the filter, hoses and outlet connection for debris, foreign objects etc.
Feb 24, 2013 | Bosch Washing Machines
Error code F03 flashing and beeping
hello,
what this error F03 code mean is an indication of over flow of water from the sensor reader temperature which might cost a chance of loose wire connection on the water temperature.
what you are to do to fix up the problem is to open (unscrew) the washer and then fix up the wire that have loose it position then clean up all liquid around the wire and the panel and (screen).then couple it pack make sure all power supply are OFF before doing this .
thank you.
Jun 12, 2010 | Bosch WFMC 3200 Front Load Washer
Plastic rectangle part of the door lock of bosch wfp 3300 is broken
that whole piece is part of a switch. you must take off the front panel to fix. not a easyfix if you dont know how.
Feb 26, 2010 | Bosch WFMC 3200 Front Load Washer
Jan 23, 2009 | Washing Machines
Bosch Axxis WFL 2060 Front Load Washer Logo
356 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
