Question about GE Spacemaker Washer and Dryer Electric Laundry Center
GE Spacemaker Washer knob broken
The knob which is used to choose the washing setting just turns round and round. It sort of will pull out, but not like it would if it was working. It won't go to any of the wash settings. All it does is spin around. Help??
  • 93 Answers
Need a new timer
Posted on Sep 12, 2009
Dial won't set
you can possibly remove the knob itself, and see if you can turn the dial itself. if you can, then you can probably see the knob is broken. if if the shaft turns, but doesn't move the gears, then you will just need a new dial switch.
Nov 19, 2013 | GE Profile WPRE6100G Top Load Washer
What is the capicity of a GE WWA7600S washer
Here is the user's manual:
http://genet.geappliances.com/DocSearch/pdf/49-9810.PDF
They never talk about weight or capacity other than
Setting the Controls
Use the Suggested Fabric and Cycle Settings guide ~ Select Rinse Temperature.
to help you make the proper selections.
~ Select Wash Spin Speed.
~ Push Cycle Selector knob in and turn clockwise to
your selected wash setting. If you wish to change setting
~ Select Water Level. ~ Pull Cycle Selector knob + START out to start the washer.
SMALL: Washer is less than 1/3 full of clothes.
MEDIUM: Between 1/3 and 1/2 full.
LARGE: Between 1/2 and 2/3 full.
This washer will pretty much take anything you can throw at it. It was a competetor of the Maytag large capacity washers. As long as you follow the loading guide above you are not going to hurt it.
Thanks for choosing FixYa,
Kelly
Oct 17, 2010 | GE Washing Machines
GE Spacemaker Washer/Dryer wont start only washer or only dryer
Did you figure out a solution to this problem? I just bought a brand new Frigidaire and it is doing the exact same thing, except it never worked properly. I thought it was the unit and had HH Greg bring another out but the 2nd one did the same as the first.
Feb 09, 2010 | GE WSM2700W Unitized Spacemaker Washer and...
Very hard to pull out washer knob to start cycle
you must,bring to the repairman, to check what is the prpblem.
check this one.
http://www.washingmachineadvisor.com/1400-spin-washing-machine
Feb 05, 2010 | GE Spacemaker Washer and Dryer Electric...
GE spacesaver stack washer & dryer: The
the dryer won't heat up. everything else works. the drum goes around with clothes in it. it just won't heat up .
Jan 03, 2010 | GE Spacemaker Washer and Dryer Electric...
Ge Spacemaker Laundry the washer knob popped out
take knob off again and look at the stem where the knob goes does it have a round side and a flat side? if so the knob will have the same profile thats the way it goes on
Sep 09, 2009 | GE Spacemaker Washer and Dryer Electric...
The timer knob spins freely and I can't start the machine or set the timer.
"Can I replace it with a new knob or do I have to buy a new timer?"
It sounds like the knob is rounded out where it fits on the timer post, or It may just be loose. Pull the knob off and inspect it. If damaged, yes, you can buy another one.
May 04, 2009 | GE WDSR2080D Top Load Washer
Ge washing machine pull knob
Replace the knob...The teeth on the back of it have broken.
Dec 01, 2008 | GE WBSR3140DW Top Load Washer
Ge spacemaker washer and dry stackable.
if you have a broken belt... remove the back. and the drum support. then you can remove the belt... and replace it with the new one...pull back the pulley and them loosen the belt... let me know
Sep 16, 2008 | GE WSM2480DWW Unitized Spacemaker Washer...
GE washer timer knob
I can not set the timer on my GE washer. The knob just turns with out stopping.
Mar 04, 2008 | GE WDSR2080D Top Load Washer
GE Spacemaker Washer and Dryer Electric Laundry Center Logo
510 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
